The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Inspection, Prints (Drawings), Testing, Sampling and Related Topics
Forum Username
Elsmar Cove Forum Sidebar
Custom Search
Monitor the Elsmar Forum
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Sponsored Links
Courtesy Quick Links
Howard's
Atul's
Symphony Technologies
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Related Topic Tags
quality control, rubber mixing
Reply
  #17
Old 12th March 2008, 11:03 PM
Miner's Avatar
Miner Miner is offline
Registration Date: Apr 2002
Thanks Given to Others: 557
Karma Power: 391
Miner is appreciated, and has over 1700 Karma points.
Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.
Re: Quality Control for Rubber Mixing and/or link to related forum
In Reply to Parent Post by humtum1977 View Post
1) As we are manufacturing epdm rubber gaskets for architectural sealing application such as windows, doors, curtain wall etc,which property of rubber should we focus to satisfy customer, i thinkg tensile and ozone perofrmance is ok? ur comments plz.
Are these closed/open cell sponges or solid rubber gaskets? Compression set, UV resistance, tear and abrasion resistance come to mind. Temperature resistance, flexibility at low temperature are others. Another might be not staining the mating surface if it is painted, not freezing to the mating surface in winter, or the ability to retain an adhesive tape for mounting.
2) can you give me any material regarding rubber mixing, that you think a beginner must have.
See my earlier post as well as other posters.
3) Please give me brief notes on following chemical, their properties, and purpose of use in rubber mixing, as i have googled a lot but did not get satisfied answer.
a) FEF N550, SRF N550.
b) Stearic Acid, Poly Plastol.
c) TMTD, ZDBC, MBT,ZNO, CBS.
d) Tetrone A
e) IPPD, KHS 68, MMBI.
f) Paraffinic oil, Aromatic oil, Wax.
a) FEF and SRF are carbon blacks that give rubber its strength and hardness.
b) Stearic acid is used as used as an activator, dispersing agent, plasticizer and lubricant. Plastol is a plasticizer that improves the rubbers ability to flow. This helps during extrusion, injection/transfer molding
c) TMTD is an inhibitor that delays scorch time (or the onset of cure). ZDBC, MBT and CBS are accelerators that increases the cure rate (slope) of the rubber. ZNO (zinc oxide) is used for a quicker and more controllable cure as well as a reinforcing agent.
d) Tetrone A is a plasticizer.
e) IPPD is an antioxidant, which increase rubber aging resistance. KHS 68 is an SBR latex/styrene mix with good abrasion, flex and tear resistance. MMBI is an antidegradant that improves heat stability.
f) oils are typically used to improve processability, while waxes migrate to the surface and form a thin film covering the surface protecting the rubber from the attack of ozone.
"A fool can learn from his own experiences; the wise learn from the experience of others." - Democritus, 460-370 B.C.
Thanks to Miner for your informative Post and/or Attachment!
Sponsored Links
  #18
Old 13th March 2008, 06:22 AM
humtum1977 humtum1977 is offline
Involved in Discussions
Registration Date: Nov 2007
Thanks Given to Others: 58
Karma Power: 25
humtum1977 has less than 100 Karma points so far.
Dear Craig
Yes we are planning to use kaolin clay, but i dont have any idea about the quality, if you can give me notes on that, i will be thankful to you.
Regards.
Sponsored Links
  #19
Old 13th March 2008, 06:30 AM
Karma Power: 25
Dear Miner
You have cleared my doubts and have given me the satisfied answer, you have very good experience on rubber, cheers to you, i will be back with some more questions.
Regards.
  #20
Old 13th March 2008, 08:05 AM
qualityforlife's Avatar
qualityforlife qualityforlife is offline
Getting Involved (6 to 9 Posts)
Registration Date: Oct 2007
Thanks Given to Others: 1
Karma Power: 23
qualityforlife has less than 100 Karma points so far.
Send a message via Skype™ to qualityforlife
Or just open this:
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting this post, 3. Use at your Own Risk.
File Type: pdf Technical_Guide_Elements_of_a_Rubber_Compound.pdf (225.2 KB, 106 views)
Thank You to qualityforlife for your informative Post and/or Attachment!
  #21
Old 18th March 2008, 10:00 AM
Karma Power: 25
Please Help! Re: Quality Control for Rubber Mixing and/or link to related forum
Well we have started our epdm rubber mixing and tested the mixed product in the lab, every thing was correct, when we extruded the rubber in extruder there we air bubbles on the surface of the extruded gaskets, what went wrong can any one calrify it, is it pure machine problem or is due to any chemical
chemicals we used (EPDM 965,FEF N550,PARAFINIC OIL,ZNO,STEARIC ACID
TMTD,MBT,ZDBC,TETRONE A )
Is there any way to test these air bubbles in testing lab before extrusion.
thks and regards.
  #22
Old 18th March 2008, 11:17 PM
Miner's Avatar
Karma Power: 391
Blistering on the surface is typically caused by moisture. This may be caused by a leak in the water jacket of the extruder barrel, or may be moisture on the uncured strip rubber. If you are spraying/dipping a release agent onto the rubber to prevent sticking, make sure that you dry it before putting it into the basket.
Porosity throughout the cross-section may be caused by moisture, trapped air, over/under mixing, wrong plasticizer, or incorrect cure rate/time. Trapped air is typically caused by starving the extruder screw. There should be a rolling ball of rubber in the mouth of the extruder. If this ball is not present, the extruder screw is not full and is mixing air into the rubber. Some formulation may form porosity if the cure rate/time is incorrect. Some plasticizers with low boiling point constituents may also cause porosity.
  #23
Old 19th March 2008, 01:36 AM
Karma Power: 25
Before mixing we need to weigh the ingredients, is there any tolerance to weigh these materials or the exact quantity is must to weigh
1) Suppose we weigh 250 grms of chemical to mix is it necessary that it
should weigh 250 grms exactly or threse is any tolerance (250 ± ......) so
that it will not effect the out put.
Is there any special weigh scale required, can u give me any example of
good weigh scale with good accuracy.
2) How much time is standard to mix rubber in mixing mill to mix 25 kg batch3
so that all chemicals are mixed properly.
3) Why is sulphur most widely used as vulcanizing agents any specific
reason to use it, what are another vulcanizing agents.
4) can u give me the in detail the diagramatic representation of mixing
process.
5) Is there any requirement of Std. temperature setting for the mixing room.
is there any standard condition for mixing raw material storage.
does raw material gets damaged if kept for long time.
  #24
Old 19th March 2008, 07:44 AM
Miner's Avatar
Karma Power: 391
1) A rubber chemist would be better able to answer this. My experience has been an exact weight. When we upgraded our mixing area, we invested in higher precision scales to improve the control.
2) When I left, there were two schools of thought on this. One was to drop the batch at a specific time. The other was to drop when it reached a specific temperature. We dropped on temperature. But both methods were unique to the rubber formulation being mixed.
3) There are only three methods for curing rubber. Sulfer is the most widely used. The other two are peroxide, which is the next used. This is more expensive and is used when sulfur is not desireable. The last, more rare for obvious reasons, is a radiation cure.
4) I do not have time to do this now and do not have an existing one. We had a two-floor setup. The chemicals were stored and added to a Banbury mixer on the second floor, mixed and dropped directly onto a mill on the first floor. The rubber was stripped off and dipped through a release slurry. The strip was then festooned through a series of blowers to dry the slurry, then wig-wagged into baskets. The sponge rubbers were then stored in a temperature controlled room at 68 degrees F.
5) Until the rubber is mixed, the ingredients are not particularly sensitive to temperature. After mixing, rubber will immediately start the curing process, albeit at a very slow rate. The rate of this cure will depend on the ambient temperature and on the specific formulation of the rubber. We used a 3-day shelf life on closed cell rubber formulae and 5 days on dense rubber formulae. However, we had one specialty compound that had a 12-hour shelf life.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Food Transportation the Weakest Link? Mixing cargo in food trucks mguilbert ISO 22000, HACCP (21 CFR 120) and Food Safety 0 21st September 2011 08:59 AM
Closed or Resolved: Forum Trend Link (Monitor the Forums) bobdoering Forum Suggestions, Complaints, Problems and Bug Reports 4 2nd August 2010 08:48 PM
RUBBER PART has a special strong smell - Over-moulding with NBR rubber sadhusong Manufacturing and Related Processes 4 4th September 2008 09:13 PM
Anyone willing to share anything related to Quality Control Project (QCP)? Raiha Quality Tools, Improvement and Analysis 5 28th January 2008 03:23 AM
Software quality related forum threads-stat Govind Software Quality Assurance 10 18th August 2005 04:28 PM
The time now is 02:10 AM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, Olde West Chester, Ohio 45069-1929
513 341-6272
