7th June 2007, 05:51 AM
Involved in Discussions
Registration Date: Jun 2007
Thanks Given to Others: 24
Karma Power: 12 Karma: 29
What do you mean by Karma Power?
Dear admintrator of this forum
I'm new here , what do you mean by Karma power ?
7th June 2007, 06:07 AM
QA Systems Coordinator
Registration Date: Apr 2006
Thanks Given to Others: 327
Karma Power: 73
Re: Karma Power ?
I think you will find all the answers you are looking for in the list at the bottom of the page
Beetle Bailey Rules!
7th June 2007, 06:15 AM
Forum Administrator
Registration Date: May 2000
Thanks Given to Others: 246
Karma Power: 213
Re: Karma Power ?
As Gert said, there are a few threads on the subject. I think Karma - How do I get karma? How does Karma work? is the most recently updated one.
Basically, Karma is awarded by other users when they find your posts helpful.
/Claes
Thanks to Claes Gefvenberg for your informative Post and/or Attachment!
7th June 2007, 08:21 AM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,896
Karma Power: 605
Re: Karma Power ?
I didn't see the exact post off hand, but the Karma Points number is different than the Karma Power number. Karma Points number is not on each post (you do see representative green dots), but you can see your exact/actual number (rather than the green dots) in your UserCP (User Control Panel).
Your 'Karma Power' is how many points you give a person when you give them 'Karma' via the Karma button  . If you use the Karma button you can also leave a comment for the person you're giving Karma to.
Using the "Thanks" button also gives 5 Karma Points but does not affect Karma Power. *Disconnected link by consensus.
For some other information, see the vBulletin manual.
vBulletin now calls it 'Reputation', but it started out being called 'Karma'.
Reason: See revision history after 080728
Thanks to Marc for your informative Post and/or Attachment!
29th November 2007, 12:54 PM
Involuted - Posts
Registration Date: Sep 2007
Thanks Given to Others: 10
Karma Power: 10 Karma: 67
Re: Karma Power ?
I understand the points made above, I have tried reading the other threads but I am still confused. My user CP says I have 57 points but I only have one green box on each post - how many points does one green box represent?
So Karma power is how many points I can give a person, in my case 1? How does this get increased?
29th November 2007, 02:51 PM
Karma Power: 605
Re: Karma Power ?
The green boxes are the Karma points you have. There are 11 'green dots' and there are light green and dark green. The best I can tell you is these are the settings here right now.
NOTE: Giving 'Negative' Karma (Reputation) is locked out - And if you see a Gray box the user has chosen not to make his/her Karma public (changeable in each user's UserCP).
