Go Back   The Elsmar Cove Forum > Manufacturing, Service, and Business Systems Processes > Process Maps, Process Mapping and Turtle Diagrams
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 4.00 average. Display Modes
Old 28th February 2007, 10:27 AM
Dizzydom Dizzydom is offline
Registration Date: Feb 2007
Thanks Given to Others: 1
Karma Power: 12
Dizzydom has less than 100 Karma points so far.
Question Using a Value Stream Map as High Level Process Map
I am the new Manufacturing Manager for 50-person manufacturing organization. We have a goal to become registered to ISO-9000:2K in 2007.
I am planning a value stream mapping exercise at the GM's request (will help educate me on their processes). My question is can this value stream map also serve as the higher level process map that defines "what we do and how we do it" which I think can be the basis for our quality manual?
Thanks,
Dom
Sponsored Links
Old 28th February 2007, 10:45 AM
Madfox's Avatar
Madfox Madfox is offline
Involved - Posts
Registration Date: Apr 2006
Karma Power: 22
Madfox is appreciated, and has over 200 Karma points.Madfox is appreciated, and has over 200 Karma points.Madfox is appreciated, and has over 200 Karma points.
Default Re: Using a Value Stream Map as High Level Process Map
Sure it can...
I've noted/posted elsewhere my thought(s) that a VSM is really just a detailed process map with data.
Unfortunately, I usually see output from "high level" mapping projects reflect a "managerial-centric" view rather than a realistic depiction of what the organization does to make a living. For example, the maps often has the "management" or "improvement" processes taking up 1/4 - 1/3 of the map when management meets or two days a year, or the organization generates a handful of CA/PA's annually.
Make it show what you really, really do on a daily basis!
Follow order flow!
The Madfox
Sponsored Links
Old 28th February 2007, 03:05 PM
Paul Simpson's Avatar
Paul Simpson Paul Simpson is offline
Looking for Solutions
Registration Date: Jan 2002
Thanks Given to Others: 280
Karma Power: 122
Paul Simpson is appreciated, and has over 1700 Karma points.
Paul Simpson is appreciated, and has over 1700 Karma points.Paul Simpson is appreciated, and has over 1700 Karma points.Paul Simpson is appreciated, and has over 1700 Karma points.
Send a message via Skype™ to Paul Simpson
Originally Posted by Dizzydom View Post
Thanks,
Dom
IMHO the value stream map does not generally cover a lot of the support functions and the business planning / leadership type processes. If you can bring those in then it should serve your purpose.
Good luck.
Rgds, Paul Simpson
Looking for Solutions, Reclaiming the "Q" word
Old 28th February 2007, 03:54 PM
tjwoolno's Avatar
tjwoolno tjwoolno is offline
Getting Involved (6 to 9 Posts)
Registration Date: Jan 2003
Thanks Given to Others: 6
Karma Power: 28
tjwoolno has less than 100 Karma points so far.
Send a message via Yahoo to tjwoolno
The Hat Re: Using a Value Stream Map as High Level Process Map
I agree with Paul. You have to make sure that you cover your support systems but I do think that the Value Stream Map is an excellent starting point. Good Luck!
Old 30th May 2007, 02:59 PM
Karma Power: 12
Thanks for the feed back. I have attached a spreadsheet that I wish to use as our quality manual. Three tabs 1) Scope 2) High Level Process Map 3) Process Matrix (still missing the hot links to corporate/local procedures and instructions). My goal is to have this be our quality manual as I believe it meets the requirement of a quality manual.
Am I way off base with my assumptions?
Thanks,
DizzyDom
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
Old 30th May 2007, 03:20 PM
AndyN's Avatar
AndyN AndyN is offline
Registration Date: Feb 2005
Thanks Given to Others: 1,784
Karma Power: 297
AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.
AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.
Let Me Help You Re: Using a Value Stream Map as High Level Process Map
I would agree with Paul on this one. Typically, a value stream map isn't the description of the business processes and their 'sequence and interaction', which you would have to describe in your QM. As I understand a VSM, it describes the (much) lower level of process along which movement of materials, people etc can be identified, with the aim of driving out non-value added/waste activities.
A simple linear process map would be quite adequate.
Your excel file was interesting, but I'm not sure it would pass muster as far as getting you registered. Although I favor a less than traditional approach to the normal manuals (which replicate the standard, clause by clause), I feel your example would be a bit too radical. One thing you might ask is, can your management 'talk to it'?
There's a (long) thread about 4 page manuals here, somewhere........
'Cause you know sometimes words have two meanings.....
Thanks to AndyN for your informative Post and/or Attachment!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Traveler Map, Control Map, Request Map - Clause 7.3.3 Design and Development QAMTY ISO 9001 - Quality Management Systems Standard 2 23rd May 2009 06:34 AM
High-level process map for a leasing service company MSAFAI Service Industry Specific Topics 2 9th September 2008 10:33 PM
Please Review my High Level QM (Quality Management) Process Map hrrvett Process Maps, Process Mapping and Turtle Diagrams 52 6th April 2008 01:07 PM
Business process map - Please Review my Process Map and Turtle Diagram phomer Process Maps, Process Mapping and Turtle Diagrams 31 16th July 2007 10:35 PM
Flow chart vs. Process map vs. Value stream map - What are the differences? pradeep sharma Process Maps, Process Mapping and Turtle Diagrams 4 16th December 2005 03:24 PM
The time now is 12:44 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
