The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > SPC Monitoring and Statistical Analysis Techniques
Forum Username
Elsmar Cove Forum Sidebar
Custom Search
Monitor the Elsmar Forum
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Sponsored Links
Courtesy Quick Links
Howard's
Atul's
Symphony Technologies
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Related Topic Tags
correlation coefficient, t-distribution, variation (measurement), mean and median in statistical analysis
Reply
  #41
Old 19th May 2008, 08:01 PM
Miner's Avatar
Miner Miner is offline
Registration Date: Apr 2002
Thanks Given to Others: 557
Karma Power: 391
Miner is appreciated, and has over 1700 Karma points.
Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.
Re: Correlation using t-test and correlation coefficient - What is the correct result
Bev is right. It is not that we do not want to help you, but you are providing very minimal information. We would need specifics about the way the data was collected before we can provide meaningful advice.
The proper analysis could depend on very exact information on how the experiment was performed. For example, the exact same experiment may be run as a fully randomized experiment or as a split-plot experiment. The analysis technique is different in each case.
"A fool can learn from his own experiences; the wise learn from the experience of others." - Democritus, 460-370 B.C.
Sponsored Links
  #42
Old 20th May 2008, 12:38 AM
amanbhai amanbhai is offline
Registration Date: Apr 2005
Thanks Given to Others: 136
Karma Power: 120
amanbhai is appreciated, and has over 900 Karma points.amanbhai is appreciated, and has over 900 Karma points.amanbhai is appreciated, and has over 900 Karma points.amanbhai is appreciated, and has over 900 Karma points.amanbhai is appreciated, and has over 900 Karma points.amanbhai is appreciated, and has over 900 Karma points.amanbhai is appreciated, and has over 900 Karma points.amanbhai is appreciated, and has over 900 Karma points.
Re: Correlation using t-test and correlation coefficient, what is the correct result?
In Reply to Parent Post by Geoff Withnell View Post
Without seeing the data, just the summary data, I suspect that the problem is that while the means and variances MAY be different, they are not ENOUGH different for a sample of 20 to reliably distinguish between them. I will bet if you plot both samples as histograms, and lay one over the other, you will see that they are very similar. When dealing with two populations such as we have here, with means separated by only a fraction of a standard deviation, a fairly large sample is usually required to show the separation, unless the SDs are very different. Not mathematically rigorous, but it often helps to look at the data visually to diagnose a problem.
Geoff Withnell
Offcourse the sample size in many cases maybe important.
but Do we determine ourself the sample size? or the population size?
Sponsored Links
  #43
Old 20th May 2008, 08:27 AM
Bev D's Avatar
Bev D Bev D is offline
Registration Date: Jan 2003
Thanks Given to Others: 1,002
Karma Power: 324
Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.
Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.
In Reply to Parent Post by amanbhai View Post
we never determine the appropriate sample size, but we should calculate it (in this case, the definition of the words matter): the system from which we are sampling determines the sample size. The process's standard deviation and homogeneneity of data determines what sample size and sampling scheme is necessarry to make accurate estimates. We can choose how accurate we wish to be and how much difference we wish to detect. This will enable us to calculate what sample size is necessarry to meet our wishes.
Population size is mostly an irrelevent question in the practical world (unless very small)
  #44
Old 23rd May 2008, 04:19 PM
jas4710 jas4710 is offline
Registration Date: May 2008
Thanks Given to Others: 4
Karma Power: 21
jas4710 has less than 100 Karma points so far.
In Reply to Parent Post by Bev D View Post
Again: we need to know EXACTLY what was done. what factors were tested, what levels for each factor? what was the sample size for each level? Was the 'experiment' passive (just took X and Y data as it naturally occured) or was it invasive? (deliberately set levels of the factor(s) and then collected data on the resulting output Y.) was it a series of one factor at a time experiments or were there full factorial or fractional factorials?
I will again caution that you that very often when 'experiemnts' are not properly structured, no amount of analysis will help; you may need to design a bettter experiment.
You can use 'nicknames' for the factors but we need more than the general info you've provided.
While in a.xls, better correlation in r1-r2 (col L) was identified, while less good result was observed in b.xls. In fact, there are far more factors but my boss said just focus on two (b.xls missing one). There are other results files like the attached two. I hope this answer some of the questions. The experiment was invasive for the 2 factors (but should be accurate) and carried out with a set of factors that can be totally different from one to another. The experiment per se is not to test the effects of those factors but I am here to question whether the factors will affect the results significantly. My boss believes normalization should help but he also agrees that how to normalize well is difficult. I'm unable to repeat the experiments with different factors.
Thank you once again for Bev and Miner's response.
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting this post, 3. Use at your Own Risk.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Correlation Coefficient and Industry Standards - Corrrelation between two of my CMMs Brad Gover Using Minitab Software 2 20th December 2011 01:11 PM
What is difference between a t-test and Correlation Coefficient calebn SPC Monitoring and Statistical Analysis Techniques 2 6th April 2011 10:30 PM
Correlation - The meaning of correlation and and its application in data analysis KCIPOH Definitions, Acronyms, Abbreviations and Interpretations 4 10th February 2010 01:49 PM
Improving coefficient correlation result D.Salman SPC Monitoring and Statistical Analysis Techniques 1 12th November 2009 04:58 AM
When to use Intraclass Correlation Coefficient vs. Coefficient of Variance seirawan SPC Monitoring and Statistical Analysis Techniques 21 4th December 2007 01:33 PM
The time now is 01:13 AM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, Olde West Chester, Ohio 45069-1929
513 341-6272
