Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Inspection and Test, Sampling and Related Topics > AQL - Acceptable Quality Level
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 23rd August 2007, 09:51 PM
plastic gal plastic gal is offline
Registration Date: Aug 2005
Thanks Given to Others: 1
Karma Power: 18
plastic gal has less than 100 Karma points so far.
Please Help! Sanity Check on AQLs (Acceptable Quality Level)
It has been a long time since I have used attributes sampling and I want to see if I still can interpret the table. If I choose an AQL and keep the Ac = 0 & Re = 1 fixed (in other words don't allow any rejects) and the arrow points down to where say the Ac = 1 and Re = 2, do I have to use the sample size associate with the later Ac/Re # (which is a larger sample)? I believe that I do and just keep the Ac = 0 and Re = 1. I am not a big fan of attributes sampling but it is a customer requirement.
Am I way off-base?
Thanks........................
Sponsored Links
Old 24th August 2007, 10:52 AM
Geoff Withnell's Avatar
Geoff Withnell Geoff Withnell is offline
Involved in Discussions
Registration Date: Jul 2007
Thanks Given to Others: 2
Karma Power: 34
Geoff Withnell is appreciated, and has over 900 Karma points.Geoff Withnell is appreciated, and has over 900 Karma points.Geoff Withnell is appreciated, and has over 900 Karma points.Geoff Withnell is appreciated, and has over 900 Karma points.Geoff Withnell is appreciated, and has over 900 Karma points.Geoff Withnell is appreciated, and has over 900 Karma points.Geoff Withnell is appreciated, and has over 900 Karma points.Geoff Withnell is appreciated, and has over 900 Karma points.
Default Re: Sanity Check on AQLs (Acceptable Quality Level)
Am I way off-base?
plastic gal,
If you follow the process as you describe, you will actually be checking to a lower AQL then the one you chose. If you prefer c=0 plans (I do for a number of reasons), may I recommend
"Zero Acceptance Number Sampling Plans", Fourth Edition
Squeglia, Nicholas L.
It is available from ASQ Bookstore, and probably Amazon, and has c=0 tables equivalent to the ANSI or MIL 105 tables you are probably using.
I have used it with good customer acceptance and good results.
Geoff Withnell
Thanks to Geoff Withnell for your informative Post and/or Attachment!
Sponsored Links
Old 24th August 2007, 09:47 PM
Karma Power: 18
Thanks so much for the reply. That is what I figured and it is nice to have the confirmation as such. I have also used the c = 0 plan in past lives.
So what I am hearing you say is that you must follow the arrows to the larger sample size no matter what. In this case it is for a destructive test for rockwell hardness (have to remove oxide layer) so I don't want a huge sample but too risky to have rejected product.
Thanks again - if there is anything else you can share it is much appreciated. Dr. Deming said that acceptance sampling guarantees that the customer will receive defective product which is possible with any sampling that is not SPC based with a large Cpk.
Pamela
Old 25th August 2007, 07:52 PM
Statistical Steven's Avatar
Statistical Steven Statistical Steven is offline
Consultant
Registration Date: May 2005
Thanks Given to Others: 36
Karma Power: 43
Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.
Send a message via Yahoo to Statistical Steven
Pamela
Are you required to use the Z1.4 standard? If not, you can use the binomial directly and calculate the AQL and LTPD for ANY sample size and Ac/Re number. I find this method to be superior to the standard since it gives smaller sample sizes and gives me BOTH the consumer and producer risks which should be stated for ANY sampling plan.
Steven Walfish
When in doubt, ask your company statistician!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Problem with AQL (Acceptable Quality Level) damienbechaux AQL - Acceptable Quality Level 9 5th August 2009 07:04 PM
AQL - How do I find Acceptable Quality Level? qmslady AQL - Acceptable Quality Level 72 8th June 2009 05:07 PM
AQL - Acceptable (Assured) Quality Level Marc Definitions, Acronyms, Abbreviations and Interpretations 0 29th December 2005 02:44 AM
SPC for calibration check data? Daily gram scales check - What is acceptable? Craig H. SPC Monitoring and Statistical Analysis Techniques 5 30th August 2004 09:20 AM
Acceptable Outgoing Quality Level (AOQL) aka Acceptable Outgoing Quality (AOQ) Randy Feliciano SPC Monitoring and Statistical Analysis Techniques 6 17th February 2004 06:30 AM
The time now is 01:24 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
