Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 19011 and ALL Auditing Discussions > Internal Auditing
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 8th October 1999, 02:28 AM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Bomb! Internal Audit Findings and the Registrar
Subject: Re: Internal Audit Findings and the Registrar /Maroney-Benassi/Naish
Date: Tue, 28 Sep 1999 15:54:20 -0600
From: ISO Standards Discussion <JENNEJOHNN@UWSTOUT.EDU>
Subject: RE: Internal Audit Findings and the Registrar /Maroney-Benassi/Naish
Patricia,
My experience with the auditors from the registrar include the following:
1) They check to make sure the audits are adequately documented.
A. Are the forms completed as per the procedure.
B. Does the record include both comforming and non conforming audits.
C. Can you see independence of the auditor from the area being audited.
D. Is there an adequate description of any discrepancies either on the audit form or a corrective action form.
2) They check to see if you are following your schedule or plan within the criteria you set for doing so.
A. If you say you do all sections in a year in all areas of the company can you show you have tracked all sections and all areas.
B. If you say you have to o the audit within a given month are you doing them within a given month.
C. If you say managers are given X notice can you show the managers were notified in advance.
3) Are the audits effective.
A. If they see obvious non conformaces or discrepancies they want to see if the internal audits 1: looked at that area of the company and 2: Did the auditor(s) see what the registrar is seeing. I had one auditor make an observation that the audits were not effective since there were a number of minor non conformances he observed and the audits performed the previous two months for the same areas did not identify the discrepancies.
B. They have asked if the ISO Rep thought there were enough audits being performed to fully evaluate the whole system in some of the larger companies who had only one audit per area in a one year period.
C. If there are checklists used, do the checklists cover all of the specific section(s) of the standard being audited for an area. In other words is the whole system really being evaluated in the audits or are some subsections of the standard or some group(s) of people being omitted that should be audited.
4) Are the auditors trained.
A. Do you have training records.
B. How much training do the auditors get.
C. Does at least part of the training include a review and understanding of the ISO standard.
Hope that helps you.
Phyllis
Sponsored Links
Old 8th October 1999, 02:35 AM
Marc's Avatar
Karma Power: 605
Lurker
Subject: Re: Internal Audit Findings and the Registrar/Maroney-Benassi/Kohn
Date: Thu, 30 Sep 1999 16:13:32 -0600
Subject: RE: Internal Audit Findings and the Registrar/Maroney-Benassi/Kohn
>From: "Maroney-Benassi, Patricia" -PMaroney@ora.fda.gov-
>ISO 9001:1994 section 4.17 requires procedures for internal audits and sets
>some specifications for the manner in which the audits are conducted and the
>records are used. Once an internal audit process is established and
>functioning, does the registrar generally review the actual audit findings?
Without a doubt. The third-party system is structured to allow only a very superficial audit vis a vis the size of the organization being audited. The reason why the system has integrity is because it is really a cross-check, a cross-check on the conclusions already reached through the internal audit process. The only way I, as a third-party auditor, can say that an organization is compliant, is based on the evidence presented to me by the client in that regard. I only audit them to make sure they're not fabricating internal audit, corrective action, management review and other critical records.
If the internal audit system says there's a problem, then there is a problem. For sure. Now, as a matter of practice, I often didn't cite minor nonconformances when they were apparently properly logged and being expediently worked through the internal audit system. Practically speaking, in the case of minor nonconformances, all that would happen is that the client would work the issue and then I'd have to spend time making sure they did so during my next visit. Since I must sample their internal audit findings for timely and effective corrective action anyway (during each visit), I need to be judicious in citing minor nonconformances of this sort; otherwise I'd be spending an inappropriate amount of surveillance time looking at internal audit and corrective action, and therefore an inadequate amount of time looking at the rest of the system.
Major nonconformances are another story, however. My typical follow-up would be in the short-term; i.e., a special visit within 2-3 months. That cannot nor should not be short-circuited based on any reliance on the client's internal audit and corrective action systems.
>If so, are they reviewing only to establish that the internal audit system
>functions (i.e. trace an observation through corrective action, resolution,
>and tie in to 4.1.3)? Or do they actually use the internal audit findings to
>measure the health of your quality system (i.e. find out what problems we've
>been having)?
It bears repeating: The third-party auditor is reviewing the internal audit system records primarily to see that you have assured that you are indeed in compliance.
- It is *NOT* to see where your problems are so they can focus in on those areas.
- It is not *only* to verify that the internal audit process itself has integrity (although that *is* one intent.)
Brian Charles Kohn
Sponsored Links
Old 8th October 1999, 02:49 AM
Marc's Avatar
Karma Power: 605
Lurker
Subject: Re: Internal Audit Find. and the Reg. /Maroney-Benassi/Pfrang
Date: Fri, 1 Oct 1999 13:59:14 -0600
Subject: RE: Internal Audit Find. and the Reg. /Maroney-Benassi/Pfrang
>From: "Maroney-Benassi, Patricia" <PMaroney@ora.fda.gov>
>Subject: Q: Internal Audit Findings and the Registrar /Maroney-Benassi
Yes, the registrar does generally review the actual audit findings. In fact, I know of one that does this as a routine part of every surveillance audit. They begin every surveillance audit with several administrative activities, one of which is a review of the findings of all internal audits performed since the previous surveillance audit.
>been having)?
Yes, the registrars review internal audit findings to establish that the internal audit system functions, and yes, they actually use the internal audit findings to measure the health of the quality system. For example, they will routinely follow-up any audit finding that occurs is in an area which they cover in their surveillance audit. They will also follow-up a random sampling of audit findings during their surveillance audit of the internal audit procedure, to confirm that the corrective action was taken and was effective.
>As a regulatory agency, we generally keep our nose out of a firm's internal
>audit findings so as not to "chill" their quality assurance efforts. We use
>complaint handling to measure the effectiveness of corrective action
>procedures. I was wondering if registrars take this same approach even
>though they have a customer/client relationship with a firm.
Yes, they use this approach as well, but much less often. Since they have access to internal audit findings, they can evaluate the corrective action procedure by simply reviewing the internal audit findings and ensuring that corrective action was taken; therefore, they do not need to rely on the other inputs to the corrective action procedure -- such as complaint handling -- to evaluate the corrective action procedure. Nevertheless, since complaint handling is another input to the corrective action procedure, they will occasionally confirm that it is also functioning, but only when the surveillance audit specifically covers the corrective action procedure.
-- Doug
Old 8th October 1999, 08:29 AM
barb butrym barb butrym is offline
Courtesy Access
Registration Date: Dec 1998
Karma Power: 63
barb butrym is appreciated, and has over 100 Karma points.barb butrym is appreciated, and has over 100 Karma points.
I Say...
Registrars I am familiar with audit customer complaints every visit...and some audit CA/PA and internal audits every visit. If those are working, its a good indication of how the rest of the system is working......
phyllis is right on....exactly what we look for.
Old 8th October 1999, 09:58 AM
Marc's Avatar
Karma Power: 605
Covering Ass
Pretty much the samd here, Barb.
Old 21st October 1999, 04:42 PM
David Guffey
Unregistered Guest
Posts: n/a
I have learned that an aggressive and effective internal audit process is a great tool during a third party audit.
If my internal audit system has cited a finding and if other findings and corrective actions have been effective and timely, my registrar has not cited.
If, however, an area was recently audited internally and a finding was not noted (even recognizing it might not have been there at the time), the registrar will write, and rightfully so.
Expect your internal audit to receive quite a review at the initial assessment and at every surveillance thereafter. If it's up-to-snuff, it will be well rewarded.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Internal Audit Findings - Do I need to raise NC for amendments/revisions? cmfugen ISO 9001 - Quality Management Systems Standard 5 21st September 2008 10:46 AM
Review on Internal Audit Findings eternal_atlas ISO 9001 - Quality Management Systems Standard 20 31st July 2008 11:10 AM
Format for Reporting Internal Audit Findings AndyN ISO 19011 and ALL Auditing Discussions 17 21st June 2007 07:51 PM
When and when not to write up minor internal audit findings? Rockanna Internal Auditing 23 20th February 2007 09:51 AM
Nonconformance reports written only through internal audit findings? JOHNatNRO Nonconformance and Corrective Action 8 19th January 2004 06:09 PM
The time now is 07:59 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
