Variance components with 3 nested factors and a covariate - Minitab
I performed a variance components analysis in Minitab. I have 3 factors (Mixer, 2 levels; Batch, nested in mixer, 5 batches/mixer; box, nested in batch, 5 boxes/batch) and a covariate. The ANOVA and the table of variance components looks as follows:
Analysis of Variance for Can PSI, using Adjusted SS for Tests
Source DF Seq SS Adj SS Adj MS F P
Net Wt (gm) 1 1347.660 646.910 646.910 1043.76 0.000
Mixer 1 44.177 45.305 45.305 2.09 0.187 x
Batch(Mixer) 8 173.732 172.638 21.580 11.85 0.000 x
Box(Mixer Batch) 40 74.852 74.852 1.871 3.02 0.000
Error 545 337.784 337.784 0.620
Total 595 1978.205
x Not an exact F-test.
S = 0.787266 R-Sq = 82.92% R-Sq(adj) = 81.36%
Term Coef SE Coef T P
Constant -45.216 1.921 -23.54 0.000
Net Wt (gm) 0.172733 0.005347 32.31 0.000
Expected Mean Squares, using Adjusted SS
Source Expected Mean Square for Each Term
1 Net Wt (gm) (5) + Q[1]
2 Mixer (5) + 11.4043 (4) + 57.0215 (3) + 285.1077 (2)
3 Batch(Mixer) (5) + 11.3292 (4) + 56.6458 (3)
4 Box(Mixer Batch) (5) + 11.8032 (4)
5 Error (5)
Error Terms for Tests, using Adjusted SS
Source Error DF Error MS Synthesis of Error MS
1 Net Wt (gm) 545.00 0.620 (5)
2 Mixer 8.00 21.719 1.0066 (3) - 0.0066 (5)
3 Batch(Mixer) 41.12 1.821 0.9598 (4) + 0.0402 (5)
4 Box(Mixer Batch) 545.00 0.620 (5)
Can anyone tell me how to interpret this last Variance components table? For each factor, what is the % of total variance (taking into account the covariate)?
Thank you very much!
Despina
Re: Variance components with 3 nested factors and a covariate - Minitab
From Minitab Help: Variance components
Use to evaluate sources of variation. In Minitab, components of variance are used in ANOVA and Gage R&R. ANOVA
Variance components assess the amount of variation in the response due to random factors. Random factors have levels that are selected at random; whereas fixed factors have levels that are controlled by the experimenter. For example, you conduct a study on the effect of two levels of pressure on output measured by randomly chosen operators. Pressure is fixed (2 levels); and operator is random. The variance components output lists the estimated variance for the operator and error term.
