Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Quality Tools, Improvement and Analysis > Quality Assurance and Compliance Software Tools / Solutions > Using Minitab Software
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 31st March 2008, 01:33 PM
George Davis George Davis is offline
Shy Poster (1 to 5 Posts)
Registration Date: Jul 2003
Thanks Given to Others: 1
Karma Power: 26
George Davis has less than 100 Karma points so far.
Question Changing LCL (Lower Control Limit) on a Minitab Control Chart
I am developng a control chart that tracks warranty returns. Obviously, the desired level is "0". I would like the control chart to reflect this. Is there any way to set the LCL to ) in Minitab?
Thanks in advance.
George
Sponsored Links
Old 31st March 2008, 01:36 PM
Jim Wynne's Avatar
Jim Wynne Jim Wynne is offline
Courtesy Access
Registration Date: Jan 2005
Thanks Given to Others: 755
Karma Power: 611
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Default Re: Changing LCL on a Minitab Control Chart
Thanks in advance.
George
Welcome to the Cove.
That would be the lower specification limit, not control limit, and you should be able to set the spec limit wherever you want it. The control limits are calculated from the input data.
Thank You to Jim Wynne for your informative Post and/or Attachment!
Sponsored Links
Old 31st March 2008, 08:04 PM
Caster's Avatar
Caster Caster is offline
An Early Cover
Thanks Given to Others: 193
Karma Power: 104
Caster is appreciated, and has over 1700 Karma points.
The poster may have a point, I think Minitab sometimes calculates and displays a negative LCL. Although mathematically correct, it makes no sense in the real world. I think IMR charts do this?
I'll have to check when I get in to work, oddly enough as much as I love SPC, I don't have a copy of MiniTab here at home!
So now I'll ask an expert, does anyone know how to set CL breaks in Mintab?
Old 31st March 2008, 10:39 PM
Steve Prevette's Avatar
Steve Prevette Steve Prevette is offline
Deming Disciple
Registration Date: Feb 2004
Thanks Given to Others: 60
Karma Power: 190
Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.
Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.
True, if you are getting a negative LCL when negative numbers are not possible, there is no reason to display the negative LCL, or perhaps overide it to zero. But - you would need to keep in mind where one standard deviation below average and two standard deviations below average are in case you are using them as part of detection rules.
I assume the original question asker had a LCL greater than zero, but wanted to show the LCL at zero since that was the desired specification. As properly pointed out, that would not be a good idea. One reason why not is - let us say this is a counting of bad things happening chart (injuries, defects, events, etc). The fact that the LCL is greater than zero means that we need to be realistic and say by the current process that we will most likely have a non-zero rate. That doesn't make it good or bad, but we need to acknowledge what the process is currently capable of.
And, by realizing the LCL is greater than zero, we know that if we do receive a time interval with zero items counted, then something special has indeed happened, and we may have a basis for celebration. Unless of course the method by which we got to zero was we said - "The next person to report a bad thing gets fired".
Steve Prevette
"A Passionate Statistician", ASQ CQE, Fluor Government Group
The opinion stated above does not necessarily reflect that of my employer.
Old 1st April 2008, 07:19 PM
Karma Power: 26
Thanks to everone who replied. Yes, Minitab did produce a negative LCL, and zero is the lowest possible (we are measuring units returned for warranty credit).
This is receiving further discussion here. There is some concern that showing the process as being within control limits will cause some to believe the current level is acceptable (not true). We do not have an upper specification limit for returns. We are thinking of establishing a target, which would be less than the mean to explain the expectations.
G
Old 11th April 2008, 12:22 PM
Allattar Allattar is offline
Involved in Discussions
Registration Date: Jan 2008
Thanks Given to Others: 4
Karma Power: 19
Allattar is appreciated, and has over 500 Karma points.Allattar is appreciated, and has over 500 Karma points.Allattar is appreciated, and has over 500 Karma points.Allattar is appreciated, and has over 500 Karma points.Allattar is appreciated, and has over 500 Karma points.Allattar is appreciated, and has over 500 Karma points.
Default Re: Changing LCL (Lower Control Limit) on a Minitab Control Chart
Just wondering if using a proportion chart would be a better application here?
I can also hazard a guess that the lower bound at zero makes the data non-normal. In that case to display correctly on an I-MR chart you may want to transform the data to a normal distribution.
It also sounds like it is just binomial data, and whilst a binomial distribution can be applied to an I-MR chart, it should probably only be used where the distribution approximates a normal one.
Old 11th April 2008, 01:22 PM
Deming Disciple
Karma Power: 190
Control charting will work regardless of the distribution. Dr. Shewhart documented the Tchebychev Inequality (see other discussions on the Cove about that) and tested control charting with the normal distribution, and two non-normal distributions. I-MR (and my preference, I-sigma) can be used effectively even if the distribution is non-normal.
If what is being plotted is indeed binomial (I can't tell from what has been posted so far), I would recommend going to the p-chart control chart.
Steve Prevette
Old 14th April 2008, 04:36 AM
Karma Power: 19
I quite happily understand that Individuals charts work for non normal data. However the control limits are going to be in slightly odd places. At least for an individuals chart calculated this way.
This is then where you get a negative control limit.
Reply
Bookmarks
Tags
control chart, lcl (lower control limit), minitab
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
How to Calculate UCL (Upper Control Limit) & LCL (Lower Control Limit) & CL? maxfusion SPC Monitoring and Statistical Analysis Techniques 20 4th June 2009 04:14 PM
What type of Control Chart? USL of 3 and a lower spec limit of 1 2001Wingnut SPC Monitoring and Statistical Analysis Techniques 1 26th November 2008 09:16 AM
SPC for One-sided Specification - Setting the Lower Control Limit keatwoon SPC Monitoring and Statistical Analysis Techniques 4 23rd March 2005 03:03 PM
Control limit - How is table for x-bar & R control chart derived? Kleeve SPC Monitoring and Statistical Analysis Techniques 7 24th July 2001 02:14 PM
The time now is 05:05 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
