Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Capability, Accuracy and Stability - Process, Machine, etc.
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 4.00 average. Display Modes
Old 30th April 2001, 08:55 AM
Chris_UK
Unregistered Guest
Posts: n/a
Question Capability index for one-sided specification? Cpk(max) = (USL-Xbar)/3*s ??
Does anybody know if there is a capability index I can use for a one-sided specification. ie +0.5mm -0mm. The distribution is normal.
Sponsored Links
Old 30th April 2001, 09:05 AM
Don Winton's Avatar
Don Winton Don Winton is offline
dWizard
Registration Date: Nov 1998
Karma Power: 63
Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.
Default
Regards,
dWizard
I was better but I got over it.
Sponsored Links
Old 30th April 2001, 12:05 PM
freeda
Unregistered Guest
Posts: n/a
Default
Chris,
I have a Word document that shows you the non-standard capabilities. If you will send me your e-mail address, I will send it to you. The formulas are a little hard to understand when you write them out here in the forum.
Old 2nd May 2001, 11:00 AM
Chris_uk
Unregistered Guest
Posts: n/a
Freeda
Thanks for the reply
I tried to mail you my address but the message was returned as undeliverable.
You can mail me at
quality@alpressings.co.uk
Cheers
Chris
Old 8th May 2001, 10:33 AM
MarkR
Unregistered Guest
Posts: n/a
Chris,
I don't think your example of +0.5 -0 illustrates a single sided tolerance. It is still bi-lateral, just not symmetrical. If you can make parts that are too big (over +.5) AND parts that are too small (under the -0) then it is bi-lateral.
A better example of single sided tolerance is flatness. If parts must be held flat within 0.030, then 0.030 is the upper spec and there is no lower spec (zero isn't the lower spec, it's the target). This is the situation where Cp doesn't apply and only the upper Cpk equation is used.
I think you still need to calculate Cp and both Cpk values to check for the possibility of making parts that are too big and too small. The only exception I can think of is if you have some natural limit on the process that simply can't be exceeded.
Old 23rd May 2001, 05:21 PM
V. Manea
Unregistered Guest
Posts: n/a
Hello there,
I too seem to find that some confusion exists with regards to one-sided tolerances. My example of one-sided will be most of the regular GD&T callouts. For example, true position of a hole. Defined as the diameter of a circle whithin which the centre of the hole must fall. So in most cases we see a 1.0mm diameter true posistion. Zero will be the target, 1.0 will be the USL, so how do we evaluate the process?
One option will be to calculate the Cp as 1.0/6-sigma.
Then calculate Cpk based on USL-proccess average/3-sigma.
Any other ideas?
Victor M.
Old 24th May 2001, 09:58 AM
Ken K.
Unregistered Guest
Posts: n/a
You're correct.
Using
Cpk = CPU = (USL - mean) / 3s
for a one-sided upper limit and
Cpk = CPL = (LSL - mean) / 3s
for a one-sided lower limit is standard AIAG SPC methodology.
If you were using MINITAB statistical software, you would also have the option of identifying a limit as being a "Boundary", which means that the product/process physically cannot exceed the boundary value.
In this case the data are treated as if there was a one-side spec limit (the bound is not considered a spec limit), AND the area beyond the boundary value is excluded from any PPM defective calculations.
Old 23rd June 2001, 12:33 PM
jadubar jadubar is offline
E-Mails Invalid or Rejected
Registration Date: Jun 2001
Karma Power: 0
jadubar has less than 100 Karma points so far.
Yin Yang
In response to the original question, "Does anybody know if there is a capability index I can use for a one-sided specification. ie +0.5mm -0mm. The distribution is normal."
This is not a one sided tolerance.
A one sided tolerance has a natural limit. For instance, run-out will never be less than zero.
If you have a Ø5.00 hole with a +0.5mm -0mm tolerance, you treat it as Ø5.25 ± 0.25mm and use the normal calculation methdods for a bilateral tolerance. It is still a unilateral tolerance because it does not have a natural limit.
The intent of this type of tolerance is to indicate that the low limit is more critical than the high limit.
A high cpk using USL-Mean/3s would actually mean you are producing the part toward the risky side of the tolerance.
I believe you can find information on + or - only tolerances in one of the newer GD&T handbooks.
[This message has been edited by jadubar (edited 23 June 2001).]
Reply
Bookmarks
Tags
capability, capability formula, cpk, one-sided specification
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Why is Cpk = lower of (USL-Xbar)/3sig & (Xbar-LSL)/3sig ? krishna_sadas Capability, Accuracy and Stability - Process, Machine, etc. 20 3rd July 2008 11:41 PM
Calcuating a one sided (LSL) Cpk for Proccess Capability T Dutton Capability, Accuracy and Stability - Process, Machine, etc. 17 13th June 2006 02:34 PM
Ppk/Cpk value with 1-sided specification - Only given a lower specification froggy66 SPC Monitoring and Statistical Analysis Techniques 1 24th May 2006 10:41 AM
What does TCI mean? Test Capability Index = USL-LSL/6*sigma of the test only pfumvue Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4 23rd March 2005 02:43 PM
Cp, Cpk, Sp, Spk for a one-sided minimum specification bkearns Capability, Accuracy and Stability - Process, Machine, etc. 2 16th March 2004 07:03 PM
The time now is 08:28 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
