Go Back   The Elsmar Cove Forum > Manufacturing, Service, and Business Systems Processes > Process Maps, Process Mapping and Turtle Diagrams
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 19th October 2007, 10:18 AM
jappel jappel is offline
Registration Date: Oct 2007
Thanks Given to Others: 2
Karma Power: 9
jappel has less than 100 Karma points so far.
Please Help! Main Map and Major Process Maps or Turtle Diagrams
I know we all make different components, and we will have specific procedures and work instructions to run our business. But, I would think that the overall map and the major process maps would be pretty similar, as far as what the overall flow is and what are the major processes.
Does anyone have an overall plant process map, and maps or turtles of what they consider major processes for an automotive company that they would be willing to share?
Sponsored Links
Old 19th October 2007, 10:21 AM
Stijloor's Avatar
Stijloor Stijloor is offline
Cross Forum Moderator
Registration Date: May 2003
Thanks Given to Others: 1,315
Karma Power: 377
Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.
Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.
Default Re: Main map and major process maps or turtles
Hello Jappel,
Welcome to The Cove!
Start here: (Turtles and Maps).
Stijloor.
Thanks to Stijloor for your informative Post and/or Attachment!
Sponsored Links
Old 19th October 2007, 12:04 PM
AndyN's Avatar
AndyN AndyN is offline
Registration Date: Feb 2005
Thanks Given to Others: 1,784
Karma Power: 297
AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.
AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.
Caution Re: Main map and major process maps or turtles
Jappel:
I would strongly recommend that you use process maps to document your system. I'd also strongly suggest that using someone else's is not a good place to start. Even if, and it's a BIG if, another company made similar things to you, the point of you defining your sequence and interaction of processes, is that your management should see it the same way.
Believe me, you will run into problems later if you just take a 'silver bullet' to this aspect of defining a quality management system. It will come back to haunt you later, either during the registration audit, or when the system starts to cause the customer problems.
One aspect of this is that if your management team create their version of the process map(s) it will be a lot easier to have them be able to talk to it during the audit and, therefore, demonstrate 'management commitment'. If you don't, I'll wager they all look at you and you'll end up defending it.
On the subject of turtles, you should use them with caution. As a way of 'seeing' where your existing documents 'fit' as controls to the process etc. they are great, but to get the most benefit, like reducing waste (your management will probably like that idea) use maps instead (I don't mean 'flowcharts') to show the non-value added areas. This will also make continual improvement easier to identify, too
'Cause you know sometimes words have two meanings.....
Thanks to AndyN for your informative Post and/or Attachment!
Old 19th October 2007, 12:56 PM
Karma Power: 9
Default Re: Main Map and Major Process Maps or Turtle Diagrams
Thanks to both responses. I will review the existing samples to help me understand the process of making the process maps better, but keep them from other management. I understand how critical it is to create and understand your own system.
Thanks to jappel for your informative Post and/or Attachment!
Old 2nd November 2007, 07:19 AM
Monypennyuk Monypennyuk is offline
Involved in Discussions
Registration Date: Oct 2004
Thanks Given to Others: 3
Karma Power: 21
Monypennyuk has less than 100 Karma points so far.
Wow, thanks so much for that link
So useful as i need to map out all our processes, and i had nothing to compare with...
Old 2nd November 2007, 07:21 AM
Stijloor's Avatar
Karma Power: 377
Originally Posted by AndyN View Post
Jappel:
An example can be very helpful. I did not recommend "copy."
Stijloor.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Process Analysis - What do process indicators mean in the turtle diagrams? sweetmeg Process Maps, Process Mapping and Turtle Diagrams 8 23rd June 2009 03:38 AM
Guidance on using Turtle Diagrams for Internal Audits (main & sub processes) annelien Process Maps, Process Mapping and Turtle Diagrams 5 30th June 2008 03:50 PM
Manufacturing Process Audits (TS16949) - are Turtle diagrams really helpful? Pradeep Ravipati ISO/TS 16949 - International Automotive Quality Systems Standard 4 31st October 2007 10:24 PM
Business process map - Please Review my Process Map and Turtle Diagram phomer Process Maps, Process Mapping and Turtle Diagrams 31 16th July 2007 10:35 PM
Turtle Diagrams - I am looking for examples of Completed Turtle Diagrams Reggie Process Maps, Process Mapping and Turtle Diagrams 14 15th November 2006 01:47 AM
The time now is 04:52 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
