The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Misc. Quality Assurance and Business Systems Related Topics
Forum Username
Elsmar Cove Forum Sidebar
Custom Search
Monitor the Elsmar Forum
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Sponsored Links
Courtesy Quick Links
Howard's
Atul's
Symphony Technologies
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Reply
Old 23rd November 2007, 05:30 AM
alexanderqms alexanderqms is offline
Registration Date: Nov 2007
Karma Power: 23
alexanderqms has less than 100 Karma points so far.
Question How to Design Good and Relevant Management System Forms?
The relevant staffs of to be responsibility for ISO management are familiar with the defining of the form in the ISO 9000 standard family is a medium that record relevant quality information of implementation of the quality management system, it will supply evidences for the efficient implementation of management system..
Base on my experiences, it is not easy to design the form well; it needs the same thread as the establishing of the procedure. Let me analysis and summary individual experiences, I have found the following questions during using form:
1)there are some blank columns after the using of form have ended.
2)there are not the sufficient and necessary blank, lead to the operators fill quality information in the other blank, or to add some columns in the form specially with a pen.
3)And we also find this situation of having some format changes in the form.
So, base on the above situations, there is the question that How to design form of management system well. Will you supply some specific ideas?
Sponsored Links
Old 23rd November 2007, 09:02 AM
Stijloor's Avatar
Stijloor Stijloor is offline
Cross Forum Moderator
Registration Date: May 2003
Thanks Given to Others: 2,949
Karma Power: 1431
Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.
Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.
Re: How to Design Good and Relevant Management System Forms?
In Reply to Parent Post by alexanderqms View Post
So, based on the above situations, there is the question that How to design form of management system well. Will you supply some specific ideas?
Hello alexanderqms,
Here is a link to "forms" from the "post attachments lists."
Here are the results of a forum search on "Forms."
It's probably a lot more than you would need at the moment, but I am sure you'll find some information and examples that would be of help to you.
Hope this helps.
Stijloor.
Sponsored Links
Old 23rd November 2007, 11:13 AM
Jim Wynne's Avatar
Jim Wynne Jim Wynne is offline
Registration Date: Jan 2005
Thanks Given to Others: 1,779
Karma Power: 1445
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
If people are adding information to forms that isn't called for, you have to determine whether the information is useful or not. If it is, revise the form to account for it, and if it's not, tell people not to add information that's not called for. Similarly, when fields are left blank, you have to determine whether the omissions are appropriate or not. There may be instances where some of the fields on a form will not be applicable each time the form is used.
I like to issue new documentation (any kind--forms, procedures, work instructions) as beta versions, where there's acknowledgment that the documents might need changes before being considered "official." It's often hard to tell what's actually needed until the process is running, and everyone who has to use the documents should be encouraged to help improve them during the beta period. Once you're satisfied that the document fulfills its intended purpose(s), suggestions for changes should still be encouraged, but people should be expected to do things in accordance with the requirements, with no exceptions that haven't been duly approved. In short, if you find that your forms aren't working as intended, you need to change something--either the way that people are using the forms, or the forms themselves.
We aim to please. You aim too, please.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Should every Management System include Design? JaneB ISO 9000, ISO 9001, and ISO 9004 - Questions and Discussions 121 13th November 2010 12:15 AM
How to make good Evaluation of Quality Management System of Suppliers Chennaiite ISO 19011 *and* ALL other Auditing Discussions 12 5th December 2009 01:01 PM
EMS (Environmental Management System) related criteria for Design Works Daminda ISO 14001 and Environmental Related Standards 3 16th July 2009 04:26 AM
Which ISO guideline or system is relevant for Hospitals? pancho-2007 Hospitals, Clinics & other Health Care Providers - Best Practices and ISO 9001 5 28th November 2007 09:32 PM
ISO 9001-2000 quality management system design RTerranova Design and Development - Process and Product 1 14th April 2007 07:27 AM
The time now is 03:48 AM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, Olde West Chester, Ohio 45069-1929
513 341-6272
