Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - Calibration, Measurement Gages and Test Laboratories > Measurement Uncertainty (MU)
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 10th July 2007, 07:29 AM
amanbhai amanbhai is offline
Involved - Posts
Registration Date: Apr 2005
Thanks Given to Others: 56
Karma Power: 35
amanbhai is appreciated, and has over 100 Karma points.amanbhai is appreciated, and has over 100 Karma points.
Question Do we still need to Calculate Measurement Uncertainties (MU)?
I talked to one of the Lab experts who is also the assessor of ISO/IEC 17025:2005 & has more than 3 decades of experince.
One of the thing that he assert is that in some cases measurement uncertainty/ Precision (repeatability/ reproduceability) is given in the standard method so we don't need to re calculate it for those tests, he also asserts that this measurement uncertainty we can report to the customer & it is accepted by the accrdediation boards.
Do we still need to calculate the measurement uncertainties for tests & we can rely on this statements?
My question is important since sometime the repeatability/ reporoduceability can be differnt from the one stated in the standard test method.
Sponsored Links
Old 10th July 2007, 04:15 PM
Hershal's Avatar
Hershal Hershal is offline
Metrologist-Auditor
Registration Date: Mar 2004
Thanks Given to Others: 1
Karma Power: 186
Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.
Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.
Default Re: Do we still need to calculate measurement uncertainties?
In many cases this may be true, such as for the ASTM standards where a precision and bias statement is included. However, not all standards have such statements or equivalents and in those cases you very likely will need to calculate your uncertainty.
The best thing, if there is any doubt, is to calculate the uncertainty.....and to ask your chosen accrediting body, which I presume is SCC.
Sponsored Links
Old 10th July 2007, 05:08 PM
Benjamin28 Benjamin28 is offline
Tater Salad
Registration Date: Dec 2006
Thanks Given to Others: 89
Karma Power: 37
Benjamin28 is appreciated, and has over 900 Karma points.Benjamin28 is appreciated, and has over 900 Karma points.Benjamin28 is appreciated, and has over 900 Karma points.Benjamin28 is appreciated, and has over 900 Karma points.Benjamin28 is appreciated, and has over 900 Karma points.Benjamin28 is appreciated, and has over 900 Karma points.Benjamin28 is appreciated, and has over 900 Karma points.Benjamin28 is appreciated, and has over 900 Karma points.
I would echo Hershal on this topic. Many standard methods do not require calculating UOM if you follow the method to a t and will typically contain a statement to that effect. If you can get away without the added work of uncertainty calculations go for it. And if you're still doubtful, ask your AB.
Old 11th July 2007, 04:53 AM
Involved - Posts
Karma Power: 35
Read This! Re: Do we still need to calculate measurement uncertainties?
just to understand the logic since ...though uncertainties given in ASTM std but our repeatability & repeatability is different from the one that is given. Our analyst is diffrent & though our equipment is same as mentioned in the std but its accuracy & precision maybe different.
My question is logically how do we justify using the same MU as ASTM std refers?
Old 11th July 2007, 10:50 AM
Tater Salad
Karma Power: 37
I have to admit I was intrigued by the question at hand. As I work for a metals testing laboratory we apply the note within ISO 17025 and yet we certainly do not quote a numerical value for the MU:
In those cases where a well-recognized test method specifies limits to the values of the major sources of uncertainty of measurement and specifies the form of presentation of calculated results, the laboratory is considered to have satisfied this clause by following the test method and reporting instructions.
Interestingly enough this statement has been debated quite extensively...in particular is the question of whether a method can provide a numerical value for measurement uncertainty which can be quoted. You can read about some of this here...
http://www.astm.org/cgi-bin/SoftCart...store+jyuv9248
The more interesting statement I found within this debate is:
"A22.2 It is neither appropriate for, nor the responsibility of, the test method to provide explicit values that a user would quote as their estimate of uncertainty. Uncertainty values must be based on data generated by a laboratory reporting results using the test method.
So, to me that would seem to be an answer...but I would look for something more definite and official. If you research further please do post your findings here for the rest of us to read.
Old 11th July 2007, 02:24 PM
Ken K's Avatar
Ken K Ken K is offline
Registration Date: Jun 2000
Karma Power: 57
Ken K is appreciated, and has over 500 Karma points.Ken K is appreciated, and has over 500 Karma points.Ken K is appreciated, and has over 500 Karma points.Ken K is appreciated, and has over 500 Karma points.Ken K is appreciated, and has over 500 Karma points.Ken K is appreciated, and has over 500 Karma points.
We are also an L-A-B accredited test lab and we do not calculate measurement uncertainty for the majority of our testing.
What we chose to do is chart our properties in Excel and use action limits and warning limits. The action limits provide an estimate of uncertainty at approximately the 99.7% level of confidence and the warning limits provide approximately a 95% level of confidence. Our auditor has given this her blessing.
The A2LA Guide for the Estimation of Measurement Uncertainty in Testing is what we used to set this up. Is was written by Thomas M. Adams. You might want to take a look at this excellent guide.
Old 3rd August 2007, 09:40 AM
Involved - Posts
Karma Power: 35
but the question is, is it accpetable to the accreditation body?
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Temperature Measurement Uncertainties - Verify a PRT at 0°C specified ±0.02°C celon ISO 17025 - Calibration, Measurement Gages and Test Laboratories 4 12th November 2004 01:06 AM
Seeking: Company that can come on-site and calculate the uncertainties JaSoN_MVTS ISO 17025 - Calibration, Measurement Gages and Test Laboratories 8 18th August 2004 12:38 PM
Micrometer Uncertainty - Best Measurement Uncertainties for O.D. Micrometers Dave N-2007 ISO 17025 - Calibration, Measurement Gages and Test Laboratories 2 8th January 2003 11:52 AM
Starting to Calculate Uncertainties Debbie ISO 17025 - Calibration, Measurement Gages and Test Laboratories 1 6th June 2001 10:06 AM
How to simply calculate Measurement Uncertainty David Drue Stauffer Measurement Uncertainty (MU) 12 24th May 2001 05:28 PM
The time now is 11:53 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
