The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > Manufacturing, Service, and Business Systems Processes > Manufacturing and Related Processes
Forum Username
Elsmar Cove Forum Sidebar
Custom Search
Monitor the Elsmar Forum
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Sponsored Links
Courtesy Quick Links
Howard's
Atul's
Symphony Technologies
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Reply
Old 25th January 2008, 08:29 AM
Ti QE Ti QE is offline
Registration Date: Nov 2007
Thanks Given to Others: 13
Karma Power: 23
Ti QE has less than 100 Karma points so far.
Re: Surface Finish Requirements for Blasted Surfaces
My customer is responsible for the bonding operation; the surface roughness requirement helps the adhesion process.
Sponsored Links
Old 25th January 2008, 08:36 AM
Karma Power: 23
In Reply to Parent Post by Crash Not View Post
If it is an issue of "ours versus theirs" than maybe both profilometers should be calibrated to the same master. Or create a sample part and have them check it and indicate where the check(s) were made, in which direction, number of checks, ect., and keep that part for your reference.
We've exchanged sample parts with defined areas marked for measurement, defined measurement procedures and methodologies (direction, profilometer settings, etc) and eliminated variables from the process.
Sponsored Links
  #11
Old 29th January 2008, 05:15 AM
swapnilmarne swapnilmarne is offline
Registration Date: Nov 2006
Thanks Given to Others: 2
Karma Power: 27
swapnilmarne has less than 100 Karma points so far.
Re: Surface Finish Requirements (Ra 150) for Blasted Titanium Surfaces
Hello Ti QE ,
Can you give detailed specification for roughness, roughness tester used make, maximum sampling length to be covered ?
I can give some inputs after receiving the data.
Regards
Swapnil
Thanks to swapnilmarne for your informative Post and/or Attachment!
  #12
Old 29th January 2008, 06:43 AM
Phil Fields Phil Fields is offline
Registered Visitor
Registration Date: Mar 2006
Thanks Given to Others: 92
Karma Power: 67
Phil Fields is appreciated, and has over 900 Karma points.Phil Fields is appreciated, and has over 900 Karma points.Phil Fields is appreciated, and has over 900 Karma points.Phil Fields is appreciated, and has over 900 Karma points.Phil Fields is appreciated, and has over 900 Karma points.Phil Fields is appreciated, and has over 900 Karma points.Phil Fields is appreciated, and has over 900 Karma points.Phil Fields is appreciated, and has over 900 Karma points.
Hello Ti QE,
Is adhesion the reason for the roughness? If yes, have you worked with your customer to determine the roughness (that you can produce) to give the best possible adhesion results?
It seems like you are worried more about the measurement comparison between you and the customer, when the solution is more centered on the adhesion process.
Phil
Thanks to Phil Fields for your informative Post and/or Attachment!
  #13
Old 31st January 2008, 12:35 AM
Karma Power: 23
All - I've been in contact with Mahr Federal and Mitutoyo (both profilometers were used to check surface finish and both had problems) and they have advised that their instruments are not the best method to measure surface finish on a grit blasted surface. Both instruments have issues with the surface irregularities (stylus gets caught on rough edges, stylus bounces, etc) which results in the diamond tip being ripped from the mountings thus causing the instrument to throw errors. Normal time between stylus replacement runs from one week to ? depending on usage. I've decided to use optical laser scanning (yes, it's expensive) to determine Ra values but it seems to be a definitive answer to the problem at hand.
Thanks to all for your comments and suggestions.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Accredited Surface Roughness Measurement - Requirement for 1Ra surfaces Mandell ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories 6 3rd March 2011 07:02 AM
Inner Diameter Surface Finish Ra Value vs. Surface Finish Graph Output p v k Raju Manufacturing and Related Processes 11 17th November 2009 05:23 AM
Anodized Aluminum Surface Defects - Stains, raised surfaces, imperfections Phil Fields Manufacturing and Related Processes 17 14th April 2008 01:08 PM
Surface Finish - G5 - Where is this from and how can I measure it? Geoff Cotton Manufacturing and Related Processes 6 15th December 2004 09:33 AM
The best way to define a surface finish jeffr ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories 1 15th October 2003 09:32 AM
The time now is 09:19 PM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, Olde West Chester, Ohio 45069-1929
513 341-6272
