25th July 2007, 12:06 PM
Involved in Discussions
Registration Date: Jun 2007
Thanks Given to Others: 24
Karma Power: 15
Signatures - User Signatures in the forums - Limitations and Additions
The limit for signatures is two lines. On almost every post there is a line at the bottom of the post with additional words, probably from the author, below that. How do I add those catchy little quips and pieces of wisdom to my own posts?
--> Instruction Note Added by Marc: After a person here has about 10 posts, a 'signature' can be put in which shows at the bottom of each post the person makes. To put in a 'signature', go to your UserCP and look at the options in the left sidebar. One of them is labeled 'Edit Your Signature'.
Practical Solutions ... Plain English Training ... Get the Job Done Approach
Reason: 080925 - Note added.
25th July 2007, 12:23 PM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Re: Signature Additions
I'm not sure exactly what you're referring to, but I must ask you to take the 'advertisement' out of your signature.
Default setting is: Registered Visitors with at least 10 posts get 2 lines, and Moderators get 3. A few users have special privileges for various reasons.
The reason the number of lines is limited is I do not want to clutter up threads with posts with people having a large signature.
NOTE: You must have 10 posts in 'business' threads before you can put a personal Signature in your Profile which will show up in your posts.
Reason: Minor Revision - 080827
Thanks to Marc for your informative Post and/or Attachment!
25th July 2007, 12:24 PM
Courtesy Access
Registration Date: Jan 2005
Thanks Given to Others: 755
Karma Power: 612
I just did a quick audit of various posts and found only one-- Steve Prevette's --that contains more than two lines. I'm not sure how that happened (perhaps the two-line limit is newer that Steve's sig) but if you can't say what you need to say in two lines and 150 characters, it's probably too much information anyway.  Less is more, when it comes to signatures.
25th July 2007, 12:31 PM
Karma Power: 15
As quick as I posted my question I had the answer. The two lines I see on others posts IS their signature. I was stuck in a rut of signature having to be, you know, signature: name and so on.
I'm all set now - thanks.
25th July 2007, 12:34 PM
Karma Power: 15
Yep, got that taken care of also - my bad - didn't realize.
25th July 2007, 12:35 PM
Karma Power: 605
Steve may have had his set before the software settings for that aspect were there. There didn't used to be any control for the number of lines in a signature.
25th July 2007, 12:38 PM
Karma Power: 15
I just did a quick audit of various posts and found only one that contains more than two lines. I'm not sure how that happened
Oh, I never had any complaint with the two lines - that is enough. I just had my own mix-up going on. I could only envision signature as a name. After looking at several others I realized what people have done. They count on the Elsmar provided identification at the top of the posting then add their words of wisdom at the bottom.
All fixed - thanks for the help guys.
25th July 2007, 12:47 PM
Courtesy Access
Karma Power: 612
And Steve is also a moderator, and thus allowed three lines, as you said in your earlier post. I wasn't aware of that. Not being a moderator, I was seeing the two-line limit.
