29th January 2008, 09:30 AM
Involved in Discussions
Registration Date: Jan 2007
Thanks Given to Others: 11
Karma Power: 12 Karma: 15
One sided F-test in Minitab
Can anyone tell me the procedure to perform a one side F-test in Minitab v14. The reason to perform this test is that i have two processes 'new' and 'old' and i want to test statistically that the 'new' process is less variable than the 'old' one.
/tahir
6th February 2008, 01:11 PM
Registration Date: Sep 2005
Thanks Given to Others: 571
Karma Power: 231
Re: One sided F-test in Minitab
Thread bumped for further response.
6th February 2008, 07:36 PM
Registration Date: Apr 2002
Thanks Given to Others: 166
Karma Power: 251
Minitab offers several options. Bartlett's Test, the F-test and the Levene test for equal variances. The first two assume and are sensitive to normality in the data. The Levene test is more robust to non-normal data.
See Stat > Basic Statistics > 2 Variances or Stat > ANOVA > Test for Equal Variances and Minitab Answer ID 1183
Note: The is no such thing as a one-sided F-test. These tests verify the assumption that the variances are equal. There is no assumption that one is larger than the other.
"A fool can learn from his own experiences; the wise learn from the experience of others." - Democritus, 460-370 B.C.
Reason: Added detail
7th February 2008, 11:27 AM
Hi Miner,
Thanks for your reply, but as per NIST website, see ( http://www.itl.nist.gov/div898/handb...on3/eda359.htm),
"This (F-test) test can be a two-tailed test or a one-tailed test. The two-tailed version tests against the alternative that the standard deviations are not equal. The one-tailed version only tests in one direction, that is the standard deviation from the first population is either greater than or less than (but not both) the second population standard deviation . The choice is determined by the problem."
so i am interested to know if Minitab offers a way to do a one-tailed version?
br,
/tahir
7th February 2008, 12:09 PM
Involved - Posts
Registration Date: Oct 2001
Karma Power: 46
tahirawan11,
Looks like MINITAB doesn't do this. Probably because you don't need to.
Why do you want to do a one tail test?
From the graphics in the program, it is obvious which variance is larger.
BTW, if the F and Levines differ in signicance, I would rely on Levine's unless you have tested normality of the data.
7th February 2008, 08:43 PM
Karma Power: 251
Originally Posted by tahirawan11
Hi Miner,
Interesting. I learned something new. As you seem to be aware, Minitab does the two-tailed test. It does not have an option for the one-tailed version. The calculation of the F-statistic itself is the same for both the one and the two tailed tests, so you can use Minitab's calculation of the F-statistic.
You will have to ignore the p value and manually determine the critical F-value from tables then perform the comparison shown in the NIST Handbook.
Thanks to Miner for your informative Post and/or Attachment!
