Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - Calibration, Measurement Gages and Test Laboratories > Measurement Uncertainty (MU)
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 7th November 2007, 06:43 AM
amanbhai amanbhai is offline
Involved - Posts
Registration Date: Apr 2005
Thanks Given to Others: 56
Karma Power: 35
amanbhai is appreciated, and has over 100 Karma points.amanbhai is appreciated, and has over 100 Karma points.
Question Relative or Combined Type A & Type B Uncertainty Calculation?
Is it neccessary in the sandard to calculate the relative unicertainty calculation? What if we calculate the uncertainties of type A & Type B but do not combined them or expand them?
Sponsored Links
Old 7th November 2007, 09:32 AM
Benjamin28 Benjamin28 is offline
Tater Salad
Registration Date: Dec 2006
Thanks Given to Others: 89
Karma Power: 37
Benjamin28 is appreciated, and has over 900 Karma points.Benjamin28 is appreciated, and has over 900 Karma points.Benjamin28 is appreciated, and has over 900 Karma points.Benjamin28 is appreciated, and has over 900 Karma points.Benjamin28 is appreciated, and has over 900 Karma points.Benjamin28 is appreciated, and has over 900 Karma points.Benjamin28 is appreciated, and has over 900 Karma points.Benjamin28 is appreciated, and has over 900 Karma points.
Default Re: Relative or combined Uncertainty calculation?
Your AB will most likely give you a minor for not calculating Expanded Measurement Uncertainty for your instrument/calibration. If you've already calculated the A B contributors it is relatively simple math to calculate expanded uncertainty even if you need to use sensitivity coefficients the guides available for UNC will give you a good clear method for calculating this, therefore there really shouldn't be any reason you can't calculate expanded uncertainty.
http://metrologyforum.tm.agilent.com/download3.shtml
Something like this may also be useful for calculating uncertainties.
"Don't Tell Me the Sky is the Limit . . . . . . There Are Footprints on the Moon".
Thanks to Benjamin28 for your informative Post and/or Attachment!
Sponsored Links
Old 7th November 2007, 09:52 AM
Tater Salad
Karma Power: 37
I probably should have also mentioned that ISO 17025 isn't very specific about MU, rather it mentions the requirements to calculate uncertainty and then refers the reader to ISO 5725 for further direction. If you're looking for specifics the GUM is your best bet. If you're a test lab 17025 also makes an exception for UNC calculations, recognizing that exact calculations may be prohibitive in some cases they do accept reasonable estimations. At the minimum they will want to see that you've identified the appropriate sources of uncertainty and made an effort to estimate the combined uncertainty.
Old 12th December 2007, 07:14 PM
DrBobby DrBobby is offline
Registration Date: Dec 2007
Thanks Given to Others: 1
Karma Power: 8
DrBobby has less than 100 Karma points so far.
Default Re: Relative or Combined Type A & Type B Uncertainty Calculation?
Be careful of referencing the GUM manual unless you know that you are using it. As an auditor when the GUM manual is referenced, I will ask someone in the lab who is taking the data for uncertainty what the equation A-3 on page 13. It is a second order partial differential equation. It is better if you just rely on a known software calculator like UnCalc4. One must be able to explain why they are using a source and the GUM is difficult if you have a limited background in mathmatics. However, it is an excellent source that will answer many questions.
Old 12th December 2007, 07:50 PM
Jim Wynne's Avatar
Jim Wynne Jim Wynne is offline
Courtesy Access
Registration Date: Jan 2005
Thanks Given to Others: 755
Karma Power: 611
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Welcome to the Cove, DrBobby
That's good advice there. Never cite that which you haven't read and/or don't understand.
Thanks to Jim Wynne for your informative Post and/or Attachment!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Clarification on Basic Principle of Uncertainty (Type A & B) neoth Measurement Uncertainty (MU) 6 5th October 2009 04:54 AM
Why are type K and type E thermocouples not pemitted to be recalibrated ? ggdjr ISO 17025 - Calibration, Measurement Gages and Test Laboratories 5 26th July 2008 04:08 AM
Which system of inspection will be better attribute type or the variable type? preetham Capability, Accuracy and Stability - Process, Machine, etc. 3 13th February 2006 01:25 PM
How to determine Type-B uncertainty?What distribution?With Calibration beginner guide nick1980 Measurement Uncertainty (MU) 11 5th October 2004 11:44 AM
Errors - Uncertainty Type I, II, or Alpha, Beta vs. Gage R&R Marc Measurement Uncertainty (MU) 1 10th September 1999 06:16 PM
The time now is 06:25 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
