Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Inspection and Test, Sampling and Related Topics
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 28th June 1999, 03:16 PM
Andy Bassett Andy Bassett is offline
An Early Cover
Registration Date: Jun 1999
Karma Power: 48
Andy Bassett has less than 100 Karma points so far.
Please Help! Inspection Plans - Subcontracted Electronics Assembly
Can anyone help me out with a small problem. I am working as a consultant for a small (6 People) computer manufacturer near Dusseldorf. The company has had to learn from zero all about in-coming inspection, final inspection, inspection at the supplier etc.
As assembly is actually sub-contracted they need a very good Assembly/Inspection Plan, what they have done is a fair effort, but to help them does anybody have a sample/example of a Assembly/Inspection Plan for a peice of electonic equipment, ie computer, printer etc.
Regards
Andy B
Sponsored Links
Old 29th June 1999, 10:53 AM
Kevin Mader's Avatar
Kevin Mader Kevin Mader is offline
One of THE Original Covers!
Registration Date: Nov 1998
Thanks Given to Others: 22
Karma Power: 94
Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.
Send a message via AIM to Kevin Mader
Question
Andy,
Have your clients performed FMEAs or done other Risk Analysis? These processes point to where the need for inspection at Incoming Inspection are. For instance, if during Risk Analysis, your clients had determined that each circuit board must be individually wrapped, part of your incoming inspection plan may be to visually observe for proper packaging.
Regards,
Kevin
Sponsored Links
Old 29th June 1999, 11:27 AM
An Early Cover
Karma Power: 48
Hello Kevin
No they have not done any FMEA Analysis. On another thread i managed to ascertain that FMEA Analyis cannot really be outsourced, and i have found a company to train them with a 1 day FMEA course in August.
However this will come a little late for their current product. If i can show them a Inspection Plan for a similar product it would help to shape their thoughts. Typical questions that they are asking are.
1. Do they have to define the assembly process themselves(Consider assembly is sub-contracted).
2. Just how detailed do the inpsection steps have to be (ie isnt 'check screws after tightening' a little over the top).
3. They have designed some quite detailed inspection plans, but the employees seem to be prone to 'Tick Syndrome' without really checking.
I should just mention that the Assembler is ISO 9001 certified and currently applying for QS 9000.
By the way, i have never heard of Risk Analysis in this how it sounds? Is it a special Technology, or just another name for FMEA?
Regards
Andy
Old 29th June 1999, 07:09 PM
Karma Power: 94
Andy,
You guessed right, FMEA is a form of Risk Analysis. Generally speaking, FMEAs live in the automotive world. This is a great tool, however, for any industry. When you get into Medical Devices and Electronic equipment, often times other directives apply where Risk Analysis is expanded on (FDA, CE, etc.). Here, additional requirements must be completed as part of the process.
Taking your questions one by one:
1 What controls are excersized over your Clients suppliers? Does the supplier have a control plan they can send you? Is it satisfactory? Are proper percautions taken to ensure only conforming product is shipped to you? Do you need to perform any Incoming Inspection?
2 What are the Critical Product Characteristics (ie. what characteristics are critical to the operation or functioning of the unit)? Checking screws, unless determined a Critical Characteristic, is probably overkill.
3 Inspection is not a value added operation. It may be a nonvalue added but NECESSARY function however. Which do you have? Inspectors not inspecting might suggest that inspection is overkill, especially if proper precaution were taken when the item was created. It may also point to a deeper problem, so beware.
My suggestion would be to determine what precautions are taken by the supplier and what controls over the supplier are in place. From here, identify the critical characteristics, create an inspection plan using a statistically sound sampling plan. Based on past history, you establish the sampling level that best covers the organization and the customer (alpha/beta risk). Review the plan after a period of record making to see if you were too aggresive or too liberal in your planning.
Got to run......
Kevin
Old 1st July 1999, 05:00 AM
An Early Cover
Karma Power: 48
Thanks for your comments. As we are about to lauch a second new product i will take your comments on baord TODAY, as next week we will start interviewing the main suppliers for it. When i read the posts in this forum i get the impression that the Auotmotive boys all speak the same language.
When we start to discuss with the suppliers next week i know that they will hide behind the 'We are just a retailer' or 'Nobody has ever asked for that before' or 'Inspection...you will have to pay more for that'.etc etc.
As we are only on our second product, which is completely different to the first we dont have much experience to start setting sampling levels, we will have to shoot in the dark a little.
Reading your comments i had the idea to do the planned FMEA course using the new product with the target of producing a Process FMEA for the actual assembly of the final product which should solve one problem.
Could you tell me anything about the Alpha/Beta that you mentioned, is it something i can use, if its heavily into stats i will reitre hurt.
Regards
Andy Bassett
Old 1st July 1999, 03:58 PM
Karma Power: 94
Andy,
I think it would be a good idea to use the new project in your FMEA training. While selecting your source for training, speak with the trainer about your idea to use this new product. I would have to believe that the trainer will agree that this is a good idea.
When preparing an Inspection plan, you should use a statistically proven sampling plan (perhaps ANSI Z1.4). If you arbitrarily select a sampling plan (i.e. 5 because I have 5 fingers), it becomes difficult to prove to a registrar that your plan is proven effective. This does not mean that you can't do that. It means you need to do additional work to prove your method works, which most folks don't want to bother with especially in light of having plans already in existence and proven.
Alpha/Beta risk refers to the Producers/Consumers risk to rejecting a "good" lot or accepting a "bad" lot of product. You need to establish as an organization the level of risk you take (what is tolerable?). Generally, 5% risk is used as the industry norm. This isn't heavy stats, just basic stuff really. You can read more about it in most Sampling books (reference Jurans Quality Handbook, 25.9).
Inspection is a funny topic. Is it necessary? When is it necessary? Different for any given situation. Picking a starting point for Sampling Plan and Sample Size is difficult for most folks. Where do you start? The only way to answer this is to review historical data (how many lots rejected vs. lot received) proportion defective and know the risks encountered. While not very analytical, it can give you the basis for drawing the line in the sand. After collecting history for a period (again difficult to say, depends on your volume) you will need to review the Plan to determine its effectiveness. Not effective, increase your sampling size, frequency, tighten your sampling plan, many, many, considerations. But eventually you get to a plan that will work well in your system. I am giving you the brief on this, but you should read more about sampling plans to draw stronger conclusions for yourself. I hope this helps a bit. Don, are you out there? You tend to explain the OC pretty well.
Regards,
Kevin
Back to the group....
Old 2nd July 1999, 01:41 AM
Don Winton's Avatar
Don Winton Don Winton is offline
dWizard
Karma Power: 63
Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.
Read This!
Yea, Kevin I am here. Have been real busy the last few weeks and will be so for the next many (I hope). I have started consulting part-time and have two clients thus far (in addition to my full time job). So, things are a bit hectic. Anyway, on with the show:
You have addressed this subject well, to which I will only add-Rather than discuss in detail here the various aspects of sampling, I suggest the following:
For a discussion of sampling plans in general and OC curves in particular http://www.samplingplans.com
There is also an OC curve simulator at my site in the Statistical section. Hope this helps.
Regards,
Don
Old 4th July 1999, 08:43 AM
An Early Cover
Karma Power: 48
Thanks for the Statistics Link, i have gone through it (along with a bottle of wine) and will defintely use it for reference for the future.
For the moment it is a bit further advanced than either my knowledge or my clients experience.
Maybe i am unlucky, but i always seem to be involved with clients who have something less than regular mass production, which seems to make statistics difficult to use (Or maybe i dont know how to use statistics properly?),
For example the current client wants every product to come off the production line to be correct, which means a 100% Final Inspection is planned.
On the supplier side as many goods are coming through retailers, they give you the cold shoulder if you start to question them about their quality levels.
Historical evidence is nearly impossible to come by as this client is only on its second product which is completely different form the first.
I can only assume that we need a little more experience with the products before creating sampling plans with any accuracy.
Andy B
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Traceability in Electronics Assembly harinandu2003 Manufacturing and Related Processes 8 30th March 2009 09:02 AM
Control Plans and Inspection Plans for panel board industries naran FMEA and Control Plans 5 1st March 2009 11:46 AM
Mixed Model Assembly Line Control Plans - Many different options that are available puddycat FMEA and Control Plans 2 10th January 2007 04:24 PM
Process Control Plan and Inspection Plans - Receiving and final inspection required? krishkaar Inspection and Test, Sampling and Related Topics 8 3rd November 2004 07:46 AM
Ishikawa Fishbone for Electronics Assembly M Greenaway Quality Tools, Improvement and Analysis 5 4th August 2003 04:24 PM
The time now is 11:24 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
