Whatever suits you best. I sometimes attach it to the procedure so people have a choice which one they use. Other times I throw the procedure away and just use the process map. As long as the information is easily available it is your choice - try asking the users which they prefer.
__________________ If you think training is expensive, try ignorance
Colin is absolutely correct. How and where you locate documents is your choice. Whatever method works best for your employees. The standard requires "control of documents." How you do that is your decision. Keep the needs of your internal customers in mind.
Yes, the decision is yours but if you do not keep them together your people may choose which one they use, whereas you may prefer them to use both. They should be complementary or else maybe one of them is redundant.
