28th April 2000, 08:44 AM
Involved - Posts
Registration Date: Apr 2000
Karma Power: 39 Karma: 10
What are monitoring devices? ISO 9001 Clause 7.6 - Control of ... monitoring devices
Cl.7.6 ISO/DIS 9001:2000 named "Control of measuring and monitoring devices".
1.Should anybody give some examples of "monitoring devices"?
2.Is there any "ISO" definition of the
term "monitoring"?
Thank you in advance
28th April 2000, 09:24 AM
Courtesy Access
Registration Date: Dec 1998
Karma Power: 63 Karma: 151
monnitoring? as opposed to measuring.....just an extension...as in thermocouples, humidity, pressure stuff on process equipment...measuring in a sense but not measuring the product for acceptance...implied before...stated now... thats one quick take on it......next?
6th June 2001, 08:19 AM
Control of monitoring and measuring devices
The ISO 9001:2001 refers that the organization shall identify the processes needeed for the quality management and determine the sequence and interaction of these processes. The question is: Shall we have to establish a different Calibration Plan (Control of monitoring and measuring devices) for each process or we can maintain one with all?
6th June 2001, 04:36 PM
$ Contributor
Registration Date: Sep 2000
Karma Power: 63
In my opinion, the answer to your question is that one calibration plan is sufficient for all production processes. Except for very special cases, the calibration requirements of a measuring instrument are not dependent on the process it it used in. The person doing the calibration often does not know or care what the process is -- they only know about the tool he or she just picked up to work on. Also, if a common measuring instrument is issued at random from a central toolroom, it is likely to be used on a different process every time.
Calibration verifies the performance of a measuring instrument against its own specification, by comparing it to a known standard of lower uncertainty. In most cases, the process the instrument is used in has no effect on the instrument's own specifications or, therefore, the calibration requirements. There are some exceptions, but they are (in my experience) rare.
Differences between different types of instruments are handled by the calibration activity. Micrometers, theodolites and voltmeters each require different calibration processes, but that is because they are different types of instruments. It has nothing to do with the processes they are used in, though.
Graeme C. Payne
ASQ Certified Quality Engineer
22nd June 2001, 05:58 AM
7.6 Control of Monitoring & Measurement
7.6d) requires that equipment shall be safeguarded from adjustments that would invalidate the measurement result.
Many of our scales, calipers etc have adjustment controls so that they can be adjusted if necessary. In the past our people have been told not to touch any of these controls (although they may need to tare the scales, or rezero the calipers). This has always worked ok.
Are we expected to seal the adjustment points to prevent tampering? Some of instruments would be hard or impossible to seal in this way. Any thoughts would be appreciated.
22nd June 2001, 12:28 PM
Registration Date: Mar 2000
Karma Power: 51 Karma: 114
Just a thought - (and may be way off base here) I would view "Re-setting to O" a normal use practice for scales & digital calipers.
Why would this action not be "justified" ---- by 0 set -- we are not "Invalidating the "adjustment of the insturment" But verifying the normal state of the device.
Any one else have an opinion?
Regards
Jim
22nd June 2001, 12:45 PM
Registration Date: Apr 2001
Karma Power: 37 Karma: 20
I totally agree with Jim on this one. Our plant workers, toolroom and qa use micrometers on an hourly basis. I'm quite sure they get zeroed all the time. I don't see how that's an issue at all. I think what they are talking about here, as with everything else, they are expecting you to take 'reasonable precautions'. What is reasonable? That will obviously be up to your discretion. You will have to determine where there is calibrated equipment that could be tampered with easily that may affect quality.
[This message has been edited by Fire Girl (edited 22 June 2001).]
22nd June 2001, 04:28 PM
Karma Power: 35 Karma: 10
I have used the following;
...operators are allowed to make adjustments to the following families of measuring equipment ...then list!
Exceptions are to the following which are locked, sealed and controlled by _____
