Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
17th March 2008, 04:34 AM
wehttam
Registration Date: Feb 2005
Karma Power: 36 Karma: 62
Utility Company Call Center / Customer Contact Center Audit checklist
Hi All
We are a large utility company and have just changed call center partner. Has anyone ever carried out a quality system audit of a call centre.If so could they send me a copy of their audit checklist.
Types of calls include new connections, design,construction, siteworks, payments,maintenance, payments, emergency, leak management.
Much appreciated?!
17th March 2008, 09:54 AM
Registration Date: Jun 1999
Thanks Given to Others: 48
Karma Power: 897
Re: Utility Company Call Center / Customer Contact Center Audit checklist
In Reply to Parent Post by WEHTTAM
Hi All
Much appreciated?!
Yep, for system registration and my checklist was the requirements of the Standard and the requirements of their own procedures.
If you use a pre-packaged, bland, programmed checklist you'll have nothing more than a tick-list that will have a tendency to lock auditors in and put blinders on them.
We who have seen war, will never stop seeing it. In the silence of the night, we will always hear the screams. Joe Galloway
Thank You to Randy for your informative Post and/or Attachment!
18th March 2008, 06:07 AM
wehttam
Thanks Randy
We have developed a lot of the scripts for the call center. But I was looking for a procedure/plan/protocol for auditing a call center.
Checklists are not perfect but they can be very useful if correctly thought out and specific. They are catalysts and can be changed as often as needed.
Thanks for your reply.
18th March 2008, 07:16 AM
Auditor / Consultant
Registration Date: Aug 2005
Thanks Given to Others: 488
Karma Power: 451
Thanks Randy
I would heed Randy's advice. If you use a 15 point checklist, most auditors will ask approximately 15 questions. That is not a process audit.
Good checklsists can help facilitate an audit, but it is unlikely you will get a "good checklist" from another company because that is not how good process based checklists are developed.
The best is a three step process:
Look at your metrics, and follow any audit trails related to metrics missing their targets.
Then, review the relevant flowcharts, procedures and work instructions, mark the significant steps, and make those your checklists. Follow the inputs and outputs.
Finally, review links to inputs and outputs from related processes. Are they effective? Are there bottlenecks in the process.
This is a much better process audit model than just asking questions from a list. Further, if auditors have even a little training in this model, they should be able to do pretty worthwhile internal audits.
PS: I have extensively audited call centers and fulfillment centers using this model. It worked very effectively for the company.
Relentlessly Pursue Excellence!
Thanks to Helmut Jilling for your informative Post and/or Attachment!
18th March 2008, 07:51 AM
wehttam
Thanks Helmut for your reply.
I understand what you mean but I don't necessarily agree although your method sounds good. My original terminology may have been a little unclear. I was basically looking for a procedure or a plan or a protocol.
Thanks again
18th March 2008, 08:21 AM
Thanks Given to Others: 4,022
Karma Power: 776
Thanks again
Wehttam: It's unlikely that anyone else's call center procedure will be much good to you - the chances that they run like the one you described in your OP is slim to none. Since most (experienced) people here would clearly distinguish between the type of documents you're looking for - procedure is different to a plan, plan different to protocol etc. it would be helpful if you could elaborate on exactly what you are seeking.
Originally, you wanted an audit checklist and current best practice is not to use 'canned' formats - for the reasons stated above. Are you intending to perform an audit? If so, then you'd be better off putting your own together by studying what the callcenter documentation says today. Randy, Helmut et el normally give great advice - we understand that you may not agree - but you run a risk of ignoring it!
Of course, if they don't have any documentation or formal systems, you're going to have a problem - which won't be helped by using someone else's checklist/procedure or any other documents...........sorry!
'Cause you know sometimes words have two meanings.....
18th March 2008, 08:31 AM
wehttam
Thanks to all who contributed
11th April 2009, 02:02 PM
Registration Date: Apr 2009
Karma Power: 17 Karma: 10
I'm working as a call centre manager in a bank in which the call center agents are empowered to do maintenance activity, such as (temporary increasing credit card limits , reversing charges less than a certain amount , replacing lost and damaged cards ..etc)
I found it necessary to create an "internal auditor" position to monitor the above mentioned activities , report violation of implemented parameters of these activities and to have more control
I would appreciate if anyone can help me in creating a job description for that post or have a ready JD
Also I will be glad if some one can give me advise on how "internal auditors" work in call centers
Thanx, Hawa
Forum Posting Settings
