Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - Calibration, Measurement Gages and Test Laboratories > Calibration Frequency (Interval)
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 23rd April 2007, 06:08 PM
caseright caseright is offline
Shy Poster (1 to 5 Posts)
Registration Date: Jan 2007
Thanks Given to Others: 4
Karma Power: 12
caseright has less than 100 Karma points so far.
Please Help! Vision System which verifies the correct part is present - Calibration / Verification
Hello everyone!
I am new to this forum and have a question on calibrating a vision system. We have resently installed a vision system on our assemly line not to measure a part but to verify that the correct part is being used. The plan is to measure the first part of every job and take a picture of that part. Then every part in the job is compared to that registered image. This system is going to be used on hundreds of different part numbers so master parts for all of the different parts is impossible. The system isn't intended to verify that all of the parts are in print just to verify that the part isn't dramatically different than the measured part.
We are TS 16949 certified and I'm not sure what the auditor's interpitation will be on this. The vision system manufacturer says they have not heard of anyone calibrating a vision system since it doesn't really measure anything. Does anyone out there have a system in place like this? Do you have it calibrated or do you have master parts that you periodically check on it? Any help in this matter would be greatly appreciated.
Sponsored Links
Old 24th April 2007, 01:28 AM
BradM's Avatar
BradM BradM is offline
Registration Date: Sep 2006
Thanks Given to Others: 814
Karma Power: 274
BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.
BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.
Default Re: Vision System which verifies the correct part is present - Calibration / Verifica
Hello there! Welcome to the Cove!
On this vision system, what kind of assessments are being made? Is it making some type of dimensional assessment? Does it check for depth or some other type of measurement? Does it display parameters, or print them out?
If it is just a camera, then I could not see the value of a calibration. If there are any measurements/dimensions that are being assessed, I would think you would need to assure the accuracy of that measurement system.
Brad
My idea of housework is to sweep the room with a glance.
Thanks to BradM for your informative Post and/or Attachment!
Sponsored Links
Old 24th April 2007, 01:31 PM
Sidney Vianna's Avatar
Sidney Vianna Sidney Vianna is offline
Post responsibly
Registration Date: Oct 2001
Thanks Given to Others: 687
Karma Power: 467
Sidney Vianna is appreciated, and has over 1700 Karma points.
Sidney Vianna is appreciated, and has over 1700 Karma points.Sidney Vianna is appreciated, and has over 1700 Karma points.Sidney Vianna is appreciated, and has over 1700 Karma points.Sidney Vianna is appreciated, and has over 1700 Karma points.Sidney Vianna is appreciated, and has over 1700 Karma points.Sidney Vianna is appreciated, and has over 1700 Karma points.Sidney Vianna is appreciated, and has over 1700 Karma points.Sidney Vianna is appreciated, and has over 1700 Karma points.Sidney Vianna is appreciated, and has over 1700 Karma points.Sidney Vianna is appreciated, and has over 1700 Karma points.Sidney Vianna is appreciated, and has over 1700 Karma points.
From what you describe this "automated" visual inspection device is not "calibratable". However, how do you ensure that the system is warning you of defective parts? Can you "create" master no-go parts? I mean, parts that are slightly defective and the system should be able to identify and either sort or warn you about them? You could then run a test at a frequency that is appropriate and re-run such tests and keep a log.
Obviously this system must be able to be verified to it's "accuracy" and capability to detect non-conforming parts; otherwise, what would be the point of installing it?
Fighting organizational dysfunction, one post at a time.
Thanks to Sidney Vianna for your informative Post and/or Attachment!
Old 24th April 2007, 01:55 PM
Teri Teri is offline
Courtesy Access
Registration Date: Mar 2003
Thanks Given to Others: 3
Karma Power: 34
Teri is appreciated, and has over 100 Karma points.Teri is appreciated, and has over 100 Karma points.
This is exactly what we do with our vision systems, they are not calibrated, but we have parts that are a no-go, tested once per hour.
It sounds like you may run many different parts across the vision system at the same time? (we don't). But maybe you could come up with some kind of rotating system to check it?
Teri
Mistakes are a fact of life. It is the response to errors that count!
Thanks to Teri for your informative Post and/or Attachment!
Old 24th April 2007, 03:38 PM
Karma Power: 12
There are parameters displayed but they don't relate to inches or mm ete, they are measuring light pixels. I know about how much a part has to change dimensionally before it will fail so maybe one set of master parts that cover both limits would be the way to go?
Old 24th April 2007, 03:53 PM
BradM's Avatar
Karma Power: 274
OK. So you have a "master" part, that you set this dimension equipment to. You have set up the master dimension equipment, look at the other parts, then you make a thumbs-up/thums-down assessment.
I mean, I guess Teri and Sidney may have a little better feel for this than I. I have seen a lot of dimensioning equipment, and much of it requires some level of standardization to assure proper dimensions are obtained.
Have you contacted the mfg. of the equipment? They should be able to let you know what kind of verification is required.
Brad
Old 24th April 2007, 05:54 PM
Karma Power: 12
The mfg said they have never heard of anyone calibrating a vision system because it is technically not a measurement device and there are so many factors that affect it. Even though I'm not measuring a part per print shouldn't I be able to set up some parameters that I want the system to reject and ensure it is doing what I want it to do by running the master parts through it and making sure it will reject them?
Old 24th April 2007, 06:09 PM
Post responsibly
Karma Power: 467
Yes, you should. How else you would know if the equipment is working properly? The manufacturer of the equipment has to have acceptability tests. And they would have to be customized for the parts being inspected.
Reply
Bookmarks
Tags
vision measurement
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Vision system - how critical is part set up? Jgryn ISO 17025 - Calibration, Measurement Gages and Test Laboratories 4 2nd December 2008 08:08 PM
Choosing a Vision System - Recommendations for a User Friendlier System Dr. Electron Quality Tools, Improvement and Analysis 3 31st May 2008 06:27 AM
Can we comingle Gauging Vision System and 3 Point Micrometers? Skydave Manufacturing and Related Processes 2 24th February 2008 11:06 PM
Advice on Handling a Camera Vision System Calibration Master jkittle ISO 17025 - Calibration, Measurement Gages and Test Laboratories 7 5th November 2007 05:19 PM
Digital Multimeter - Verification vs. Calibration MSA (Measurement System Analysis) FloraOdchigue Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3 7th April 2005 10:45 AM
The time now is 10:45 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
