Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Inspection and Test, Sampling and Related Topics > AQL - Acceptable Quality Level
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 14th October 2007, 11:33 PM
Caster's Avatar
Caster Caster is offline
An Early Cover
Registration Date: Jul 2003
Thanks Given to Others: 193
Karma Power: 104
Caster is appreciated, and has over 1700 Karma points.
Question Capability Study Required as a Condition to Adopt a Sampling Plan?
Now here is an odd situation.
For years we have done a capability study, and submitted that as part of a package to our Big 3 customer to allow us to adopt a sampling plan.
I get a lot of flak for suggesting that the one does not need the other.
The rationale for this is lost in the mists of history. It seems to have been, first prove you're capable then we'll let you go to sampling.
As far as I know, a capbility study is not a prerequisite for sampling. Any plan can be selected (and it will of course have risk) <as will SPC>.
Any thoughts?
Sponsored Links
Old 15th October 2007, 08:03 AM
e006823 e006823 is offline
Involved in Discussions
Registration Date: Nov 2003
Thanks Given to Others: 2
Karma Power: 33
e006823 is appreciated, and has over 300 Karma points.e006823 is appreciated, and has over 300 Karma points.e006823 is appreciated, and has over 300 Karma points.e006823 is appreciated, and has over 300 Karma points.
Default Re: Capability Study Required as a Condition to Adopt a Sampling Plan?
I believe the capability study would help you select an appropriate sampling plan, see: http://www.variation.com/techlib/as-7.html
Regards,
Sponsored Links
Old 15th October 2007, 09:54 AM
Geoff Withnell's Avatar
Geoff Withnell Geoff Withnell is offline
Registration Date: Jul 2007
Karma Power: 34
Geoff Withnell is appreciated, and has over 900 Karma points.Geoff Withnell is appreciated, and has over 900 Karma points.Geoff Withnell is appreciated, and has over 900 Karma points.Geoff Withnell is appreciated, and has over 900 Karma points.Geoff Withnell is appreciated, and has over 900 Karma points.Geoff Withnell is appreciated, and has over 900 Karma points.Geoff Withnell is appreciated, and has over 900 Karma points.Geoff Withnell is appreciated, and has over 900 Karma points.
Any thoughts?
Caster,
The connection is fairly straightforward. It is not the function of sampling in a capable process to detect defects! In a capable process, the function of sampling is to verify (obviously with some degree of risk) that the process remains capable. Given that the process remains capable, the level of defects will, by the very definition of capable, remain acceptably low. If the process is already known to be not capable, then we do not need to sample to detect the level of defects, we already know from the process incapability that the level of defects is probably unacceptably high. Sampling is inappropriate, and we must therefore take other measures, such as 100% inspection, to reduce the level of defects.
You can see this idea in Z1.4, which requires the halt of sampling if tightened inspection continues too long, since this indicates the capability of the process is degraded.
Geoff Withnell
Old 16th October 2007, 11:06 PM
Caster's Avatar
An Early Cover
Karma Power: 104
Geoff Withnell & e006823
OK, thanks to you both. I think I have it now.
The cap study is to determine what kind of defect level the process is operating at.
From that, I can then pick a sample plan with an AQL that makes sense for the process defect level.
Caster
Old 17th October 2007, 09:31 AM
Bev D's Avatar
Bev D Bev D is offline
Registration Date: Jan 2003
Thanks Given to Others: 265
Karma Power: 137
Bev D is appreciated, and has over 1700 Karma points.
Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.
Capability is not necessary for sampling plans to work - this is a myth.
Sampling plans are based on the probability of detection given any defect rate. The stability - or capability - of the process has nothing to do with the probability of a sample detecting a specified level of defects. The random selection of the samples and the definition of the "lot" from which one is sampling do affect the effectiveness of the sampling plan.
The 'need' for a capability study prior to implementing a sampling plan is a belief of the Customer or regulatory agency that if the process is incapable or unstable, then they are better protected from receiving defects if you use 100% inspection/testing rather than a sample plan (no sample plan is 100% effective in detecting defects). So if your process is incapable (known to produce defects) or unstable (could prodcue defects at any time) then you should use 100% inspection/testing. If it is stable AND capable (yes - I know you cant' truly be capable if you aren't stable but many people forget this) then you can institute a sample plan at final acceptance...at least that's the theory...
This is a result of the "zero defects" philosophy as opposed the "acceptable defect rate" philosophy that the Mil Std plans were originally developed for.
Old 17th October 2007, 10:03 AM
Karma Power: 34
It is equally a myth that the Mil Std plans were originally developed for an "acceptable defect rate". The AQL is NOT permission to ship defective product. It is a convenient label for how much sampling inspection is warrented based on the consequences of not discovering a negative shift in quality. If you read the entire standard, it fairly clear the intent of MIL-STD-105 and its successor standards is not so much to accept/reject specific lots (although it obviously does that) as to detect a negative change in the process quality.
Geoff Withnell
Thanks to Geoff Withnell for your informative Post and/or Attachment!
Old 17th October 2007, 08:23 PM
Caster's Avatar
An Early Cover
Karma Power: 104
Sampling plans are based on the probability of detection given any defect rate. The stability - or capability - of the process has nothing to do with the probability of a sample detecting a specified level of defects. The random selection of the samples and the definition of the "lot" from which one is sampling do affect the effectiveness of the sampling plan..
This is more like the answer I was fishing for.
As I understand sampling, the OC curve tells me the producer and consumer risks for any given defect level in a lot. All in all done.
I did however like the idea of doing a cap study to understand my process defect rate and then selecting a sampling plan based on that. Very elegant.
In this case I think you are correct, the customer is looking for 100% protection from sampling so has come up with this mixed marriage of related cousins.
Cheers
Caster
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Customized sampling plan - Acceptance sampling plan for the raw materials newuser123 Inspection and Test, Sampling and Related Topics 2 20th May 2009 01:43 PM
Process Capability for a specification with Maximum Material Condition (MMC) Chennaiite SPC Monitoring and Statistical Analysis Techniques 4 1st April 2009 04:50 PM
Capability Studies - Fewest Number of Parts for a Capability Study ivo Capability, Accuracy and Stability - Process, Machine, etc. 9 20th June 2006 04:25 PM
Capability Study for Level 3 PPAP - They are asking for a 100 peice capability study 1236 Paul APQP and PPAP 4 11th August 2000 04:48 PM
Capability Study - Feasible? Capability Study when there is No Set Target Value precabcorp SPC Monitoring and Statistical Analysis Techniques 2 27th February 2000 11:08 PM
The time now is 04:13 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
