Please Critique my process map - Metal-Mechanic Industry
Hi Everybody,
I need your help reviewing my process map, I will present this to Plant Manager for review and I want to make sure it covers ISO 9000 requirement.
Thanks for your help.
Anerol
Thank You to Anerol C for your informative Post and/or Attachment!
Re: Please Critique my process map - Metal-Mechanic Industry
In my opinion, a process map can’t cover all ISO9001 requirements, but every process should reflect appropriate parts of ISO requirements and all the processes together should cover all applicable ISO requirements.
Your process map is good for ISO 9001 system.
Thanks to darkafar for your informative Post and/or Attachment!
Originally Posted by Anerol C
Hi Everybody,
Anerol
Anerol,
We also have a model similar to the ISO 9001 Process Based in our Quality System Manual, but it does not clearly relate to the Core Processes identified in the rest of the manual. I only share that as a recommendation to watch for that synchronization.
The other thought I stumbled upon when reviewing your model is: why is it that the Management and Qualty Responsibilities are not two way like that of Resource Management and Monitoring & Measurement? Is it to say that 'Quality begins with Management?'
Hi Everybody,
Anerol
Hi Anerol,
I suggest you go through the Cove by using the SEARCH function. We have plenty of process maps in the cove.
I have no special talents. I am only passionately curious - Albert Einstein
Doug;
When I created I condisered that Management/Quality Manager gives direction on Quality assurance, but considering it again it should be two way as Quality Department informs Management about new customer requirements,Customer satisfaction, etc. I'll modify it.
Thanks; Anerol
