Elsmar Cove Quality and Medical Device Discussions
The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > National and International Business System Standards > Aviation, Space and Defense Standards and Requirements > AS9100, Nadcap and related Aerospace Standards and Requirements
Forum Username
Wooden Line
Need help with AS9102 form #2.
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Bodies - World Wide Standards Bodies
International Standards Organization - ISO Standards and Information
Atul's
Quality Forum Online
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Quality Digest
Reply
  Post Number #1
Old 24th January 2007, 08:26 AM
Quality-Misfit - 2008
Thank You! Need help with AS9102 form #2.
Hello Cove,
I have a few questions about form 2.
Question 1: Does the statement "Make From" mean that if we (production) take any type of raw materials i.e. we use a liquid plastic to make a earpiece it has to be recorded ? If so what has to be recorded?
Question 2: Does Standard Catalog hardware have to be recorded here as well? I thought they were excluded per section 4 of the AS specification but it is mention here.
Question 3: Also under the special processes the only thing done is soldering "done by our internal IPC certified solders" do we have to record anything here or is it covered by our job traveler?
Any advice would be helpful.
Thanks in advance.
qm
Sponsored Links
  Post Number #2
Old 24th January 2007, 11:59 AM
andygr's Avatar
andygr
Re: Need help with AS9102 form #2.
Question 1- You need to indicate what the raw material is and the ref the applicable spec if any. It may just be the suppliers controling doc such as a tech data sheet.
Question 2- You have to record standard catalog items used and the verification is covered by referancing the C of C number. You do not have to inspect any variable property of standard catalog itmes. If your design strictly calles out a suppliers part number no verification is required other than the CofC.
Question 3- For special processes you only need to cover if it a process is defined a "special" by you ( for F/A performed by subtiers) or your customer.
You have to show how it is verified that if required that you have meet all the applicable requirements for being approved. For example if you are required to have Customer XYZ approval then you need to referance the applicable approval document. Aerospace calles for Heat Treat to Nadcap and you would list you Nadcap approval as evidance of compliance.
Sponsored Links
  Post Number #3
Old 24th January 2007, 12:08 PM
In Reply to Parent Post by andygr View Post
Refernce 1: The oem is buying to our drawings and is using our drawings as their "Source control" So do we only have to list the plastic oems data sheet?
Reference 2: So this would be Stainless steel screw CofC number 12345? Do we have to list all the components that is in this unit? We have screws, nuts, plastic fittings, etc...maybe over 50 COTS items that go into this widget along with their C of C's.
Reference 3: How does this tie to soldering we do not have any of the special treatments defined by NADCAP. We're strickly an assembly shop. So unless we define soldering as a special process we don't have any.
Thanks.
qm
  Post Number #4
Old 24th January 2007, 12:18 PM
andygr's Avatar
andygr
Listing the supplers data sheet number for the plastic is all you need if that is what you called out in your design. If some one got fancy and created a internal spec then you have to verify. If not then only a ref to the C of C is only required. For the screw it probly is called out as a MS number of some other call out. You would list that and verification would be the C of C # xxx line item 3.
The Nadcap referance was only an example of flow down. In your case what would happen if you did not use IPC certifed solderers? If you are violating a customer or regulatory requirement then evidance of compliance is required with out a doubt. If it is called out as part of your processing spec it has to be covered a as part of the spec verification. If it is just a general shop practice ( good practice it is) you do not have to account for it on the FAI.
Hope this clears it up.
  Post Number #5
Old 24th January 2007, 12:33 PM
Andygr,
Thanks for your help, so in wraping this up.
1: We'll just list the raw material along with the suppliers data sheet
2: All hardware has to be called out?
As I stated earlier we have over 50 items that goes into the widgets top level assembly from screws, nuts, fastners, rubber gromets, etc.. all of these items that go into the item has to be recorded on our FAI?
I guess this also applies to any subassemblies as well.
Also on a side note how far down do you go into the subassemblies? If the oem is buying to our drawing?
3. IPC is only for our requirement and not mandated by our customer. So it does not have to be accounted for in the FAI.
qm
Last edited by Quality-Misfit - 2008; 24th January 2007 at 12:35 PM. Reason: can't speel
  Post Number #6
Old 24th January 2007, 01:06 PM
RCW's Avatar
RCW
Sorry to intrude and possibly cause more confusion but I have the following comments.
Re: #2....I haven't included any standard catalog items on FAI forms (yet) and I haven't gotten any feedback to the contrary from my customers. I do have in my internal quality procedure that standard catalog items will be processed via our normal incoming inspection procedures and will not be listed on FAI forms. As far as referencing a C of C number, I do have C of C's on file to cover my backside for these items but many of these don't contain a reference number. In my own case, this wouldn't work well to use this on the FAI form.
Re: #3....In addition to what andygr touched on, some customers define special processes (heat treating, anodizing, even soldering) that have to be performed by their own approved vendors. If this is the case, which it sounds like it isn't, then the special process and approved vendor is listed on form 2. While you, Quality-Misfit, are peforming a soldering tasks, it sounds like your customer is not placing this requirement on you.
Hope this helps.
  Post Number #7
Old 24th January 2007, 01:17 PM
In Reply to Parent Post by RCW View Post
Re: #3....In addition to what andygr touched on, some customers define special processes (heat treating, anodizing, even soldering) that have to be performed by their own approved vendors. If this is the case, which it sounds like it isn't, then the special process and approved vendor is listed on form 3. While you, Quality-Misfit, are peforming a soldering tasks, it sounds like your customer is not placing this requirement on you.
Hope this helps.
So you've excluded the lisiting of hardware on form 2 for an AS9102 FAI? Again my concern is lisitng all of these items, most of my c of c's have no reference number on them.
Again we're currently not doing any special processes i.e. heat treating , etc only soldering.
Thanks,
qm
  Post Number #8
Old 24th January 2007, 01:25 PM
andygr's Avatar
andygr
For certifications that have no unique number you can use PO# and date of supplier cert.
Just have to be able to get there from here.
"All hardware has to be called out? "
Yes it does. For example Electronic FAI are a bear with all the components that they contain. The only thing that can save some work is that you can cross referance components that are covered already.
"I guess this also applies to any subassemblies as well."
Yes
"Also on a side note how far down do you go into the subassemblies? If the oem is buying to our drawing?"
Only if you get them to cover you in writing to only need top level FAI can you stop there. This also can get into what you want to keep from them as priporitary information. Talk to them and work it out. I personaly recomend that even if they do not require you to perform the sublevels that you do them any way as the AS9102 FAI process does allow you to truly verify that production matches design.
Last edited by andygr; 24th January 2007 at 01:27 PM. Reason: Clarify cert tracking
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
AS9102 Form #3 modification mlaurie AS9100, Nadcap and related Aerospace Standards and Requirements 5 11th February 2015 01:30 PM
AS9102 FAI - Detail vs Assembly FAI (Form 1, Box 13) demir-ahmet AS9100, Nadcap and related Aerospace Standards and Requirements 6 27th August 2014 08:08 PM
AS9102 FAI (First Article Inspection) Form example ttwerp65 - 2009 Document Control Systems, Procedures, Forms and Templates 30 21st June 2013 02:00 PM
Another FAI AS9102 form question tonefordays Document Control Systems, Procedures, Forms and Templates 3 12th November 2011 10:54 AM
AS9102 Form - Do you hate it as much as I do? Kevo25 AS9100, Nadcap and related Aerospace Standards and Requirements 27 29th September 2008 11:28 AM
The time now is 03:00 PM. All times are GMT -4.
NOTE: This forum uses "Cookies"
