Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Documentation Control Systems, Procedures, Forms and Templates
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 18th February 1999, 09:09 PM
QMRICH56
Unregistered Guest
Posts: n/a
Question Do we need to have the documents on the shop floor stamped "VALID" ?
Do we need to have the documents on the shop floor stamped "VALID" ? The documents have the Issue Date in the header and reflect the date listed on the "List of Valid Documents" sheet. and do we need to have the "List of valid documents" on the shop floor also?
Rich
Sponsored Links
Old 19th February 1999, 05:12 PM
Marc's Avatar
Marc Marc is online now
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Default
You would only have to stamp the documents If Your Procedure Say So.
Sponsored Links
Old 23rd February 1999, 10:35 PM
Don Winton's Avatar
Don Winton Don Winton is offline
dWizard
Registration Date: Nov 1998
Karma Power: 63
Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.
Default
Agreed. Document control does not require that the documents be stamped (VALID or otherwise), only identified (ISO).
Regards,
Don
Old 24th February 1999, 12:48 AM
Russ Jackson Russ Jackson is offline
Involved in Discussions
Registration Date: Jul 1997
Karma Power: 51
Russ Jackson has less than 100 Karma points so far.
Default
Apparently you call you master list of documents "List of Valid Documents" and this list appropriately identifies the current (and valid) documents which should be in use.
There is no need to stamp the documents VALID simply because you use the term in you master list unless, as Mark and Don have pointed out, that you state in your document control procedures that they should be stamped.
As to the second question, there is no requirement for having the master "List of Valid Documents" available on the floor unless you require by procedure that document users check to ensure that their procedures match the issue on the master list. If your document control practices are working correctly then you should have good assurance that the users always have the latest valid issue in hand. If your document control practices are not working correctly the problem will be detected in your internal audits and you can initiate corrective action. But, bottom line, do not implement a practice of stamping the documents to show validity unless you have the requirement specified in a procedure OR it is absolutely necessary in your work environment to ensure that document control requirements are being met.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Severity of Finding for "Past Due Gage" found on the shop floor jdyaker ISO 17025 - Calibration, Measurement Gages and Test Laboratories 40 21st February 2008 05:16 AM
Gage Supplier - Need a 72" (min) Digital Read Out LLM for the Shop Floor qcman ISO 17025 - Calibration, Measurement Gages and Test Laboratories 2 1st September 2006 01:46 PM
"Shop-Floor Work Instruction" – How important they are? dmytry Manufacturing and Related Processes 10 14th February 2006 09:01 PM
Back-up "Emergency" procedures - Process to release shop prints to the floor michelle8075 ISO 9001 - Quality Management Systems Standard 11 8th April 2005 02:46 AM
Controlled Documents - How many copies can be stamped "Controlled Document"? roadrunner5_2000 Documentation Control Systems, Procedures, Forms and Templates 11 27th April 2000 05:54 PM
The time now is 11:59 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
