Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - Calibration, Measurement Gages and Test Laboratories > Measurement Uncertainty (MU)
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 25th October 2007, 07:31 PM
Backscatter's Avatar
Backscatter Backscatter is offline
Registration Date: Oct 2007
Thanks Given to Others: 5
Karma Power: 9
Backscatter has less than 100 Karma points so far.
Question ISO 17025 MU Requirements - Construction Material Testing Lab Uncertainty Budgets
Greetings
I have several questions relating to ISO 17025, and specifically uncertainty budgets for construction material testing laboratories.
Any help in resolving these questions or forwarding links to the answers would be greatly appreciated.
This query relates to ISO 17025, section 5, clauses relating to MU (measurement uncertainty).
As a CMT lab performing tests using A.S.T.M. methods and complying with note 2 of clause 5.4.6.2, do the other clauses relating to uncertainty (specifically 5.4.6.1, 5.4.6.2, and 5.4.6.3) apply?
We do not develop test methods or calibration procedures (all critical test equipment is calibrated by a 17025 accredited calibration facility).
Does compliance with note 2 in clause 5.4.6.2 eliminate the need for compliance with the main body of clause 5.4.6.2?
Is it the determination of ISO that there is a requirement for procedures to be developed and proof of the ability to perform uncertainty budgets (MU) if the facility in question complies with note 2 (section 5.4.6.2), and as stated clause 5.4.6.1 & 5.4.6.3 are not applicable to our facility?
Also do the notes in 17025 (specifically the above referenced note 2 of section 5.4.6.2) have the same "authority" as the clause themselves?
Any help in resolving these questions would be appreciated.
Last edited by Backscatter; 25th October 2007 at 07:34 PM. Reason: typo, grammatical
Sponsored Links
Old 25th October 2007, 08:47 PM
AndyN's Avatar
AndyN AndyN is offline
Registration Date: Feb 2005
Thanks Given to Others: 1,786
Karma Power: 297
AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.
AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.
Let Me Help You Re: ISO 17025 MU Requirements - Construction Material Testing Lab Uncertainty Budgets
Backscatter:
If I understand your question(s) correctly, your lab can use (for example) any uncertainty estimations contained in the test methods, where these are available. If you don't perform any calibrations then the lab doesn't have to comply with that requirement - in this case, 5.4.6.1.
By employing the uncertainty estimation methods/results which are embodied in the test method, is the way in which you comply with 5.4.6.2 - the note is an explanation of that specific circumstance you're in.
The notes are simply clarification and guidance, so have no 'authority' in terms of requirements. This so for most ISO standards.
It seems fairly simple to me, but I hope it is for you too........
'Cause you know sometimes words have two meanings.....
Thanks to AndyN for your informative Post and/or Attachment!
Sponsored Links
Old 25th October 2007, 09:03 PM
harry harry is offline
Registration Date: Sep 2005
Thanks Given to Others: 571
Karma Power: 231
harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.
harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.
Default Re: ISO 17025 MU Requirements - Construction Material Testing Lab Uncertainty Budgets
I hope this old file is still useful for you.
Welcome Backscatter. Puget sound reminds me of Tacoma Bridge and my students days doing some lab work on construction materials.
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
File Type: pdf measurement uncertainty - construction materials.pdf (215.8 KB, 97 views)
Thank You to harry for your informative Post and/or Attachment!
Old 26th October 2007, 05:12 PM
Karma Power: 9
Thank you andyn and harry, I appreciate your responses (and the link).
My understanding and interpretation of 17025 for CMT labs MU requirements would indicate no requirement to perform uncert. budgets (with the paramiters already stated).
I am being asked to prove the capability to perform budgets, so if a client asks for it we can provide one. We perform tests using ASTM methods, and have critical test equipment calibrated by an accredited (MRA) 17025 calibration facility.
I can find no such requirement in 17025 to prove the capability, when clause
5.4.6.2 (note 2) is satisfied, and budgets are NOT even an issue with our clients.
Again, test methods and calibration procedures are not developed, and test procedures are ASTM test methods.
I am just trying to find my way through this situation, and throwing this out for possible solutions and discussion, and to see if others have run into this situation.
P.S.
harry
tried to link the webcam shots of the new Narrows bridge for you, but alas I'm still a newbie here (less than 5 posts).
Old 26th October 2007, 05:49 PM
Stijloor's Avatar
Stijloor Stijloor is online now
Cross Forum Moderator
Registration Date: May 2003
Thanks Given to Others: 1,316
Karma Power: 377
Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.
Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.
Originally Posted by Backscatter View Post
P.S.
harry
Hi Backscatter,
Is this the correct link?
Stijloor.
Thanks to Stijloor for your informative Post and/or Attachment!
Old 26th October 2007, 06:32 PM
AndyN's Avatar
Karma Power: 297
Thumbs up Re: ISO 17025 MU Requirements - Construction Material Testing Lab Uncertainty Budgets
Interesting! I think it's fairly realistic that someone in the lab can demonstrate some competencies when it comes to uncertainty, just as part of doing normal lab 'business'.
P.S glad to be of assistance!
Old 26th October 2007, 06:57 PM
Karma Power: 9
Stijloor, I was able to send link in email, though I appreciate the assist.
Old 26th October 2007, 07:28 PM
Stijloor's Avatar
Karma Power: 377
Thanks! Glad to lend a hand....
Stijloor.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Measurement Uncertainty (MU) - Genetic Testing Lab - Lack of suitable CRM - ISO 17025 jane lai Measurement Uncertainty (MU) 6 8th July 2009 04:46 PM
% Uncertainty Budgets - Auditor wants to see my uncertainty budget represented as a % luluthecat Measurement Uncertainty (MU) 5 20th July 2005 07:19 PM
Looking for my testing Lab to be accredited under iso 17025 - Definitions Pimi_petty ISO 17025 - Calibration, Measurement Gages and Test Laboratories 5 18th October 2004 02:36 PM
Construction Materials Testing Lab 17025 Templates matayus ISO 17025 - Calibration, Measurement Gages and Test Laboratories 4 15th July 2003 02:41 PM
Looking for an accredited 17025 lab to do heat age testing on automotive fabrics Sam ISO 17025 - Calibration, Measurement Gages and Test Laboratories 3 14th November 2001 01:52 PM
The time now is 12:20 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
