Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Inspection and Test, Sampling and Related Topics > AQL - Acceptable Quality Level
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 31st August 2007, 03:41 PM
Pudge 72's Avatar
Pudge 72 Pudge 72 is offline
Involved in Discussions
Registration Date: Mar 2007
Thanks Given to Others: 45
Karma Power: 15
Pudge 72 is appreciated, and has over 100 Karma points.Pudge 72 is appreciated, and has over 100 Karma points.
Please Help! AQL and Sampling Plan as they relate to Functional In-Process Inspections
OK Cove.
Throughout my career I have always been weak in the area of Sampling Plans and AQL levels as they relate to functional In-Process inspections whether it is the operator checking the part or as a QC function.
So, here goes the question. Has anyone created or does anyone have a good plan in Excel or Word for determining the amount of pieces to be inspected on an hourly basis as would be required per a Control Plan for production parts? Or, a document that explains a good methodology for the selection of # of pieces and time that would be acceptable to a customer?
IE - I check a feature on a part that is a length let's say. This Length is listed as a Feature that is Inspected on the Control Plan, but, it is not a customer critical. I inspect 5 pcs. per hour. I do not do CPK on this feature as it is more of a "preventive" inspection so that I can see a drift during the run to assist with an adjustment if necessary.
On this part, I have let's say 5 or 6 of these types of features to inspect and I am measuring 5 pcs. per hour.
I do 5 pcs. per hour because that is what I have always done and it seems to be economical whether it is the operator or QC - seems to be effective. But, what is the real or better way to arrive at the amount of pieces or time frame in the beginning of the project? I can't change the IP based on rolling data because it is submitted with my Control Plan - it needs to be developed on the Front end.
Any Ideas guys?? I hate the norm and never thought that this method was quite right.
Sponsored Links
Old 31st August 2007, 04:08 PM
Jim Wynne's Avatar
Jim Wynne Jim Wynne is online now
Courtesy Access
Registration Date: Jan 2005
Thanks Given to Others: 755
Karma Power: 611
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Default Re: AQL, Sampling Plan
Originally Posted by Pudge 72 View Post
OK Cove.
Use of a sampling plan with an associated AQL or OPerating Characteristic Curve is usually done with finished lots of material, as in the case of final or incoming inspection. Determining sampling quantities and intervals for in-process checks is a little like setting calibration intervals. You do it based on experience and history. You should monitor closely in the beginning (what "closely" means will vary with the processes involved) and then gradually expand the interval until you're reasonably sure nothing bad is happening between inspections. The goal of these checks should be process control--knowing how to control the variables that can affect product quality.
Thanks to Jim Wynne for your informative Post and/or Attachment!
Sponsored Links
Old 31st August 2007, 04:24 PM
Pudge 72's Avatar
Karma Power: 15
Default Re: AQL and Sampling Plan as they relate to Functional In-Process Inspections
Excellent.
This is exactly the type of feedback I am looking for.
I agree with you completely Jim. The philosophy you suggest is along my lines of thinking - but, based on my expierience, it will be hard to implement as it almost falls into QE territory whereas you base the inspection interval on historical data - the problem falls in where someone has to analyze all of that not to mention that it has to run for a while to gather this data.
So, while it could be said that in the end you will have a cost savings based on eliminating unecessary inspection, you will spend a lot to get to that point.
That is kind of my ultimate dilemma, in this day and age of listening to how much QC (by the operator or direct QC) is a non-value added activity, we don't seem to have good definitions in place for analyzing In-Process data to arrive at these points and eliminate the waste during production which is where the rubber meets the road - not Final inspection.
Old 31st August 2007, 04:29 PM
Jim Wynne's Avatar
Courtesy Access
Karma Power: 611
That's exactly what statistics is for.
Old 31st August 2007, 05:13 PM
Pudge 72's Avatar
Karma Power: 15
I know, but I am sure that you feel my pain when I try and explain and justify someone analyzing data - even if it is for improvement. Just wondering if you or anyone else had a better method right out of development - IE - CPK of 1.75 = 3 pcs. per hour for In-Process Inspection instead of 5 based on a certain lot size or something. I am not sure, I know how to apply the statistics on the historical data, but to change all of the paperwork for sampling sizes is a pain - probably trying to take a lazy way out that is really not there.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Sampling Plan - AQL effect on sample size BigEd09 Inspection and Test, Sampling and Related Topics 7 22nd June 2009 05:47 AM
AQL - Does AQL relate to the Six Sigma capability of my supplier? ivan99 AQL - Acceptable Quality Level 7 23rd August 2007 09:30 AM
What is the confidence level for a given AQL in zero sampling plan Yew Jin Inspection and Test, Sampling and Related Topics 4 10th August 2007 05:07 AM
Setting AQL (Acceptable Quality Level) on C=Zero inspections Norman V AQL - Acceptable Quality Level 16 6th December 2006 10:41 AM
AQL and RQL Calculation for Variables Sampling Plan WLN AQL - Acceptable Quality Level 8 7th November 2001 04:08 PM
The time now is 08:38 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
