Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
2nd February 2007, 04:14 PM
Registered Visitor
Registration Date: May 2005
Karma Power: 34 Karma: 10
Does Excel STDEV calculate in 3 stdev (standard deviation)?
Does Excel STDEV calculate in 3 stdev?
2nd February 2007, 05:24 PM
True Artisan
Registration Date: Aug 2003
Thanks Given to Others: 53
Karma Power: 107
Re: 3 standard Deviation in excel
If I'm interpreting the questions correctly - NO.
STDEV is one standard deviation - you'll have to multiply it by 3 in a formula somewhere.
I don't have a solution, but I admire your problem. -- Steven Wright
I'm a moderator here, so if you need help with something, feel free to ask.
2nd February 2007, 05:52 PM
Involved in Discussions
Registration Date: Sep 2006
Thanks Given to Others: 42
Karma Power: 39
In Excel STDEV yeilds one sample standard deviation. To get 3 sigma you need to multiply it by 3. Also, if you need the standard deviation of a population, you should use STDEVP instead.
Rock is hard but water is patient!!!
2nd February 2007, 06:33 PM
Statistician
Thanks Given to Others: 206
Karma Power: 134
In Reply to Parent Post by Howard Lee
I wish Microsoft would do away with the STDEVP function. It has no use. The difference is that STDEV divides by n-1 and STDEVP divides by n. Can anyone tell me when you would use STDEVP?
Steven Walfish
When in doubt, ask your company statistician!
2nd February 2007, 09:14 PM
Wes R
Registration Date: Jun 2004
Karma Power: 54
In Reply to Parent Post by Statistical Steven
Hi Statistical Steven,
It would be used if you had the entire data set. Although this is less common, there are a few cases: 1. The standard deviation of test scores for the entire number of students in a class. 2. The standard deviation of a part characteristic when you have measured all of the parts in the production run. Both cases would typically have a fairly small number in the population, such as less than 100 items.
I accept that if you have measured all of the population values, then you could graph the values and see how they are distributed.
Wes R.
3rd February 2007, 11:29 AM
Deming Disciple
Registration Date: Feb 2004
Thanks Given to Others: 145
Karma Power: 260
I think I've also answered this on the ASQ board from a question there. But here goes:
The formula for sigma (STDEVP) is the maximum likelihood estimator for the population standard deviation. However, it is a biased estimator. If you only have a sample of the population (and consider - if the "future" is part of your population, you still only have a sample), STDEVP will have a bias in it. If you repeatedly sample from a population, you will notice that the average STDEVP values will not tend to match the actual population standard deviation. However, if you use STDEV (dividing by n-1), the average of the STDEV's will converge on the population standard deviation.
Steve Prevette
"A Passionate Statistician", ASQ CQE, ASQ Fellow
3rd February 2007, 10:10 PM
Registration Date: Sep 2003
Thanks Given to Others: 29
Karma Power: 148
Re: Does Excel STDEV calculate in 3 stdev (standard deviation)?
I like what Steve said, but I want to make two minor points. - sigma (STDEVP) would be the population standard deviation, not an estimate. When you have the full set, you don't need to estimate!
- I believe it is actually (STDEV)^2 that averages to (STDEVP)^2, not STDEV that average to STDEVP. That is, you take the variances calculated from the sample standard deviations and average them to get an unbiased estimate of the true variance.
Of course, all this is all WAY to esoteric for most people!
3rd February 2007, 11:32 PM
Statistician
Karma Power: 134
Actually S^2 is the MLE for sigma squared...but that is not the point. If as Wes stated, you have the entire population, then why would you need to know the standard deviation. That is to say, any inferences to be made can be made from the data in the population. There are no confidence intervals that need to be calculated. I am stumped, regardless of the theoretical differences between sigma and S, why there is an application that someone would be using Excel for that requires the population stdev.
Steven Walfish
Forum Posting Settings
