Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 19011 and ALL Auditing Discussions > Internal Auditing
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 14th December 1998, 05:13 AM
Lyndon Diong
Unregistered Guest
Posts: n/a
Default Scheduling internal audits
4.17 "IQA shall be scheduled on the basis of the status and importance of the activity ..." Chrysler-specific req't says the IQA shall be conducted at least once per year. I intented to do the IQA once a year. Hence I did an audit on all elements and all departments in my company. A second party auditor commented that I failed for "... scheduled on the basis of the status and importance of the activity..." How should I resolve this?
Q2: Every two weeks, a Quality Engineer will audit the production. E.g. check on SPC, housekeeping, process parameters etc. Can I classify this as internal quality audit?
Sponsored Links
Old 14th December 1998, 08:36 AM
Kevin Mader's Avatar
Kevin Mader Kevin Mader is offline
One of THE Original Covers!
Registration Date: Nov 1998
Thanks Given to Others: 22
Karma Power: 94
Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.
Send a message via AIM to Kevin Mader
Default
Lyndon,
How did you prioritize areas, elements, etc.? You treated all the elements and departments with equal importance. This may be true enough, but you may need to adjust to meet Customer expectations. Otherwise, it seems a small point to make a large fuss over.
Sponsored Links
Old 14th December 1998, 08:47 AM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Default
The bottom line is that for QS you have to have 1 round of internal audits every year, as I understand it. ISO is more lenient.
Old 14th December 1998, 08:58 PM
Lyndon Diong
Unregistered Guest
Posts: n/a
Default
Thanks for the reply. If the audit is once a year and not all the elements are audited, that will mean that some elements will not be audited every year. I have also come across auditors who require all elements to be audited and on all dept, including Adiminstration and Facilities, at least once a year.
Old 14th December 1998, 09:31 PM
Marc's Avatar
Karma Power: 605
Default
That's what I meant to say by 1 round of audits a year - a complete audit (all areas/elements).
Old 15th December 1998, 08:43 AM
Karma Power: 94
Default
Keep in mind that one audit in areas that have a history of being troublesome may not be enough (status - troublesome). In these areas you will need to schedule follow-up audits to ensure compliance. Overall, as Marc has said, you need to do the collective whole in a year's time.
Old 18th December 1998, 08:57 AM
barb butrym barb butrym is online now
Courtesy Access
Registration Date: Dec 1998
Karma Power: 63
barb butrym is appreciated, and has over 100 Karma points.barb butrym is appreciated, and has over 100 Karma points.
Default
Alot depends on how you worded your procedure....they are correct on the requirement, but if you procedures say something additional then thats whats audited. Most say yearly as a minimun and may be adjusted re: as 'importance, status or criticality issues' dictate..so covers both requirements of the standard. On a generic report cover, you can put a check box for a schedule adjustment needed beacuse of xxx. So there is a record if it ever needs to happen. Originally I thought that was an 'auditor friendly' addition to the record, but have found it quite useful.
Old 22nd April 2008, 12:46 AM
spacemanR spacemanR is offline
Registration Date: Apr 2008
Karma Power: 7
spacemanR has less than 100 Karma points so far.
Default Re: Scheduling internal audits
Lyndon,
my opinion for your reference.
at first,easy Q2. Q2,the activities of QE is part of production process audit ,more systemitical autir is better.
then difficult Q1.one complete audit one year is ok,but the audit time of individual process should be allocated based on the improtanctance and performance of perocess.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Scheduling Internal Audits - What should I be auditing and when Amanda H Internal Auditing 8 27th December 2005 11:20 AM
Scheduling Internal Audits - What is meant by 'based on status and importance'? Fire Girl Internal Auditing 29 1st April 2004 08:52 AM
Internal audits on CSR (Customer Specific Requirements) - Look at Ford's Behemoth ADVENTURE Internal Auditing 1 17th June 2003 04:42 PM
Scheduling Internal Audits - Has ISO 9001:2000 changed how you schedule your audits? M Greenaway Internal Auditing 14 18th July 2002 08:22 AM
Scheduling Internal Audits: Status and Importance of the Activity Andrews Internal Auditing 4 15th January 2002 12:59 PM
The time now is 11:57 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
