Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 19011 and ALL Auditing Discussions
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 17th April 2000, 05:07 PM
Don Watt
Unregistered Guest
Posts: n/a
Question Does an Audit Schedule have to be a Controlled Document?
Does an audit schedule have to be a controlled document?
e.g. at the start of the year I produce a schedule / plan of the internal audits expected to be conducted throughout the year.
As time progresses various revisions may be needed to include additional audits arising from quality problems or to re-arrange audits to allow for new requirements to be effectively introduced.
Does the initial plan need to be at revision level 1 and each amendment to plan included at an incremented revision level?
Sponsored Links
Old 17th April 2000, 05:38 PM
wpbudd
Unregistered Guest
Posts: n/a
Thumbs up
My audit schedule is controlled. However, the controlled part is the form number not the actual data. My work instruction states that updates may be necessary. Again, only the form in control not the information, since said information may change at a give time.
Sponsored Links
Old 17th April 2000, 10:41 PM
David Mullins's Avatar
David Mullins David Mullins is offline
Aussie Bloke
Registration Date: Nov 1999
Karma Power: 51
David Mullins has less than 100 Karma points so far.
Yin Yang
No the audit schedule does not have to be a controlled document.
The auditor may well expect a date on the schedule to signify the status/currency. They may also ask who gets the schedule.
How often is it updated.
The important thing is that the schedule complies with what your procedure says.
Cheers.
Old 12th May 2000, 07:07 AM
matthew evans matthew evans is offline
Registration Date: Mar 2000
Karma Power: 40
matthew evans has less than 100 Karma points so far.
Are you mad. Of course an audit plan is a controlled document. The point about the schedule being updated to include additional audits is covered by simply having a note at the bottom of the plan stating that additional audits can be carried out and a mark being put onto the audit plan. The blank audit schedule should have a form number and a revision status for the blank form only. The completed schedule only requires the year as an heading.
Old 27th May 2000, 01:36 AM
John C
Unregistered Guest
Posts: n/a
Matthew Evans,
The use of numbers and revisions is optional, being only the conventional, and not the only possible, method of control. When numbers and revs are used, they apply only to procedures and forms and will be applicable, of course, to the procedure which describes the planning and implementation of the internal audit. The actual schedule is not a procedure. It may be on a form but there is nothing in the Standard to say that it must be. Basically, a schedule (by definition) is only an ordered list - not necessarily a dated list. It can be on the back of a postcard for all that it matters, or it could be only a verbal agreement.
In fact, the second paragraph of 4.17 (the only mention of scheduling in the Standard) gives us leeway to initiate or postpone audits according to perceived need rather than use a dated list. (This relates to the flexibility to changes in circumstances mentioned by David and Lurker above) For example; I can imagine an organisation where the decision to hold, or not hold an internal audit, is made at Management Review, depending on the current situation and imminent events. This method might have become the conventional approach from the time the first edition of ISO 9001 was introduced, had most of us not already become bound by the chains of bureaucracy. There is nothing in the Standard to prevent this approach and it has a lot to commend it. It would align the implementation of ISO 9001 more closely with Deming, particularly regards items; 2,3,5 and 7 of his 14 Points For Management and conform to Shonberger’s advice to eliminate waste throughout the organisation.
In such a case, the minutes of the meeting, filed anyway as the quality record of Management Review, would provide both the schedule and the quality record of scheduling. (Note; the control of quality records is a different subject entirely)
Please don’t hesitate to call me mad, if that is what you think, but be sure to tell me where I’m wrong, and don’t let it be just your opinion; back it up with evidence from your experience and, most of all, evidence taken directly from ISO 9001 since that is the document under consideration and furthering of our understanding of compliance with that document is the object of these discussions. Whatever else we get from these discussions, we all want to learn.
Respectfully yours,
John C
Old 22nd June 2000, 05:27 AM
Claes Gefvenberg's Avatar
Claes Gefvenberg Claes Gefvenberg is offline
Forum Administrator
Registration Date: May 2000
Thanks Given to Others: 246
Karma Power: 213
Claes Gefvenberg is appreciated, and has over 1700 Karma points.
Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.
I would regard the schedule as a record.
We use an Access application to run our entire audit process. That includes reports, checklists and schedule as well as follow ups. Once a year we enter the audit schedule, print it out and sign it.
This application also sends the audit plan to our intranet. Any changes or additions to the plan is relayed to the intranet.
Our procedures refer to the application.
Claes Gefvenberg
[This message has been edited by Claes Gefvenberg (edited 22 June 2000).]
Old 22nd June 2000, 09:36 PM
Aussie Bloke
Karma Power: 51
Spin!
It's amazing what happens when you remove the blinkers and look at how the standard (any standard or system model for that matter) can be applied to best suit an organisation, and still be compliant. For those people who are establishing a new quality management system, I would say: don't make the hurdles too high from day one, make them achievable and then progressively improve the system, thus raising the bar.
I enjoy my open mind, my ability to conceptualize, and being just a little bit mad (well let's call it eccentric).
Cheers.
Old 24th June 2000, 06:15 PM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,894
Karma Power: 604
Yin Yang
Think INTENT in my opinion.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Controlled Document Definition - What constitutes a controlled document? shereenk Definitions, Acronyms, Abbreviations and Interpretations 9 29th April 2009 04:28 AM
The Optimal IA Schedule - How should the Internal Audit Schedule be set up? Pazuzu ISO 19011 and ALL Auditing Discussions 26 12th January 2008 01:02 PM
What is the difference between a controlled document and an uncontrolled document? johnkwt Documentation Control Systems, Procedures, Forms and Templates 10 7th February 2007 12:12 PM
Internal Audit Schedule Updates - Necessity of a revision date on the schedule Angela at SKF Internal Auditing 8 27th November 2006 04:20 PM
ISO/TS 16949 Audit Schedule - How to draw up an audit schedule hollyc ISO 19011 and ALL Auditing Discussions 3 4th April 2006 11:01 PM
The time now is 08:28 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
