Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 9001 - Quality Management Systems Standard
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 11th August 2000, 12:12 AM
lmfoong
Unregistered Guest
Posts: n/a
Changes to ISO 9001:2000
I seek to obtain advice pertaining to the any significant changes in the revision of ISO 9001:2000 in the following areas :-
1) Involvement of top management
2) Measurement of customer satisfaction and dissatisfaction
3) Continual improvement
Thanks and Best Regards
lmfoong
Sponsored Links
Old 14th August 2000, 08:00 AM
Marc's Avatar
Marc Marc is online now
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Yin Yang
You ought to take a read through Misinterpretation of ISO9K-2K for a sometimes 'spirited' debate on some differences.
Anyone want to contribute some specifics?
Sponsored Links
Old 16th August 2000, 04:19 AM
Andy Bassett Andy Bassett is offline
An Early Cover
Registration Date: Jun 1999
Karma Power: 48
Andy Bassett has less than 100 Karma points so far.
Ill avoid the specifics, but tell you my take on the three points mentioned.
1) Involvement of top management.
I beleive that the new standard strengthens the requirements for management involvement. I understand that they now have to set clear targets for the system and measure them and follow them. Before you could of scraped by with a Quality Policy.
2) Measurement of customer satisfaction and dissatisfaction.
I now understnad that this is a requirement.
3) Continual improvement.
This should automatically come about becuase you are required to measure your processes.
The general discussion is that all this SHOULD have been done before. This is true, but i beleive many companies with the certificate were not doing this.
Regards
Andy B
Old 22nd November 2000, 06:04 PM
Marc's Avatar
Karma Power: 605
Hehehe...
Some thoughts:
Date: Mon, 9 Oct 2000 13:21:07 -0500
Subject: Re: Q: ISO 9000:1994 Vs. ISO 90002000 /van Putten/Paten
Dirk,
I have used Figure 1 of ISO 9001:2000 (the "Process-Based Quality Management System") to depict how the new standard focuses on both "compliance" and "improvement". The following narrative explains:
Assuming that what you "Say You Do" meets the intent of the standards, both the 1994 and 2000 versions require you to "Do What you Say" (implement) and "Prove It" (demonstrate compliance).
The biggest change for 2000 is that you also must "Improve It".
In order to improve you must have "baseline" measures to gage improvement against. Therefore we must develop at least one key performance measure for each of the key QMS processes (or elements) - then we must gather our baseline data and set goals or objectives for improvement based on current performance - then we must take action to improve the processes most in need of improvement - then we must take a look at measureable results to see if actions taken achieved the desired results. Classic stuff.
I advocate that at least two key measures be easily established for each QMS process or element: 1) at least one measure of (in)effectiveness - i.e. something that measures whether (or not) you achieved the overall objective or desired outcome of a particular process; and 2) at least one measure of (in)efficiency - i.e. something that measures how well (or poorly) resources were utilized to achieve the results measured in 1). For example
Clause 6.2.2: Training Processes: Key measures of effectiveness: % employees fully trained and qualified and/or % corrective actions resulting from a lack of training. Key measures of efficiency: % of training completed rated by attendees as marginally satisfactory or worse.
Clause 7.2: Customer Related Processes. Key measures of effectiveness: % customer satisfacation and/or the # of customer complaints. Key measures of efficency: resources dedicated to customer related processes and/or resources devoted to investigating/resolving customer complaints.
Clause 7.3: Design Control Processes. Key measure(s) of effectiveness: Product/Service Performance Measures. Key measures of efficiency: resources devoted to design function and/or resources devoted to design changes resulting from product failures reported from the field.
Clause 7.4: Purchasing Control Processes: Key measures of effectiveness: Supplier performance measures and/or the # corrective actions resulting from incorrect, misidentified or poor quality purhased material. Key measures of efficiency: Resources involved in processing returns and/or supplier corrective actions.
Clause 7.5: Operations Control Processes: Key measures of effectiveness: Product / Service Quality Measures. Key measures of efficiency: defect rate, % scrap, rework, equipment downtime; inventory accuracy, % operations where work instructions or automated process controls are in place.
In any case, these measures should be easy to come up and track. Like most of what ISO has always required - it's not rocket science - just good, down to earth common sense stuff.
Best of luck in the "Move from Conformance to Performance"
Mike Paten
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Summary of Changes - ISO 9001:2000 and ISO 9001:2008 Marc ISO 9001 - Quality Management Systems Standard 154 27th October 2009 12:10 PM
Draft ISO 9001:2008 (Feb 08 version) & Summary of Changes kiwisfly ISO 9001:2008 Status 60 16th November 2008 06:56 AM
ISO 9001-2000 Registered - We received our ISO 9001:2000 certificate yesterday Lauren B. ISO 9001 - Quality Management Systems Standard 30 22nd July 2003 03:51 PM
Summary of Differences and Changes - ISO 9001:1994 and ISO 9001:2000 Marc ISO 9001 - Quality Management Systems Standard 19 31st March 2002 10:14 PM
ISO 9000:2000 Clause 7.3 Design and Development Requirements Summary Andy Bassett Design and Development - Process and Product 23 20th October 2000 01:54 AM
The time now is 08:59 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
