Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 19011 and ALL Auditing Discussions > Internal Auditing
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 11th September 2000, 10:30 AM
Mark Smith
Unregistered Guest
Posts: n/a
Question Internal Audit Checklists - Using the standard itself replace any checklist
During a previous ISO surveillance audit a nonconformance was identified for the fact that the checklist for internal audits did not cover the requirements in enough depth.
As a corrective action I stopped using the checklist and changed the auditing procedure to require that the ISO 9001 standard itself replace any checklist so that each element is addressed where appropriate.
Last week I had another surveillance audit and the auditor wrote a non-conformance because there was no way for him to verify that I was auditing all applicable elements of the standard (the checklist used to offer this verifiable evidence). What are some possible solutions people might have?
This is a small (20 person) company and people are getting audited fairly regularly. I currently audit each department twice during the year. Would it be wiser to audit by element appropriate departments and personnel or continue to audit each department for all applicable elements?
Sponsored Links
Old 12th September 2000, 01:16 AM
Aaron Lupo's Avatar
Aaron Lupo Aaron Lupo is offline
QA-LA
Registration Date: Jan 2000
Thanks Given to Others: 5
Karma Power: 71
Aaron Lupo is appreciated, and has over 700 Karma points.Aaron Lupo is appreciated, and has over 700 Karma points.Aaron Lupo is appreciated, and has over 700 Karma points.Aaron Lupo is appreciated, and has over 700 Karma points.Aaron Lupo is appreciated, and has over 700 Karma points.Aaron Lupo is appreciated, and has over 700 Karma points.Aaron Lupo is appreciated, and has over 700 Karma points.
Bomb!
That is exactly how I do my audits. I break it down by Department, then I audit each Department to all the applicable elements. It shows on my audit schedule what elements have been audited. I think this should be able to allow you to eliminate the "checklist".
Sponsored Links
Old 12th September 2000, 05:55 AM
Claes Gefvenberg's Avatar
Claes Gefvenberg Claes Gefvenberg is offline
Forum Administrator
Registration Date: May 2000
Thanks Given to Others: 246
Karma Power: 213
Claes Gefvenberg is appreciated, and has over 1700 Karma points.
Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.
BIG Smile
I'd be very wary about not using a checklist when auditing. It's too good a tool...
Just like ISO GUY I usually audit by department, but I guess there is no right or wrong there.. It rather depends on the nature of your buissness and how it's set up.
I put a unique cheklist together for every audit by going from the standard ( to avoid missing any gaps ), to the Quality Manual and the written procedures and records. I also refer every single question to one or a number of std elements.
/Claes
Old 12th September 2000, 12:26 PM
Rick Goodson's Avatar
Rick Goodson Rick Goodson is offline
Registration Date: Aug 2000
Karma Power: 42
Rick Goodson has less than 100 Karma points so far.
You might consider a checklist that has a column for the ISO element reference, company procedure reference/requirement, and the method of audit (what you are going to do) in addition to the other boiler plate 'stuff' on the form. Typically when I teach internal auditing I want students to learn to reference to the ISO element first, the company documentation second. This will more closely replicate what the third party will do.
Old 8th October 2000, 05:04 PM
Jim Triller
Unregistered Guest
Posts: n/a
Mark,
A tool I have succesfully used has been an audit plan - a one page sheet that defines when & what locations/areas are going to be audited and what elements are to be covered. Senior management approves the plan and it is retained as a quality record. The audit report reiterates what was covered in the audit (per the plan) and lists any nonconformances to the ISO standard and/or the organization's procedures. This approach has worked well at seven companies I assisted in the registration process.
Old 12th October 2000, 02:26 PM
Al Dyer
Unregistered Guest
Posts: n/a
I also lead the internal audits for our company. We have broken the audit process down to two functions, product and process.
Process audits are verification of effectiveness to the elements of QS-9000. We had a checklist that was determined to be non-compliant so I requested that our auditor give us a copy of the checklists he used to audit us. He did and now there are no questions as to the validity of the checksheets.
Product audits are scheduled to determine the effectiveness of individual work stations. These checksheets cover all work station requirements as stated in procedures. In addition to the checksheet, all cell personnel are monitored using applicable control charts and instructions as guides. This type of product audit has proven very effective as it really gets cell personnel aware and involved. It also keeps the auditor happy when we show the review of these audits during management review.
ASD...
Old 18th October 2000, 03:48 PM
Gary Manion
Unregistered Guest
Posts: n/a
Question
Stuck between a Registrar and a Consultant.
A few months ago during a surveillance audit we had a finding stating "Some audits do not audit the entire element," with a few examples as evidence. The Auditor wrote it was “due to an inadequate checklist” and that we did not audit the entire element to the standard.
The checklist I am using came from a registrar (not the one we are using). It covers ISO-9000, QS-9000 and AS9000. I was using this as a starting point and would generate additional questions based on our written system on a separate work sheet. After further reviewing the checklist item by item to all three standards I verified it is verbatim of all three. (It is easy to determine which item is ISO, QS or AS since one is Normal text, one Bold and the other Italics.)
Today I just talked to our consultant (QMS-LA) who has been involved in ISO/AS for some time and he said the role of the Internal Auditor is to audit the system (Manual, Procedures and Work Instructions including product etc…) only, not to see if the system meets the standard. He said that it is Management’s responsibility as part of Management Review to make sure that the system meets the standard. He said it is the registrars job also since they do the doc review and assessment audit, meaning they already said our written system meets the standard less any changes that may have been made of course.
What are your thoughts?
I would like to hear your opinions.
Old 18th October 2000, 04:10 PM
Alf Gulford Alf Gulford is offline
An Early Cover
Karma Power: 40
Alf Gulford has less than 100 Karma points so far.
I Say...
Gary-
IMHO - I think that's right, but only in theory.
The reality that I see is that we have to make the decisions about conformance, investigate possibilities, suggest paths to take, write procedures and train people. This may not be in our job description (although it's usually there as 'other duties as required') but that's the only way it gets done.
I hear a few stories about management being 'wildly enthusiastic' about ISO, or compliance teams, but mostly it's just us.
No big deal. Just an observation about my job.
Alf
[This message has been edited by Alf Gulford (edited 18 October 2000).]
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Internal Audit schedule & Process Audit Checklists JohnSy Internal Auditing 3 5th February 2009 01:00 PM
ISO 13485 Practical Internal Audit Checklist - Standard vs. Process Based ISO MAN Internal Auditing 17 6th November 2008 09:41 AM
Supplier audit checklists for special processes - Plating Process audit Checklist E0029626 Process Audits and Layered Process Audits 2 13th June 2005 11:57 PM
Question about ISO 9001 Registrar Audit Checklist - No more checklists? Donald Duck ISO 19011 and ALL Auditing Discussions 9 19th January 2004 09:57 AM
APQP Checklists - Process Flow Chart Checklist, PFMEA Checklist, Floor Plan Checklist JeanMichel APQP and PPAP 11 10th March 2003 11:06 AM
The time now is 06:08 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
