The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > SPC Monitoring and Statistical Analysis Techniques
Forum Username
Elsmar Cove Forum Sidebar
Custom Search
Monitor the Elsmar Forum
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Sponsored Links
Courtesy Quick Links
Howard's
Atul's
Symphony Technologies
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Related Topic Tags
correlation coefficient, t-distribution, variation (measurement), mean and median in statistical analysis
Reply
  #25
Old 13th May 2008, 07:51 AM
jas4710 jas4710 is offline
Registration Date: May 2008
Thanks Given to Others: 4
Karma Power: 21
jas4710 has less than 100 Karma points so far.
Re: Correlation using t-test and correlation coefficient - What is the correct result
In Reply to Parent Post by Bev D View Post
Additionally I will reiterate as Steve did that paired t tests and linear regression are NOT the appropriate statistical tools for measurement studies such as yours. The Intraclass correlation coefficient is the appropriate statistic...a simple google search for this will help.
From SPSS, there are different parameters
(Two-Way Mixed when people effects are random and the item effects are fixed, select Two-Way Random when people effects and the item effects are random, or select One-Way Random when people effects are random.)
However, the so-called "people effects", "fixed", "random" look unclear to me. Furthermore, should only one set of data is to be supplied or both sets?
Sponsored Links
  #26
Old 13th May 2008, 10:28 AM
prototyper's Avatar
prototyper prototyper is offline
Appreciation Courtesy Access
Thanks Given to Others: 51
Karma Power: 50
prototyper is appreciated, and has over 1300 Karma points.prototyper is appreciated, and has over 1300 Karma points.prototyper is appreciated, and has over 1300 Karma points.prototyper is appreciated, and has over 1300 Karma points.prototyper is appreciated, and has over 1300 Karma points.prototyper is appreciated, and has over 1300 Karma points.prototyper is appreciated, and has over 1300 Karma points.prototyper is appreciated, and has over 1300 Karma points.prototyper is appreciated, and has over 1300 Karma points.prototyper is appreciated, and has over 1300 Karma points.
At this point there are too many unknown factors!
We do not know the repeatability and reproducibility of either piece of measuring equipment, if there is any operator test retest error or operator bias.
I would recommend a study as per the MSA manual third edition on each individual piece of equipment to identify any weakness in the measurement systems prior to any direct comparison of data.
I have attached a spreadsheet which I developed from the manual which may help. The data included is directly from the MSA third edition to validate the calculations.
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting this post, 3. Use at your Own Risk.
Thanks to prototyper for your informative Post and/or Attachment!
Sponsored Links
  #27
Old 13th May 2008, 10:48 AM
Karma Power: 21
In Reply to Parent Post by prototyper View Post
MSA is too rigorous for me to follow... is there any way to better perform intraclass correlation coefficient analysis? Merely taking all data will yield poor R but I just don't know how intraclass R can be calculated *meaningfully*.
  #28
Old 13th May 2008, 11:11 AM
prototyper's Avatar
Karma Power: 50
Not that I know of as the intraclass correlation coofficient is the ratio of the estimated product variation and the estimated measurement variation.
We do not know the measurement variation inherent from each piece of equipment.
  #29
Old 13th May 2008, 11:51 AM
Bev D's Avatar
Bev D Bev D is offline
Registration Date: Jan 2003
Thanks Given to Others: 1,004
Karma Power: 324
Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.
Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.
In Reply to Parent Post by jas4710 View Post
what are you trying to do?
  #30
Old 13th May 2008, 07:48 PM
Karma Power: 21
The same as the OP. I've got 2 sets of data in hand and discovered correlation of around 0.6. From studying the previous messages, it seems that intraclass correlation coefficient may help explain which portion of the data is leading to poor correlation. Therefore I'm asking how to calculate "intraclass correlation coefficient " Thanks a lot
  #31
Old 14th May 2008, 07:19 AM
Bev D's Avatar
Karma Power: 324
the OP had repeated measurement error data. (two independent measurements of 20 different samples)
Is this the type of data you have? or do you have measurements of two variables that you suspect as having a cause and effect relationship to each other?
also if you POST your data and explain what it is, how you collected it and why you are interested in it we can help you.
the intraclass correlation coefficient ahs a very specific applicability adn i don't know from your post if it applies.
Thanks to Bev D for your informative Post and/or Attachment!
  #32
Old 14th May 2008, 10:26 AM
Karma Power: 21
Columns D & G are the data obtained by measuring the movement of different parts (Column A refers to 3D coordinate ID) of an object under different experimental conditions, e.g. different temperature. Maybe more than 1 condition is varied (not designed by me) and I'm just testing whether under different conditions shall still give readings with good correlation. If not, is particular part of that object leading to difference? Thanks once agin.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Correlation Coefficient and Industry Standards - Corrrelation between two of my CMMs Brad Gover Using Minitab Software 2 20th December 2011 01:11 PM
What is difference between a t-test and Correlation Coefficient calebn SPC Monitoring and Statistical Analysis Techniques 2 6th April 2011 10:30 PM
Correlation - The meaning of correlation and and its application in data analysis KCIPOH Definitions, Acronyms, Abbreviations and Interpretations 4 10th February 2010 01:49 PM
Improving coefficient correlation result D.Salman SPC Monitoring and Statistical Analysis Techniques 1 12th November 2009 04:58 AM
When to use Intraclass Correlation Coefficient vs. Coefficient of Variance seirawan SPC Monitoring and Statistical Analysis Techniques 21 4th December 2007 01:33 PM
The time now is 02:23 AM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, Olde West Chester, Ohio 45069-1929
513 341-6272
