16th May 2007, 11:32 PM
Registered Visitor
Registration Date: May 2006
Thanks Given to Others: 1
Karma Power: 18 Karma: 90
Process Maps identified as inadequate during registrar's Document audit
During the 1st day of our iso cert audit the auditor wrote up a minor for a weak process map for lack of inputs/outputs. This is my first go at being part of a certification process but worked under qs for many years and admit it is weak. What I am wondering is why were we not given a minor on this during the document audit (off site) during that portion of the audit ? When I asked the auditor this she said they do not go that far into the documents during that part of it
16th May 2007, 11:42 PM
Registration Date: Sep 2006
Thanks Given to Others: 814
Karma Power: 274
Re: Document audit
Hello, there! I'm wondering if you might have typed a wrong word somewhere.. Did you get a MAJOR, but thought it should be a MINOR?
Here's my frail line of thinking... If the process map is weak, then maybe the associated procedures might be weak. Certain areas not addressed correctly, others not covered at all, etc.
However... my line of thinking is irrelevant. There should be clear evidence cited by the auditor why this creates significant risk, deficiencies, ineffective system, etc. in your process. Was there any verbiage to the effect?
Brad
My idea of housework is to sweep the room with a glance.
16th May 2007, 11:48 PM
Karma Power: 274
Re: Document audit
Interesting... there's another thread going right now regarding process maps:
Examples of process mapping
Don't know if it would be of any interest to you.
Brad
17th May 2007, 03:22 AM
Consultant / Auditor
Registration Date: Feb 2006
Thanks Given to Others: 599
Karma Power: 174
Re: Process Maps not identified as inadequate during registrar's Document audit
Hard to say without seeing the docs and knowing the background, but a documentation review is usually just intended to establish whether there is a documented system that appears capable of being audited. It's a lot to ask someone to also establish how valid or robust the processes are as well - iot's usually only when they see the actual system itself that they can see. I've had doc reviews come back with an auditor say it looks weak, then change their mind at the actual audit.
Regards, Jane
Intelligent quality: practical, simple & flexible
17th May 2007, 06:00 AM
aka Colin
Registration Date: Oct 2006
Thanks Given to Others: 91
Karma Power: 77
Hmm, I think it is a bit unsatisfactory if the auditor at doc review looked at the process map and did not comment at the time. After all, you are paying for him/her to comment on the suitability of the documented system to meet the requirements of the standard.
I do agree with Jane, it is not really possible to tell how suitable the process map will be in practice but that is not what I understand you to be saying here.
If you think training is expensive, try ignorance
17th May 2007, 07:56 AM
Registered Visitor
She did say it will be wrote up as a minor because there is no clear link ( on the PM) between processes. Unfortunetly we were forced by the powers to be to do a rush job of switching our QS system to ISO and it shows in some areas. I do agree with her that it's weak and will not contest the minor but as Colpart said I find it unsatisfactory that it was not even mentioned during the doc audit.The links are there and I would have had time to make the changes.
17th May 2007, 08:52 AM
Registration Date: Feb 2005
Thanks Given to Others: 1,784
Karma Power: 297
QCman:
I believe that the emphasis of the Stage 1 (since we're talking 'TS' here) is a 'readiness' review, to determine if the organization has a system in place, has been operating it getting some sort of results and the scope is correct - yada, yada......more registrar preparation (aka 'CYA') than a robust review of documentation.
I'm therefore not surprised that someone will comment later on simple stuff like this. It's frustrating because the whole idea of the 'automotive approach' is to ensure consistency......
Of course, there will always be personal bias (oops, preferences) of auditors, and it seems like this is one of hers!
'Cause you know sometimes words have two meanings.....
Reason: spellink
17th May 2007, 08:58 AM
aka Colin
Karma Power: 77
Unlikely scenario I know but what would happen if the auditor missed something significant at doc review and then found that it caused a Major during the certification audit? It would reflect very badly on the auditor and presumably, an appeal could be made by the organisation.
Thanks to Colpart for your informative Post and/or Attachment!
