Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
16th June 2007, 12:15 AM
E-Mails Invalid or Rejected by Recipient System
Registration Date: Mar 2002
Thanks Given to Others: 2
Karma Power: 0 Karma: 10
PFMEA (Process FMEA) issue about lower RPN - AIAG 3rd edition page 55
Hi, I have a question about FMEA manual(AIAG, 3rd edition), in P55, as following
"To reduce the probability of occurrence, process and/or
design revisions are required. An action-oriented study
of the process using statistical methods could be implemented
with an ongoing feedback of information to the
appropriate operations for continuous improvement and
defect prevention.
• Only a design and/or process revision can bring about a
reduction in the severity ranking."
1. Can somebody explain why "design" and "process" in different sequence to lower "S" and "O"?
2. Can only "process revision" lower "S"? I have heard from somebody, said no.
16th June 2007, 12:49 AM
$ Contributor
Registration Date: Feb 2001
Thanks Given to Others: 80
Karma Power: 217
Re: PFMEA issue about lower RPN
In Reply to Parent Post by LI Yan
defect prevention.
1) I think the easiest explanation comes by way of looking at the process of packing a parachute. The severity assigned to a parachute failure to open would be 10 because failure would result in some one's death. The only way to change the severity would be to redesign the parachute so it wouldn't matter if it didn't open. Nothing you do in your packing process will effect the severity. You can, by improving the process, lower the number of times the chute is packed wrong. This would reduce the "O" (occurrence) RPN. Detection ("D") can also be improved in your packing process and reduce the RPN.
2) I don't like to say "only" but in most cases the severity ("S") has to be reduced through re-design of the product, not the process. I suppose it is possible for a process revision to lower the severity RPN but I sure can't think of an example.
I hope this addresses your question.
Dave
"Time you enjoyed wasting is not wasted time"
16th June 2007, 01:38 AM
Re: PFMEA (Process FMEA) issue about lower RPN - AIAG 3rd edition page 55
Thank Dave's quick answer. I also cannot imagine what examples can demonstrate a process revision can lower severity. But the reference manual mentions "Only a design and/or process revision can bring about a
reduction in the severity ranking." . That mearns both design and process revision could reduce S alone, not MUST be coperated to use?
I also want clearify a Engilish grammar:
Can expression "A and/ or B" disassemble to "A+B" or "A alone" or "B alone"?
16th June 2007, 01:48 AM
Registration Date: Sep 2005
Thanks Given to Others: 1,406
Karma Power: 662
Yes, you are right.
Thanks to harry for your informative Post and/or Attachment!
16th June 2007, 01:59 AM
This question puzzle me several years. Years ago, I attended a training presented by a TS training company (so well known ) the trainer explained this grammar like this: "A and/or B" = "A+B"; or "A alone". Has any body know it?
16th June 2007, 02:37 AM
For this case, "only Design and /or process revision can lower S" means "design and process revision can lower S" or "only design revision can lower S", but process revision cannot lower S. If so, very reasonable!
But precondition(grammar) is not correct, right?
16th June 2007, 10:55 AM
Email Address Invalid or Rejected by Recipient System
Registration Date: Jul 2002
Thanks Given to Others: 15
Karma Power: 0
I think we may be getting hung up on the Failure Mode being Product related. In that case, I agree that the "only" way to reduce the Severity ranking is through a design change.
If the Failure Mode is Process related (a parameter of some sort), then it seems a change made to the process could reduce the ranking. For instance: if my process has a high severity for hold time in the machine and I performed a DOE which showed I could change a less critical parameter which would lessen the impact of hold time, I would then reduce the severity ranking for that Failure Mode.
Does that help any????
Reason: Added: I don't want to lead astray -- The Severity is addressed to the EFFECT of the Failure Mode.
Thanks to Bill Ryan - 2007 for your informative Post and/or Attachment!
17th June 2007, 12:02 AM
Maybe you are right. But still I cannot got whole picture of your example. I also think you maybe lowered the ocurence ranking, not severity ranking. Your detailed example will be appreciated.
Forum Posting Settings
