--> Subject: ISO
--> Date: Fri, 09 Jul 1999 08:19:22 -0500
--> From: Mike Van Heck
--> To: Marc
--> I just finished reading your advise that I found on the internet
--> under ISO/QS9000 Home Brew Implement. I just wanted to say that I
--> find your advise helpful.
--> I am implementing ISO 9000 at Nuvar. Most of my knowledge has been
--> gained from a lead auditor course given by Perry Johnson. I work for
--> a small 60 plus employee company called Nuvar Mfg. located in
--> Holland, Michigan. We do contract assembly work for the major office
--> furniture manufacturers. I have just started to document the
--> procedures our procedures. I might add that everyone of our
--> procedures have a flow chart.
I commend you. Keep with the flow charts.
--> My problems come to haunt me because of the fact that I try to over
--> document the system. Knowing this I have probably not done a thoural
--> job at meeting every shall.
This becomes an interpretation issue. Some
Shall's may not apply to you. As you get better at understanding and interpreting ISO9001 you will feel more comfortable.
Consider training instead of documentation. See
http://Elsmar.com/level2/accolades.html#document where he says:
"Especially important, at least in my opinion, was your help in determining where we did not need to document every last thing."
--> I just appointed two people inside of
--> the company to audit every section of the manual including both
--> procedures and work instructions. I am hoping that they will
--> recognize nonconformances and recommend changes or additional
--> procedures needed.
The problem here is that you are now asking several employees to understand ISO9001 so that they can say what procedures you need. You indicate you still have much to learn about ISO9001. I don't believe in this approach, but I admit I have used it and it has worked OK a couple of times. It can be a real fight, however, and I'm not convinced it's value added.
-->Do you have any advise on what these auditors
--> should be looking for?
Different prople set up internal audits in different ways. My personal opinion is that internal audits should be entirely based upon verifying and validating internal systems and related procedures, etc. Many companies use internal audits to verify ISO9001 compliance which requires your internal auditors to have a reasonable understanding of ISO9001. Ask your self how long you have been working with ISO9001 and then ask yourself how well you feel you understand it all. How long will it take your auditors to 'learn' ISO9001 adequately to make interpretations? Do they have the time to spend on this? One auditor quits and you have to train another one. One auditor just doesn't work out and you have to find another one and again train.
--> I have had an offer from a consultant to do internal auditor
--> training. Is this necessary and at what type of cost should I be
--> looking at? The estimated cost is $1500.00 for five people. This to
--> me seems quite pricey.
--> Once again thanks for your advise through your internet article.
Well, an internal auditor course on site is going to be expensive. I do an ISO 2 day and a QS 3 day and I charge US$1250 for the first day and US$850 per day each day after (plus US$60 a student for book and such. With all costs it comes to about US$2200 to US$2500 for a 2 day. I may be high, but for me it's a matter of what I feel is reasonable for my 'expertise' and time. If I'm 'low on work', I might bid cheaper. I charge for my time and the location, not the number of students - 5 or 25 souls, the base fees are the same. You could consider sending them out to a course.
My personal advice is to out-source internal audits for a company your size. If you don't I predict you will wish you did. Let your employees do what you hired them to do, rather than try to turn them into auditors with a 2 day wonder 'Internal Auditor' course.
[This message has been edited by Marc Smith (edited 16 July 2001).]
