Elsmar Cove Quality DiscussionsHow to Set Acceptable Calibration Limits for Measurement Instruments?The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > > >
Forum Username
Wooden Line
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links Elsmar Cove visitors will find useful in the quest for knowledge and support:
Jennifer Kirley's
Conway Business Services
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Ajit Basrur
Claritas Consulting, LLC
International Standards Bodies - World Wide Standards Bodies
AIAG - Automotive Industry Action Group
International Organization for Standardization - ISO Standards and Information
Quality Digest
Reply
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 4.00 average. Display Modes
  Post Number #1
Old 2nd January 2008, 06:42 AM
sowmya
Please Help! How to Set Acceptable Calibration Limits for Measurement Instruments?
during verification of calibration certificates, we find deviations.how to fix the acceptable limits for the instruments?. Is there any standards available, so as to say that for vernier acceptable limits are this much like that.......
Some people say, that acceptable limits can be based on the process tolerance. but we are contract manufacturers and process tolerance varies for different products........any help?
Sponsored Links
  Post Number #2
Old 2nd January 2008, 09:38 AM
Al Rosen's Avatar
Al Rosen
Re: How to Set Acceptable Calibration Limits for Measurement Instruments?
In Reply to Parent Post by sowmya View Post
The instrument's manufacturer determines the limits. Notice the accuracy in the specs.
Thank You to Al Rosen for your informative Post and/or Attachment!
  Post Number #3
Old 2nd January 2008, 11:06 AM
BradM's Avatar
BradM
This is a bit of a problem. When you say you are finding deviations, do you mean Out of Tolerance, or just finding deviations within tolerance? There will always be deviations, but the instrument should be adjusted to minimize any deviations.
Are you calibrating your own instruments, or having someone calibrate them for you? If someone is doing them for you, are they competent to do your work? What tolerance do they cite on the certificates?
Yes... to an extent. For your situation, though, Al's suggestion is the correct one. You would create a complex situation trying to keep up with everything. However, you might can have different standards for different processes (which have different tolerances).
  Post Number #4
Old 2nd January 2008, 12:44 PM
Jerry Eldred's Avatar
Jerry Eldred
I don't at all disagree with any previous replies. As has already been covered, tolerances are by model. A given model caliper for example, has a given tolerance. Tolerance does not change based on what is being measured. The overall measurement uncertainty may change based on a variety of factors, but the tolerance for a model stays the same.
However, one consideration in establishing tolerances (for your own instruments) is that there are legitimate methods for defining your own tolerances. I say this very carefully. So please read details below carefully if you consider doing this.
The normal industry practice is to certify an instrument meets its specified tolerances. However, if you use an instrument to tolerances different than the manufacturer's (OEM = Original Equipment Manufacturer), you may use a process-based, local tolerance rather than OEM tolerance. However, to do this requires documentation to assure it is fully defined.
-Your quality system must specifically allow local tolerances.
-You must document this for each instrument, so that there is no confusion whether OEM tolerances are used or a locally established tolerance is used.
-You must be able to ensure there can be no confusion as to which tolerance applies.
-Users must have documented training to assure only the correct tolerance is used at the correct process.
-If you use multiple differing tolerances for the same instrument on different processes, each instrument must be CLEARLY labeled for what tolerance and which process it may used on.
-Calibration Procedures, process documents, and calibration labeling must account for the differences.
This is a risky method and should only be done if it is worthwhile for your application.
I have said previously that you can calibrate anything to any tolerance you want. **HOWEVER** (and it is a BIG HOWEVER), when ever you deviate from calibrating to OEM tolerances, there is risk (users will misuse instruments and make erroneous measurements - another long topic). So if you wish to calibrate to multiple local tolerance carefully consider the risks, and be sure they are all accounted for in your quality system.
P.S. - Hi J. S.
Thank You to Jerry Eldred for your informative Post and/or Attachment!
  Post Number #5
Old 2nd January 2008, 12:48 PM
BradM's Avatar
BradM
Nice job, Jerry. You typed what I thought about mentioning.
P.S.-Good to have you checking back in.
  Post Number #6
Old 3rd January 2008, 02:55 AM
sowmya
Thanks for the great inputs jerry. Still some confusions......
We are doing calibrations for soldering stations (Accuracy is defined as ±5°C, do not know how it is defined, but the process is not critical for our application and it works till now. during verification we will give go ahead for production if the deviation is within ±5°) in house and other instruments like vernier caliper, micrometer goes to outside calibration agencies (NABL accredited).
For vernier caliper model 500-196, the accuracy given is ± 0.001in. Is that means, for a nominal value of 20mm it if measures 19.97mm we need to reject the instrument or give correction factor?. confused.....
The calibration agency has given a statement on the top of the results.........instrumental allowable error of measuring length ± 0.03mm. which error it talks about?
Another thing, for load cell we could not find NABL accredited lab, so we have done calibration without NABL. Last time TS auditor questioned about it and we replied the same. what should we do in that case?
thanks,
Sowmya
  Post Number #7
Old 3rd January 2008, 06:24 AM
pinpin - 2009's Avatar
pinpin - 2009
Dear Jerry,
How can we tell from the calibration report that our instrument can still be used or fit to be used?
I heard some people say we have to look at the measurement uncertainty value and compare with the part's tolerance that we are to measure using this instrument, then can determine whether it can be used or not...
Please teach me.
Thank You.....
  Post Number #8
Old 3rd January 2008, 10:49 AM
BradM's Avatar
BradM
I'm not Jerry, but I will add a few thoughts for you!
Sowmya
You did not list the process requirement, so I am not sure how to address that. You state accuracy is defined at +/-5 degrees C. Are the stations meeting that criteria when you verify them? If so, you should be fine. If not, then you need to address what the problem is. Either the stations cannot meet that accuracy, there are significant errors in your measurement system, or a combination of both. I assume you have the appropriate standard to measure these.
I'm confused also! You have a nominal value of 20mm listed, but then the accuracy listed as +/-.001 inch. I would keep to one criteria (mm or inch). The caliper information should listed a tolerance for mm and inch. If this is a four place caliper, .001 inch should be obtainable. If it is a 3 place unit, that will be difficult. Too, there is some error accumulated through measurement styles and such that should be accounted for.
Sowmya
Without seeing it, it's hard to determine. It can either be what they are stating the acceptable tolerance is on the instrument they are verifying, or the uncertainty of their standard measurement system. At .03mm, I would think that would be the error of the instrument they are verifying for you.
Just something for you to think about....I sense that you are getting frustrated dealing with tolerances on the certificates, in/out assessments, etc. A good calibration house is well-worth what you pay them; and they are there for you. However, there is no magical book or lists of perfect tolerances for equipment/instrumentation. There are simply too many variables. You need to establish good communication with them.
I encourage you to determine what your requirements are, and that the measurement system is working for those requirements. You should make sure that all your instruments are providing the proper confidence you need in measurements. Talk with your calibration source about the tolerances they have on there. They should be more than happy to assist you with that. In the end, you should have established knowledge that you are providing the proper system for your customers, and your calibration vendor is providing information that you understand and can use.
I hope something here helps.
Thanks to BradM for your informative Post and/or Attachment!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Emoticons are On
[IMG] code is On
Similar Discussion Threads
Why Gauge R&R 10% is acceptable for variable instruments ? VivekanandGawade Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5 5th June 2015 01:24 PM
Is "rounding" acceptable when measuring parts? Tolerance Limits - What is acceptable? David Bear - 2010 Quality Tools, Improvement and Analysis 45 19th October 2012 12:06 PM
Are family type of GR&R acceptable in situations where you have a lot of instruments? Mgrace Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11 12th September 2010 02:04 PM
Acceptable Testing Range for Calibration Studies on a Measurement Device camcnown General Measurement Device and Calibration Topics 3 26th March 2008 12:47 AM
What are Acceptable Limits for Gage R&R Results Sean Kelley Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6 11th November 2005 05:47 PM
The time now is 01:50 AM. All times are GMT -4.
Misc. Internal Links
NOTE: This forum uses "Cookies"
The Elsmar Cove is currently owned by the Marc Smith Retirement Trust and operated by Law-Nutz Wyoming©2018
