Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - Calibration, Measurement Gages and Test Laboratories > Gage R&R (GR&R) and MSA (Measurement Systems Analysis)
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 5.00 average. Display Modes
Old 23rd March 2000, 06:17 PM
chuy sanchez
Unregistered Guest
Posts: n/a
Question Gage R&R - RTT (Total Spec) - New tecnique to calculate R&R involving Six Sigma
A friend just told me that a new tecnique to calculate r&r involving 6 sigma ( no from g.e.concept) so, somebody hear about that ?
Only that i know is when you relations is with RTT( total Spec ).
thanks
Sponsored Links
Old 31st March 2000, 12:23 PM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Yin Yang
I''m not an R&R expert. Maybe one of the other folks can pick up on this.
Sponsored Links
Old 31st March 2000, 12:51 PM
Don Winton's Avatar
Don Winton Don Winton is offline
dWizard
Registration Date: Nov 1998
Karma Power: 63
Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.
Question
I have not heard anything "new" regarding R&R either.
Regards,
Don
Old 8th April 2000, 07:50 PM
Batman
Unregistered Guest
Posts: n/a
I am not a statistamagician, but on occasion I have used a 6 sigma vs total tolerance when using a CMM or similar instrument and only needed the "R" repeatability part of the Gage error.
I take one part and measure it 20 times (not sure how significant THAT value is - 15 may be enough) and calculate the 6 sigma of those values. Theoretically, this give the error of the measurement device, which is then compared to the total tolerance.
I don't recall reading this anywhere, but no one ever complained.
Old 9th April 2000, 06:46 PM
chuy sanchez
Unregistered Guest
Posts: n/a
BIG Smile
yeahhhhhh, thanks
I just talk with a friend statical man and he give the same aswer that you batman.
The only issue is : if you use a gage for SPC chart you should be use a 6 sigma, if not use the regular calculation.
For what ? only the impact the readings and more exacly which error is permissible on this instrument.
thanks
Old 18th April 2000, 12:55 PM
Batman
Unregistered Guest
Posts: n/a
Not sure of your question, Chuy, but when you perform a GR&R, you are qualifying the gage to either accept readings from it or not. SPC is separate from GR&R in that, given the gage is acceptable, the actual readings from the process are charted, and any other [correct] data analysis is accepted since the data were collected and accepted by an acceptable gage.
Old 3rd July 2001, 12:41 AM
AllenLee
Unregistered Guest
Posts: n/a
Question G R&R
I have a silly question, does the G R&R mean 5.15¦Òm ( Standard deviation of measurement system)?
Thanks!
Allen
Allen Lee
Old 3rd July 2001, 12:35 PM
Ken K.
Unregistered Guest
Posts: n/a
Default
A gage R&R is a method of evaluating several potential sources of variation in a measurement system. The typical gage R&R quantifies the variation due to differences between parts, between operators, and between units treated identically (gage variation).
The idea is that the variation between operators and the gage variation should be small compared to the total variation observed. If it is not, you can use the gage R&R to determine whether you need to retrain your operators or improve your gage, or both.
If you haven't already, I strongly suggest you purchase a copy of the AIAG Measurement System Analysis Reference Manual, available at http://www.aiag.org/
Only $11 for non-members. It is well written.
I also strongly suggest you invest in statistical software capable of analyzing the results properly. Your best bets are MINITAB, StatGraphics, and JMP. I prefer MINITAB.
Ken K.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Tolerance vs Total Variation in Gage R&R report - MSA 3rd edition pg. 116 Geese Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14 13th February 2009 08:34 PM
Gage R&R - Sigma Multiplier 5.15 or 6 AFBlackBelt Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2 15th December 2008 11:45 AM
Calculating Gage R&R with Part Tolerance instead of Total Variation Periannan Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7 2nd August 2007 10:17 AM
How do I calculate Gage R&R (GR&R) with 1 tester, 1 operator, 3x4 units? iii_v Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2 13th July 2006 04:53 AM
Gage R&R on plating thickness - What do I use as the total tolerance? billsfan Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8 18th April 2000 12:43 PM
The time now is 08:56 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
