12th December 2007, 04:42 PM
Alien
Registration Date: Apr 2007
Thanks Given to Others: 29
Karma Power: 11 Karma: 10
Duration between Management Review and Registration
need to ask
if the issue date of iso9001:2000 quality system in an organization is 01/01/2008 for example can the organization bring the registration body after only 15 days or less or there must be a duration for application of the system to convence the auditor.
12th December 2007, 04:54 PM
Cross Forum Moderator
Registration Date: May 2003
Thanks Given to Others: 1,317
Karma Power: 377
Re: duration between management review and registration
Originally Posted by MDWEEK
need to ask
I hope that I understand your question correctly. You should present a compliant and workable system to the Registrar. Fifteen days of activity looks very short to me.
Stijloor.
12th December 2007, 06:15 PM
Post responsibly
Registration Date: Oct 2001
Thanks Given to Others: 688
Karma Power: 467
need to ask
If the CB were following the ISO 17021 prescribed methodology, the first time the auditor was to visit the organization would be the Stage 1 audit. Such activity is to ensure the readiness of the system to be assessed for certification purposes.
Audits are done based on objective evidence. Good intentions only are not enough. Certain activities might generate enough evidence of compliance in a couple of days, but, larger, broader process monitoring indicators and other less frequent activities such as design reviews, internal audits and management reviews will probably take longer to collect evidence of performance.
Fighting organizational dysfunction, one post at a time.
12th December 2007, 08:43 PM
Registration Date: Feb 2005
Thanks Given to Others: 1,786
Karma Power: 297
Re: Duration between Management Review and Registration
need to ask
Since the principle purpose of management review is to review the effectiveness of the quality management system, identify any issues and then, depending on what's found, initiate either corrective actions or improvements, it would follow that there should be some evidence of actions resulting from the review. Hence, IMHO, 15 days is unlikely to be sufficient, but it depends on what can reasonably accomplished and the type of business, customer expectations
'Cause you know sometimes words have two meanings.....
13th December 2007, 09:07 AM
Courtesy Access
Registration Date: Sep 2001
Thanks Given to Others: 3
Karma Power: 65
I believe that most registrars require one MR and a full cycle of internal audits
13th December 2007, 01:54 PM
Post responsibly
Karma Power: 467
Most CB's require that because it is a requirement of the IAF Guidance to ISO Guide 62:
G.2.1.43. Certification/registration shall not be granted until there is sufficient evidence to demonstrate that the arrangements for management review and internal audit have been implemented, are effective and will be maintained.
