Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Capability, Accuracy and Stability - Process, Machine, etc.
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 16th February 2000, 10:06 AM
ivo
Unregistered Guest
Posts: n/a
Question Capability Studies - Fewest Number of Parts for a Capability Study
For my traineeship, I have to improve a production process. I have done an FMEA and now I want to do a capability study. But at school I learned that the least amount of products you should produce (to test) is 50.
But the products that I have to produce are about 13 meters long and 100 kg. Is there a way to reduce the number of products? Please let me know..........
Sponsored Links
Old 16th February 2000, 03:55 PM
Mike525
Unregistered Guest
Posts: n/a
ivo:
I'm not a statisticion, but I believe the fewest number of parts one can use for a capability study, and still be statistically correct, is 31 - has something to do with the distribution under a normal curve based on the Standard Normal (z) Table and Sample (t) Table. Two good books to reference are "Introduction to Statistical Quality Control" 2nd ed. by Douglas Montgomery, and "Understanding Statistical Process Control" 2nd ed., by Donald Wheeler and David Chambers. Hope this helps.
Sponsored Links
Old 18th February 2000, 04:19 AM
Qualiman Qualiman is offline
Involved - Posts
Registration Date: Feb 2000
Thanks Given to Others: 11
Karma Power: 41
Qualiman has less than 100 Karma points so far.
Lightbulb
ivo:
As a normal rule you cannot make a capability study unless you have already demonstrated the stability of your process, and you need at least 30 data if you use average lectures and more than 100 for individual moving range charts.
However,(I declare : I am not an expert in this field) you can run some short time period (or preliminary)studies to have an idea of your process capability using let us say.. 7 lectures, but in this case you must close your gap and instead of using 3 sigma you have to use 4, I think to "compensate" of using few points.
What other folks think ?
Qualiman
Old 27th February 2000, 08:11 PM
Batman
Unregistered Guest
Posts: n/a
Screw
One should always plan the attack before going into the field. If one is charged with improving a process, one would plan the attack, which would include the "after" sampling, along with the comparison to the "before" stuff.
That said, in this instance, based on the description of the product there are few parts made per day, them how about just adding the new data onto the old in a run chart of some sort. I assume that there was historical data that suggested the need for improvement, so take some "after" parts (seperate enough from the "before" parts - maybe a "purge" of the process) and add the sample data to a run chart of the prior data - Average and moving range, for example. If the large size is an indication of being able to run only a few per hour or day, then I think only a few could be necessary. The improvement (or lack thereof) should be obvious. IF there is an improvement, continue to run more parts, enough to see expected variation over some time, then calculate capability.
I think the first step is to determine if the change was a real improvement.
Old 20th June 2006, 01:29 PM
Marc's Avatar
Marc Marc is online now
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Default Re: Capability Studies - Fewest Number of Parts for a Capability Study
Can anyone clarify the minimum number of parts required for a capability study and the reasoning behind the number?
Anyone know where Mike525 might have gotten the number 31?
Old 20th June 2006, 01:42 PM
Jim Wynne's Avatar
Jim Wynne Jim Wynne is online now
Courtesy Access
Registration Date: Jan 2005
Thanks Given to Others: 755
Karma Power: 611
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Generally speaking, in a normally distributed population, the sample and population standard deviations should be nearly identical after ~30 pieces. Generally. There are some problems (among others) with the idea of so-called 30-piece capability studies:
  • If the sampling isn't really random (i.e., each individual has an equal chance of being selected each time), all bets are off.
  • Unless the chronological order of production is preserved in the samples, an important and oft-overlookes component of capability study is lost.
Old 20th June 2006, 02:34 PM
jrubio's Avatar
jrubio jrubio is offline
Javier Rubio
Registration Date: Jun 2005
Thanks Given to Others: 2
Karma Power: 74
jrubio is appreciated, and has over 1700 Karma points.jrubio is appreciated, and has over 1700 Karma points.jrubio is appreciated, and has over 1700 Karma points.jrubio is appreciated, and has over 1700 Karma points.jrubio is appreciated, and has over 1700 Karma points.jrubio is appreciated, and has over 1700 Karma points.jrubio is appreciated, and has over 1700 Karma points.jrubio is appreciated, and has over 1700 Karma points.jrubio is appreciated, and has over 1700 Karma points.jrubio is appreciated, and has over 1700 Karma points.jrubio is appreciated, and has over 1700 Karma points.jrubio is appreciated, and has over 1700 Karma points.jrubio is appreciated, and has over 1700 Karma points.
Send a message via MSN to jrubio
Here is what I think, if I am wrong I will be pleased to know it.
-Ppk the procces is cronic none stable. (Minimum 100 parts)
-Cpk the process is stable. (MSA third edition page 7)
-Preliminary.
Short term.
According to MSA Do not included the effect of people, raw material, method, machine, gages, enviroment).
For new process or revised proccess
3-5 parts > 20 subgroup = 100 parts (According to Ford Design Institute. Page 5 Control Process Course)
and According to PPAP Thied Edition (Sorry but I am not in Automobile Arena).
Need to produce a minimum of 300 parts produced minimum 1 hour to 8 hours.( Page 2) for these 300 parts need to select (according to PPAP thierd Editiion Page 6) Minimum 25 subgrops with total amount of 100 readings of a significant production batch. These samples could be changed to long term if Customer request.
Long term.
According to PPAP
included the effect of people, raw material, method, machine, gages, enviroment). Minimum 100 parts splited during some change in our process.
Therefore with that info I consider that minimum 100 parts.
Therefore 100 parts is the number minimum to calculate the capability.
Best Regards from Cádiz Spain (Europe).
Javier Rubio Barragán.
Higher Industrial Engineer and Safety Master
Old 20th June 2006, 02:38 PM
Jim Wynne's Avatar
Courtesy Access
Karma Power: 611
You are correct with regard to AIAG requirements, but I think the question pertains to a statistical justification for a minimum number.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Minumim number of parts to conduct the Process Capability Study Eduardo APQP and PPAP 18 22nd December 2004 05:17 PM
Machine Capability Studies: How many parts needed? Dawn SPC Monitoring and Statistical Analysis Techniques 11 21st March 2001 02:17 PM
Capability Study for Level 3 PPAP - They are asking for a 100 peice capability study 1236 Paul APQP and PPAP 4 11th August 2000 04:48 PM
Capability Studies - 5 different dimensions - How many parts? Dawn SPC Monitoring and Statistical Analysis Techniques 6 8th March 2000 03:31 PM
Capability Studies - Combining parts from two lots Dawn SPC Monitoring and Statistical Analysis Techniques 17 24th November 1999 01:09 AM
The time now is 06:12 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
