Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Quality Tools, Improvement and Analysis > Quality Assurance and Compliance Software Tools / Solutions > Using Minitab Software
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 7th January 2008, 08:20 AM
Brian Dowsett Brian Dowsett is offline
$ Contributor
Registration Date: Apr 2002
Thanks Given to Others: 3
Karma Power: 32
Brian Dowsett has less than 100 Karma points so far.
Question Is Minitab technical support answer 2255 wrong?
Hello cove people
I am looking into Type 1 gauge studies and found my way onto the minitab technical support site.
Could someone take a look at anser 2255 for me and tell me if i'm going nuts?
Page 2, talking about a study of a gauge used on a process with top limit only
gives a formula to calculate the control limit which I can't make sense of (shouldn't the factor used be 'L' which is the number of Std Dev's to be used in the gauge study) ??
Then it says that the measurements should be ABOVE that limit. Shouldn't the limit (which I think is normally 4 gauge std devs) sit below the process top limit and measurements should be below that?
Also does anyone have an opinion on calculation of Cg and Cgk when a gauge is used on a single sided process?
Brian
Sponsored Links
Old 7th January 2008, 04:57 PM
Scott Catron's Avatar
Scott Catron Scott Catron is offline
True Artisan
Registration Date: Aug 2003
Thanks Given to Others: 34
Karma Power: 52
Scott Catron is appreciated, and has over 700 Karma points.Scott Catron is appreciated, and has over 700 Karma points.Scott Catron is appreciated, and has over 700 Karma points.Scott Catron is appreciated, and has over 700 Karma points.Scott Catron is appreciated, and has over 700 Karma points.Scott Catron is appreciated, and has over 700 Karma points.Scott Catron is appreciated, and has over 700 Karma points.
Please Help! Re: Is Minitab technical support answer 2255 wrong?
Bumping to see if anyone can offer some help.
I don't have a solution, but I admire your problem. -- Steven Wright
I'm a moderator here, so if you need help with something, feel free to ask.
Thanks to Scott Catron for your informative Post and/or Attachment!
Sponsored Links
Old 9th January 2008, 05:57 PM
Yanling Yanling is offline
Registration Date: Jan 2008
Karma Power: 8
Yanling has less than 100 Karma points so far.
Default Re: Is Minitab technical support answer 2255 wrong?
Hi Brian,
There are three typos in the last paragraph of page 2. which have been corrected.
1. K should be replaced by L.
2. For lower spec limit only, replace words “less than” by “greater than”.
3. For upper spec limit only, replace words “greater than” by “less than”.
Sorry about this. Thanks for raising the question.
Yanling
Thank You to Yanling for your informative Post and/or Attachment!
Old 9th January 2008, 08:01 PM
Miner's Avatar
Miner Miner is offline
Thanks Given to Others: 166
Karma Power: 251
Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.
Originally Posted by Yanling View Post
Hi Brian,
Yanling
Welcome to the cove, and thank you for responding. I presume that you are associated in some manner with Minitab, since Answer ID 2255 was indeed modified yesterday. If you are, we get a fair number of questions regarding Minitab, and your support would be welcome.
"A fool can learn from his own experiences; the wise learn from the experience of others." - Democritus, 460-370 B.C.
Thanks to Miner for your informative Post and/or Attachment!
Old 10th January 2008, 05:28 AM
$ Contributor
Karma Power: 32
Thanks to all for taking time to help.
The other part of the answer on minitab technical support (my question number 885596) said there is no methodology to calculate Cg or Cgk when a single sided tolerance is used.
I'd instictively think that Cgk could be calculated and used in the normal way but i'm not sure about Cg.
Does anyone have experience or an opinion on this?
Cheers
Brian
Old 24th January 2008, 06:34 AM
Miner's Avatar
Karma Power: 251
Bumping post.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
An Encounter with AT&T DSL Technical Support Jim Wynne Computer, Cell Phone and Internet News 28 16th October 2007 05:25 PM
Corrective action following a wrong answer of the auditee Libnani ISO 9001 - Quality Management Systems Standard 19 14th June 2007 03:31 AM
FDA requires 7 Years of Support? UL 544 for Extended Support? End of Life of Product Pataha Medical Devices (21 CFR part 820) 2 4th October 2005 03:00 PM
Making Minitab support real time data acquistion using digital gages interface wslabey Using Minitab Software 4 21st June 2005 10:30 AM
Military Personnel Support - Looking for Service Person(s) to Support CINDY Coffee Break and Water Cooler Discussions 33 28th July 2004 11:41 AM
The time now is 08:46 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
