Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > SPC Monitoring and Statistical Analysis Techniques
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 5.00 average. Display Modes
Old 26th August 1999, 08:59 AM
Steven Sulkin
Unregistered Guest
Posts: n/a
Question Precontrol and Process Capability - CNC Lathes that run small batches - Short Runs
Trying to determine what type of control chart to apply...
We two CNC Lathes that run small batches. These batches may be of different material and configurations which require setups between runs. There is a lot of variation between runs (due to setups) and very little variation within runs (variation in lathe).
I would appreciate a recommendation. If you successfully implemented SPC in this circumstance an example would also be appreciated.
Sponsored Links
Old 26th August 1999, 12:20 PM
Roger Eastin Roger Eastin is offline
An Original Cover!
Registration Date: Dec 1998
Karma Power: 54
Roger Eastin has less than 100 Karma points so far.
We had a similar situation and used some of the "short-run" SPC techniques to help us. It requires, among other things, to know the sigma of each "within set-up" run. By normalizing the "gross sigma" for the process, you can have one set of modified control limits for each NC machine. This technique allows you to focus on the machine and not just the part that you are fabricating. We used this technique years back and it worked. You do lose some resolution on the control limits, but we found that the gains outweighed the loss due to resolution. Anyway, check out some books on this topic in the ASQ Publications catalogue.
Sponsored Links
Old 26th August 1999, 12:33 PM
Don Winton's Avatar
Don Winton Don Winton is offline
dWizard
Registration Date: Nov 1998
Karma Power: 63
Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.
Question
I am not sure I can help here. Control chart applications are very dependent on usage. It sounds as if your chart is varying across setups, but I need more details.
There are some alternatives to the traditional control chart in this type (small run) which may be of help. Under the assumption that each run is different, you may want to look at a pre-control type of technique.
Perhaps I could be more help if additional details were provided. Or, perhaps someone else has had this experience. Personally, I have found control charts for short runs rather, in a word, lacking.
Regards,
Don
Just the ramblings of an Old Wizard Warrior.
Old 26th July 2001, 03:10 PM
dmac
Unregistered Guest
Posts: n/a
Question precontrol and process capability
Are there any statistical formulas that relate precontrol data to process capability indices?
Old 26th July 2001, 03:55 PM
D.Scott's Avatar
D.Scott D.Scott is offline
Registration Date: Feb 2001
Thanks Given to Others: 80
Karma Power: 149
D.Scott is appreciated, and has over 1700 Karma points.
D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.
Send a message via Yahoo to D.Scott
dmac - I am not sure this is what you are looking for but here it is anyway for what it is worth.
To establish a pre-control chart, it must be assumed that the process is normally distributed with a Cpk of at least 1.0. It can then be statistically shown that 86% of the product will be within the control lines with 7% in each of the other sections.
As there is no statistical data taken or analyzed, it is important to only use pre-control on a process known to be stable.
I am sure there are others who can add a lot to this but at least it may help to get you started.
Dave
Old 31st July 2001, 01:53 AM
MSAFAI MSAFAI is offline
Registration Date: May 2001
Thanks Given to Others: 4
Karma Power: 35
MSAFAI has less than 100 Karma points so far.
Yin Yang
1- Check normality by using a Histogram of your data.
2- You can have a ROUGH estimate of process capability by taking standard deviation of your data and calculating Ppk.
3- I don't know to what extent you can rely on the above calculation, because using a Pre-control chart you cannot be sure your process is under control (a prerequisit to determining capability)
Any other ideas?
MSAFAI
Old 7th December 2002, 05:40 AM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,896
Karma Power: 605
Let Me Help You
Seeking any other details on Pre-Control. Found this here FYI:
http://Elsmar.com/Forums/showthread.php?t=5156
Old 8th December 2002, 06:00 AM
Chemman Chemman is offline
Registration Date: Oct 2002
Karma Power: 29
Chemman has less than 100 Karma points so far.
Question
Steve: We two CNC Lathes that run small batches. These batches may be of different material and configurations which require setups between runs. There is a lot of variation between runs (due to setups) and very little variation within runs (variation in lathe).
I have a similar problem, but unable to use any SPC that I know of. We take a batch of material, mold it, cure it in an oven under clamped pressure, grind it, scorch it, then take 5 pcs/batch (batch = approx 3000 parts) and do various physical tests on it. SPC is not done on the process, but the end result of these operations.
So for example, the density of the part is measured per batch as a subgroup. This charateristic is affected by every operation above beginning with the material batch, potentially processed on 1 of 3 presses, through 1 of 6 ovens, 4 clamping stations,etc. It is not possible to keep these separate and plot individually. Each control chart subgroup is from a different batch of material and off a multitude of processes and equipment.
Limits are very tight from Rbar, which makes the charts look terrible from subgroup to subgroup variation, but still very controlled compared to the specifications. This is hard to explain to vistors that do not understand the complexity of the problem.
To me, it seems that these could be considered different setups, processes, or population just as you would expect a mean shift for a different lot of steel in a fineblank press.
When things appear to go out of control, there is not much you can do to react to the problem. There is no adjustment at this point in the process because the parts are already made. Because this happens very frequently and because of the huge number of influencing factors, you can't investigate everything and record the reaction as required for OUC conditions. Some real assignable causes can be determined after a week or two if your lucky, others are just ellusive despite DOE after DOE. I have began to think that this level of variation is normal, little more can be done to improve it, and that a lot of my problem is the use of control charts that shouldn't be applied to this situation. I think standard Xbar & R charts are inappropriate here. Anyone agree or am I out in left field?
Thanks,
Chemman
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
How to implement SPC in a CNC m/c shop processing small batches of 'one timer' jobs? Joe_1 SPC Monitoring and Statistical Analysis Techniques 9 18th February 2009 06:59 PM
Machine Capability Studies on CNC Lathes DWPOZE SPC Monitoring and Statistical Analysis Techniques 34 29th March 2008 02:08 PM
Example - PFMEA for Machined Parts on CNC Mills & Lathes MTECD FMEA and Control Plans 3 11th October 2006 11:14 AM
CNC test pieces for milling and turning - I need to run a process capability study Brian Hunt ISO 17025 - Calibration, Measurement Gages and Test Laboratories 2 6th May 2004 02:58 PM
SPC for Short Runs (Control Limits) vs. Precontrol charts (Specification Limits) Don Winton SPC Monitoring and Statistical Analysis Techniques 7 10th October 1998 01:45 AM
The time now is 03:35 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
