Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Quality Tools, Improvement and Analysis > Quality Assurance and Compliance Software Tools / Solutions > Using Minitab Software
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 10th September 2007, 02:51 AM
Yew Jin's Avatar
Yew Jin Yew Jin is offline
Involved - Posts
Registration Date: Aug 2006
Thanks Given to Others: 23
Karma Power: 29
Yew Jin is appreciated, and has over 500 Karma points.Yew Jin is appreciated, and has over 500 Karma points.Yew Jin is appreciated, and has over 500 Karma points.Yew Jin is appreciated, and has over 500 Karma points.Yew Jin is appreciated, and has over 500 Karma points.Yew Jin is appreciated, and has over 500 Karma points.
Let Me Help You Perform 2 ways ANOVA in minitab with non normal data involved
Hi guys,
One of the assumptions is the data must in the normal distribution before study in ANOVA. I have a case that the intend to compare the 2 samples which 1 of the sample is in the non normal distribution.
We may use Johnson or Box Cox trasformation to change the non normal to normal set of data. But the question is how we want to use the transformation data in the sample versus the other set of original data which in normal distribution in this case for this study?
____________________________________________
failing to plan is planning to fail ~ Joseph Juran
Sponsored Links
Old 10th September 2007, 03:01 AM
shailendrasingh shailendrasingh is offline
Registered Visitor
Thanks Given to Others: 7
Karma Power: 14
shailendrasingh has less than 100 Karma points so far.
Default Re: Perform 2 ways ANOVA in minitab with non normal data involved
Transform the non normal data using Box Cox transformation. Using the same lambda value convert the normal data set. This conversion will not affect the distribution of your normal data set,and then perform ANOVA using transformed data.
Other option is to perform nonparametric test equivalent to ANOVA i.e Kruskal Wallis test.This test is performed when any one of the data sets is not normal or if both sets are not normal.
Sponsored Links
Old 10th September 2007, 03:07 AM
Yew Jin's Avatar
Involved - Posts
Karma Power: 29
But when we have the data which in the negative that we can't use the box cox, right?
Any other alternative beside we use the non normal method in this case?
Old 10th September 2007, 03:37 AM
Registered Visitor
Karma Power: 14
Ahaan !!
Well we cant use Box Cox when data are negative.
A usual method of dealing with raw data where many of the values are less than 1 is to add an arbitrary constant to the entire data set and then transform; in this way we avoid dealing with negative numbers.
Old 9th January 2008, 05:30 AM
Allattar Allattar is offline
Involved in Discussions
Registration Date: Jan 2008
Thanks Given to Others: 4
Karma Power: 19
Allattar is appreciated, and has over 500 Karma points.Allattar is appreciated, and has over 500 Karma points.Allattar is appreciated, and has over 500 Karma points.Allattar is appreciated, and has over 500 Karma points.Allattar is appreciated, and has over 500 Karma points.Allattar is appreciated, and has over 500 Karma points.
I have to ask about the data structure.
Is the data expected not to be normally distributed?
Is the data in each group normally distributed.
You probably realise this already, but just to confirm, the original data in an ANOVA does not need to be normally distributed, but the residual error should be. Well roughly normal at least.
An example of this could be
Line Shift
1 A
1 A
1 B
1 B
2 A
2 A
etc...
The criteria is that the results from each group, ie: line 1 shift A, line 1 shift B, line 2 shift A, line 2 Shift B, they would be normally distributed. But if you add all the results together in one column, they need not be normally distributed.
Lets say all combinations of line and shift have the same average and the same standard deviation, and are normally distributed, except line 1 shift B. Line 1 Shift B has an average muich higher than the other groups, it will make the data not normally distributed.
Apologies if you know this already, it is a common mistake, and one I have to explain often.
If you know the results from each combination are not expected to be normally distributed, ie: you are trying to analyse the standard deviation, which follows and exponential distribution. Then we can either transform the data, or run as suggested the Kruskal Wallis test, which is a test of medians, rather than means.
I wouldnt worry too much either if the residuals are not perfectly normal.
Old 26th June 2008, 08:24 AM
Miner's Avatar
Miner Miner is offline
Registration Date: Apr 2002
Thanks Given to Others: 166
Karma Power: 251
Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.
Moved latest post by Poilofesse regarding Range/ANOVA methods of MSA to MSA forum.
"A fool can learn from his own experiences; the wise learn from the experience of others." - Democritus, 460-370 B.C.
Reply
Bookmarks
Tags
2 way anova, anova, minitab, non-normal distribution, statistical analysis, statistics
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Gage R&R or Anova two way? Using Minitab ed1978 Using Minitab Software 1 14th October 2009 08:23 PM
Non-Normal Data - Transforming the Data to Normal Jon O SPC Monitoring and Statistical Analysis Techniques 12 11th March 2007 11:14 PM
How does Minitab handle outliers in ANOVA? bernchan Using Minitab Software 3 25th April 2006 12:37 PM
MINITAB and non-normal unilateral tolerance data - Cannot confirm Ppk values VMax! Using Minitab Software 15 29th November 2005 04:16 PM
Capability Analysis - Dealing with non-normal data in Minitab alokb Using Minitab Software 2 26th November 2005 08:50 AM
The time now is 08:37 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
