8th November 2007, 11:28 AM
Registration Date: Nov 2007
Thanks Given to Others: 16
Karma Power: 9 Karma: 10
MTBF (Mean Time Between Failures) Calculation
Please help!
I used this equation Fail Rate= # of failure/total running time.Therefore, MTBF is 1/fail rate.
The total running time= unit that does not fail running time + running time of the fail unit.
Question: Let say that one of my unit failed, we repair it then it will continue to run again. How do one input as a running time for this failed unit? Are you suppose to include only upto the time it failed or even after it is fixed and ran again?
Best regards,
Kenny
8th November 2007, 12:06 PM
Involuted - Posts
Registration Date: Sep 2007
Thanks Given to Others: 10
Karma Power: 10 Karma: 67
Re: MTBF Calculation
Kenny,
In my opinion, you count the time before and after the repair.
If you only made one part and it first failed after 5 mins, you repaired it, and it fails again after 7 mins. At that point the MTBF (or average time between failures) is 6 mins.
See: http://www.vicr.com/documents/quality/Rel_MTBF.pdf
for a fuller explanation of the difference between MTBF and MTTF (Mean time to failure).
Reason: typo
8th November 2007, 12:11 PM
Courtesy Access
Registration Date: Jan 2005
Thanks Given to Others: 755
Karma Power: 611
Originally Posted by kctrinh
Please help!
Best regards,
Kenny
Mean time between failures gives a good overview of MTBF and the calculations for it.
20th November 2007, 12:31 PM
VINI, VIDI, DORMIVI
Registration Date: Feb 2002
Thanks Given to Others: 20
Karma Power: 84
Re: MTBF (Mean Time Between Failures) Calculation
The other part of your OEE is the Mean Time To Repair. When you decide to start the counter on either of them is something that should be understood by Maintenance, Production and yourself.
Normally, MTBF is from "start-up" to fail, MTTR may start at Maintenance notification and run until they return the machine to production (after prove out of the repair). I have seen some engineers track MTTR until the "Okay to Run" was issued from QA. I have also seen where scheduled downtime was not computed in MTBF because the machine wasn't running.
Decide what data is going to help. When to start or stop isn't the main issue. Getting data and being able to use it to make you better is.
"What this country needs is more unemployed politicians." Edward Langley
Thanks to Randy Stewart for your informative Post and/or Attachment!
8th January 2008, 04:46 AM
Involved in Discussions
Registration Date: Aug 2007
Thanks Given to Others: 236
Karma Power: 13 Karma: 31
Dear Randy,
TS clause 7.3.3.2 requires manufacturing process design output shall incluide "data for quality, reliability, maintainaility and measurability" and clause 8.2.3.1 also talks about "process capability, reliability, maintainability and availability". Can you give example of these metrics in relation to manufacturing process ?
