2nd April 2008, 10:41 PM
Registration Date: Mar 2008
Karma Power: 7 Karma: 11
File Attachments - How do I load a Picture Attachment?
I have found a picture of the sign, how do I load it. it is jpg form, tried copy paste no avail, and it doesnt' look like it was a RT number it was an exit number, 50 thru maybe 54? for the musem, does it ring a bell. This sign was created in 1993, barring severe weather the signs were guarteteed for 15 years. Painted with UV protector paint coating
2nd April 2008, 10:54 PM
Re: How do I load a picture attachment
The picture is linked as an attachment if any would like to see it that is how I put it on.
2nd April 2008, 11:07 PM
Quality Manager
Registration Date: Sep 2003
Thanks Given to Others: 182
Karma Power: 397
If you continue to scroll down from the message box when you make a post, you will see a series of options, including one where you can post an attachment.
Additional Options Miscellaneous Options Show your signature
Automatically parse links in text
Disable smilies in text
Attach Files Valid file extensions: bmp doc dot dwg dxf flv fp5 gif gz jpe jpeg jpg mdb mov mp3 mpp pdf php png pps ppt psd rar sdr tar tgz txt vsd xls zip
Manage Attachments
Thread Subscription Notification Type:
Do not subscribe No email notification Instant email notification Daily email notification Weekly email notification Rate This Thread If you like, you can add a score for this thread.
Choose a rating 5 : Excellent 4 : Good 3 : Average 2 : Fair Content 1 : Not Useful At All
Thread Management Close this thread after you submit your message
Un-stick this thread after you submit your message
Although it doesn't exactly look like this (I'm too lazy to make a screen shot and do all the other stuff), you scroll down to "Attach files" ( in red on this view) and click on the box that says "Manage attachments" and follow directions in the popup box.
3rd April 2008, 12:06 AM
the insert image is not working on my system check my profile and there is an attachment.
3rd April 2008, 12:15 AM
Registration Date: Sep 2006
Thanks Given to Others: 814
Karma Power: 274
What is the format of the picture and what is it's size? Are you trying to attach the picture, or use it as an Avatar?
Brad
My idea of housework is to sweep the room with a glance.
3rd April 2008, 12:26 AM
Registration Date: Sep 2005
Thanks Given to Others: 572
Karma Power: 231
Also see: How to Attach a File to a Post in a Thread
The maximum size of files (varies for different type/format of file) that you can attached are found therein.
3rd April 2008, 12:40 AM
Quality Manager
Karma Power: 397
There is a possibility the Cove software is blocking G White from attaching a file because he does not have a sufficient number of posts (we impose this limit to thwart spammers.) I am sending my email address directly to your email.. Send the picture to me as an attachment and I will add it for you.
Thanks to Wes Bucey for your informative Post and/or Attachment!
3rd April 2008, 01:46 AM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
If you want to attach a picture or other file to a post you make in a discussion thread, please read How to Attach a File to a Post in a Thread.
If you want to attach a Profile Picture or an avatar, go to your UserCP (User Control Panel). On the left you will see a link to: Edit Your Profile. There you can attach a picture up to 150 x 150 pixels in dimensions and up to 64 KB (file size). This has been sufficient for most Profile pictures.
If you want to add an 'avatar', look for the Edit Your Avatar link. The limitations are 75 x 75 pixels in dimensions and up to 64 KB (file size).
If you need help, let me know.
Also see: Avatars and Profile Pictures - How to show my picture next to my name in my posts?
OK by me. I did check permissions for file attachments, avatars and profile pictures for Registered Visitors and there is no minimum post requirement set.
