Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Quality Tools, Improvement and Analysis > Quality Assurance and Compliance Software Tools / Solutions > Using Minitab Software
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 14th March 2007, 05:09 PM
jazzyd jazzyd is offline
Registration Date: Mar 2007
Karma Power: 11
jazzyd has less than 100 Karma points so far.
Please Help! Point Estimation - I need to use the Quadratic Regression Model - Minitab 14
Hi Guys,
I'm really hoping someone out there can help me.
I have been doing regression analysis in Minitab 14 and i need to do a point prediction. However, when i do a point prediction at the moment it always uses the formula for the Linear Regression model but i need to use the Quadratic regression model. Can anyone help?
Sponsored Links
Old 14th March 2007, 05:33 PM
Tim Folkerts's Avatar
Tim Folkerts Tim Folkerts is offline
Registration Date: Sep 2003
Thanks Given to Others: 27
Karma Power: 123
Tim Folkerts is appreciated, and has over 1700 Karma points.
Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.
Default Re: Point Estimation - I need to use the Quadratic Regression Model - Minitab 14
Welcome Jazzyd!
I'm not sitting at the right computer to explore the options within mintab, but would it work to get the answer "by hand"? If you only need to do this a few times, then a manual calculation (or perhaps using Excel) would also work.
Once you have the equation in the form
y = ax^2 + bx + c
and Minitab tells you the values of a, b, and c from the regression, you could plug in a value for x and find y. Or you could create a formula within Excel (or within Minitab for that matter) to calculate y for many values of x.
Of course, if you need to do this many times, or you need to plot the quadratic regression within Mintab, then calculating it yourself would be less useful.
Perhaps later I can get to the "right" computer and see about minitabs actual options.
Tim F
Sponsored Links
Old 14th March 2007, 05:43 PM
Karma Power: 11
Hi Tim,
Thanks for the reply, basically my issue is that i am doing a report and within the report i have to submit proof that i have used Minitab, i.e. a printout from it which includes prediction and confidence intervals.
i've managed to get a prediction point with the linear regression line, but i can't see any way of doing it with the quadratic regression formula. I've looked through all sorts of help files and get nowhere. If you can get to the 'right' computer and help me it would be much appreciated
Old 14th March 2007, 08:55 PM
Karma Power: 123
Would a graph suffice as "proof"?
In version 14 of Minitab, look in the menu Stat/Regression/Fitted Line Plot. Click the button for "Options" and there are check boxes for "Display Confidence Interval" and "Display Prediction Interval". If you select those, then at least the prediction & confidence intervals will be displayed on the graph.
You could cut & paste the resulting graph into your report. I don't see a way to get the actual numerical values, but often a graph is as good as a bunch of number in a table.
Tim F
Old 14th March 2007, 10:15 PM
reynald's Avatar
reynald reynald is offline
Involved in Discussions
Registration Date: Sep 2005
Thanks Given to Others: 68
Karma Power: 33
reynald is appreciated, and has over 700 Karma points.reynald is appreciated, and has over 700 Karma points.reynald is appreciated, and has over 700 Karma points.reynald is appreciated, and has over 700 Karma points.reynald is appreciated, and has over 700 Karma points.reynald is appreciated, and has over 700 Karma points.reynald is appreciated, and has over 700 Karma points.
Originally Posted by Tim Folkerts View Post
Welcome Jazzyd!
Tim F
Jazzyd,
Fortunately for you, i am now using minitab.
Do this:
Double click the line in the scatter plot with linear fit. Then a dilog box "edit Regression fit" will pop-up.
Select Options tab, then click your options.
Hope that helps
>>rey
"Unless the CEO builds the Company, the Engineers labor in vain"
Old 14th March 2007, 11:41 PM
Statistical Steven's Avatar
Statistical Steven Statistical Steven is offline
Consultant
Registration Date: May 2005
Thanks Given to Others: 36
Karma Power: 43
Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.
Send a message via Yahoo to Statistical Steven
Jazzyd
Create a new variable which is x^2 then fit the model Y=x + x^2 which will give you the coefficients for each parameter. Let me know if this works.
Steven Walfish
When in doubt, ask your company statistician!
Old 15th March 2007, 12:00 PM
Karma Power: 11
Hi guys,
Thank you all for your help. I ended up using Steven's suggestion. Unfortunately Tim a graph was not sufficient evidence. Rey i tried your method on some old date for which i knew what the correct estimate was and it through out a whole load of stuff that i didn't really know how to comprehend. Thanks once again for your help guys.
Jaz
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Evaluating a Regression Model Using the Constant Variance Assumption Jim Shelor Six Sigma 8 21st August 2009 02:45 PM
How to filter out responses from Minitab - Questionnaire using a 5 point likert scale Uso68 Using Minitab Software 3 8th April 2009 12:48 PM
Cost Estimation of Sand Casting Process including the Pig Loss in estimation kriss0072k Manufacturing and Related Processes 6 5th December 2008 10:06 AM
Inference for Regression Slope in Minitab - Significance test for Beta ashome Using Minitab Software 0 7th May 2008 02:44 PM
Point Cloud Technology Validation - Point Cloud to CAD model comparisons for FAIR Rus E ISO 17025 - Calibration, Measurement Gages and Test Laboratories 2 22nd March 2004 07:35 PM
The time now is 07:09 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
