Go Back   The Elsmar Cove Forum > Elsmar Cove Forum Essentials > Instructions --> How to use the Forum Software
Elsmar Cove Forum Visitor Notices
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 10th May 2007, 08:47 PM
BradM's Avatar
BradM BradM is offline
Registration Date: Sep 2006
Thanks Given to Others: 814
Karma Power: 274
BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.
BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.
I Say... Posting - Putting Thread or Post links within posts
Originally Posted by Marc View Post
Let's say you're posting and want to make it easy for someone to find information on quality manuals. You can form a search query as a link within the post:
Code:
<url=http://Elsmar.com/Forums/search.php?do=process&titleonly=1&query=quality+manual>Quality Manuals</url>
NOTE: In this example I used < and > instead of [ and ] because even in the 'code' box' the string will appear as a clickable link like this: Quality Manuals instead of your being able to see th code - In this example I am searching for the two words 'quality' and 'manual' and I'm limiting the search to thread titles only.
Is there a way to put a title on a link to a particular thread or to a post? Instead of the poster seeing this big long thread with numbers/letters/etc., is there a way to title it as :supplier evaluation 1, supplier evaluation 2, etc.
If I understand correctly, your example above is in relation to a search, and not necessarily with results found.
For example, is there a way to clean up this link to an post I made with two links?
http://elsmar.com/Forums/showpost.ph...43&postcount=2
Brad
My idea of housework is to sweep the room with a glance.
Sponsored Links
Old 11th May 2007, 01:09 AM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Default Re: Putting Thread or Post links within posts
Yes. You can make a link with a 'title', if that's what you're asking.
Using the 'Link' button in editing boxes is the first thing.
You should get a 'Requester' box like this:
Fill in the URL:
and click OK. You'll get a link. I looked at your example and there's a lot of 'garbage' I see which you probably don't because it appears you are using the full WYSIWYG editor. That puts in a bunch of 'extra' information such as font sizes and colors, etc.
The bottom line is you want words to show rather than just a url. When a link is made, in the 'raw' it looks like this:
Code:
<url="http://Elsmar.com/Forums/showpost.php?p=146042&postcount=10">http://Elsmar.com/Forums/showpost.php?p=146042&postcount=10</url>
NOTE: In this example I used < and > instead of [ and ] because even in the 'code' box' the string will appear as a clickable link.
Note that there is the link and the link is repeated between <url=.....> and </url>. That is the place to put the text you want.
That said, I use the 'standard' editor so I'll see things you don't using WYSIWYG.
Give me a bit and I'll look at this using the WYSIWYG editor to try to see what you see. As I said, the WYSIWYG editor will not show you all the code like the 'standard' editor does.
Thanks to Marc for your informative Post and/or Attachment!
Sponsored Links
Old 11th May 2007, 01:36 AM
Marc's Avatar
Karma Power: 605
When using the WYSIWYG editor, if you look at the 'link' in the WYSIWYG editor:
If you highlight a link:
You can type or paste the text you want to show:
Highlight the next link:
and type in what you want to show:
Note that the first link is in bold. If you would look in the 'standard' editor, you'll see for some reason the WYSIWYG editor put in the code for bold. I'm not sure why.
One of the nice things about vBulletin these days is the WYSIWYG editor. But - it's a very difficult aspect of software like this. It ends up putting in a lot of extraneous code for a number of reasons. I am not saying it shouldn't be used, just that I use the standard editor because I want the control over the code.
You CANB switch back and forth between editing modes to see what is there by clicking on the 'switch editor mode' button:
Old 11th May 2007, 09:18 AM
Miner's Avatar
Miner Miner is offline
Registration Date: Apr 2002
Thanks Given to Others: 166
Karma Power: 251
Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.
I just type the text that I want to appear as the link, highlight it, click the hyperlink button that you showed, paste in the URL and close it. A lot less work.
"A fool can learn from his own experiences; the wise learn from the experience of others." - Democritus, 460-370 B.C.
Thank You to Miner for your informative Post and/or Attachment!
Old 11th May 2007, 10:52 AM
Marc's Avatar
Karma Power: 605
Ah! You're using the WYSIWYG interface, correct? I never use that editor and didn't know it worked that way! Thanks for the tip!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Posting - Putting 'Search' links within posts Marc Instructions --> How to use the Forum Software 20 13th November 2007 08:59 AM
Searches in Posts - Putting 'Search' links within posts Marc Instructions --> How to use the Forum Software 20 13th November 2007 08:59 AM
Links in Posts - Post Counts and Active Links in Posts Houxapa Elsmar Cove Forum TOS and Forum Policies 8 2nd November 2007 11:33 AM
Posting - Quoting one or more Posts in a Reply in a Thread - Working with 'Quotes' Wes Bucey Instructions --> How to use the Forum Software 3 9th July 2005 11:15 AM
Posting - Putting tables in posts Govind Instructions --> How to use the Forum Software 5 22nd May 2004 06:39 PM
The time now is 12:17 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
