The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > Manufacturing, Service, and Business Systems Processes > Reliability Analysis - Predictions, Testing and Standards
Forum Username
Elsmar Cove Forum Sidebar
Custom Search
Monitor the Elsmar Forum
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Sponsored Links
Courtesy Quick Links
Howard's
Atul's
Symphony Technologies
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Related Topic Tags
cnc machining, en 754-3, visual inspection, cnc (computer numerically controlled), automatic test equipment (ate), measurement techniques and procedures, measurement (general)
Reply
Old 6th November 2007, 04:12 AM
pigeon pigeon is offline
Registered Visitor
Registration Date: Aug 2005
Thanks Given to Others: 4
Karma Power: 33
pigeon has less than 100 Karma points so far.
Please Help! How to Measure Straightness of Small Bars or Tubes (Long Length)
Can anyone give some advise how to measure straightness on small bars or tubes?
The bars range from diameter 10 - 20 mm (0.394" - 0.625") and a length of app. 3660 mm (12').
We have to guarantee straightness of 1 mm / m on the full length. These bars are machined by our customers in automated CNC machines.
According to the standards (for example EN 754-3) we have to place the bars on a table in such manner that the weight of the bar reduces the deviation in the straightness (this means placing the bend in the bar upwards on the table). In this position we have to measure the height of the remaining bend (should be less than 3.66 mm).
At this time we only use a visual inspection by the operators while packaging, but this is not acceptable for some customers. We would prefer an inline automated or semi-automated measuring device.
Next week we will do a test to manually measure the straightness on a table of some visually rejected bars. I'm quite sure that some of the visually rejected bars will turn out to be within specification if we actually measure according to the standard (because the weight will reduce the bend).
What methods or devices are used by machine shops to measure straightness on long length of small bars?
Sponsored Links
Old 6th November 2007, 04:17 AM
Stijloor's Avatar
Stijloor Stijloor is offline
Cross Forum Moderator
Registration Date: May 2003
Thanks Given to Others: 2,952
Karma Power: 1431
Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.
Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.
Re: how to measure straightness on small bars or tubes (long length)
In Reply to Parent Post by pigeon View Post
What is the material of the tubes/bars?
Stijloor.
Sponsored Links
Old 6th November 2007, 04:26 AM
Registered Visitor
Karma Power: 33
In Reply to Parent Post by Stijloor View Post
Stijloor.
Material is aluminum.
Old 6th November 2007, 06:03 AM
Stijloor's Avatar
Karma Power: 1431
Re: How to measure straightness of small bars or tubes (long length)
A search revealed a description of a newly invented device.....
Stijloor.
Thanks to Stijloor for your informative Post and/or Attachment!
Old 6th November 2007, 10:02 AM
Crash Not Crash Not is offline
Registered Visitor
Registration Date: Aug 2006
Karma Power: 32
Crash Not has less than 100 Karma points so far.
Re: How to Measure Straightness of Small Bars or Tubes (Long Length)
I would support each end in a 'V' block and rotate the bar using a dial indicator in the middle.
Thank You to Crash Not for your informative Post and/or Attachment!
Old 6th November 2007, 11:09 AM
Jim Wynne's Avatar
Jim Wynne Jim Wynne is online now
Registration Date: Jan 2005
Thanks Given to Others: 1,781
Karma Power: 1445
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
How do you propose to avoid using the method required by the standard?
We aim to please. You aim too, please.
Thanks to Jim Wynne for your informative Post and/or Attachment!
Old 6th November 2007, 11:13 AM
Benjamin28 Benjamin28 is offline
Tater Salad
Registration Date: Dec 2006
Thanks Given to Others: 89
Karma Power: 65
Benjamin28 is appreciated, and has over 900 Karma points.Benjamin28 is appreciated, and has over 900 Karma points.Benjamin28 is appreciated, and has over 900 Karma points.Benjamin28 is appreciated, and has over 900 Karma points.Benjamin28 is appreciated, and has over 900 Karma points.Benjamin28 is appreciated, and has over 900 Karma points.Benjamin28 is appreciated, and has over 900 Karma points.Benjamin28 is appreciated, and has over 900 Karma points.
For practical measurement I would do the same as Crash suggested, seems like this would work for the most part. For an automated solution, there are a few patent-pending devices, but I'm not sure of anything very mainstream.
http://www.mefos.se/services-and-pro...s-meter-4.html
"Don't Tell Me the Sky is the Limit . . . . . . There Are Footprints on the Moon".
Thanks to Benjamin28 for your informative Post and/or Attachment!
Old 6th November 2007, 11:27 AM
Registered Visitor
Karma Power: 32
Another method might be to roll the bar on a surface plate with the bow up in the middle and use a feeler gage to measure the gap between the bar and the plate.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Gage to Measure Wire Straightness needed aproddutoor Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5 10th May 2010 09:42 PM
Correct Length to Measure Surface Roughness Spacewalker Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4 7th January 2010 03:08 PM
Plastic Rod Straightness Tolerance Standard - 12' Bars of 3/8" Round Acetal Delrin jschmidt Various Other Specifications, Standards, and related Requirements 3 3rd October 2009 10:28 AM
SMA Connector Measurement - Measurement Equipment to Measure the Ferrule Length Mark Smith ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories 3 13th March 2008 09:15 PM
Improving Small Diameter Cable Length Measuring Techniques - Process Improvement cable6 Preventive Action and Continuous Improvement 3 17th December 2007 04:44 PM
The time now is 04:58 PM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, Olde West Chester, Ohio 45069-1929
513 341-6272
