14th September 1998, 03:40 AM
Do you need FMEA for QS 9000
Are FMEA's necessary to apply for QS9000
14th September 1998, 12:27 PM
FMEA's are necessary before you can be QS-9000 registered. FMEA's can be one of the most useful requirements of the standard.
16th September 1998, 07:40 AM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Both Design and Process FMEAs are required.
Don't forget control plans and the entire APQP process. In addition, you must be a tier 1 to Ford, GM and/or Chrysler or the requirement must be flowed down. It's not a 'cake walk'.
3rd October 1998, 08:18 PM
E-Mails Invalid or Rejected
Registration Date: Sep 1998
Karma Power: 0 Karma: 40
I have been led to believe FMEA's are required only when requested by the customer. I do not have my FMEA book with me, but this also has been verified with consultants. Am I in for a rude awakening? FMEA's are very good for a company, but also very costly to a small comapany;extremely time consuming.
4th October 1998, 09:30 AM
Karma Power: 605
QS9000 unambiguously requires:
Design FMEA
Process FMEA
Process Control Plan
Process Flow Diagram
No exceptions.
What consultant says you can register to QS9000 without these documents?
I beg to differ with you about the cost. If you do your documentation on your equipment you only do it once. Thereafter there will be regular minor updates as problems are solved and as other problems surface - but the main work is done during the initial effort.
Yes - if you believed otherwise you are in for a surprise. I know of no company which has been excused from this with the exception of design FMEAs for designs older than 5 years - which is in its self suspect, actually.
ISO9001 does NOT specifically require them but it does required a defined design process.
[This message has been edited by Marc Smith (edited 10-04-98).]
6th October 1998, 09:39 AM
Listen to Marc and not your consultant. PPAP requires FMEA. It may be implied in other areas but if you read the PPAP manual FMEA is required.
Although I agree that FMEA's are time consuming they save so much time and money in the long run, they are well worth the effort. An ounce of prevention.....
18th November 1998, 09:37 PM
Registration Date: Nov 1998
Karma Power: 45 Karma: 10
I work in procurement quality in aerospace, a fairly long way from QS9000. Many of my suppliers are small jobs shops, 10-25 employees.
However, when working with the quality managers, I haul out the QS manuals on FMEA and APQP and touch on some of the concepts.
The manuals present logical and structured approach to providing quality product that, in the long run, is cheaper for the supplier and my company.
By no means do I expect them to do full blown FMEAs, control plans, etc.;I may order 250 separate parts a year from a shop in small lots of 6 - 12 pieces.
But manuals do get the management of these small shops thinking about quality from a systems/process approach. And that can hurt either of us.
21st January 1999, 09:37 PM
So if I do not have a FMEA for every order on the shop floor, am I not in compliance?
