Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - Calibration, Measurement Gages and Test Laboratories > Measurement Uncertainty (MU)
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 6th April 2008, 12:47 PM
mmurat mmurat is offline
Shy Poster (1 to 5 Posts)
Registration Date: May 2006
Karma Power: 15
mmurat has less than 100 Karma points so far.
Question What is maximum limit for MU (Measurement Uncertainty) or acceptable criteria?
Hi, I have been working as Calibration superintendent. I studied and searched MU but I couldn't find my questions about evaluation of MU. How can I show MU and what is max limit of MU or accaptable criteria?
if Anyone can help me ,I will appreciate it.
Thanks in advance.
Sponsored Links
Old 7th April 2008, 12:41 AM
Hershal's Avatar
Hershal Hershal is offline
Metrologist-Auditor
Registration Date: Mar 2004
Thanks Given to Others: 1
Karma Power: 186
Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.
Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.
Default Re: What is max limit for MU or acceptable criteria?
Showing MU is typically accomplished using either a simple statement or somtimes a chart if there is a different MU for each reading. MU is also typically expressed as "k=2 to approximate 95% confidence" and the statement needs to be there to explain the expression of M.
Ther is not really a limit to MU, but depending on what you are calibrating, the MU likely won't exceed about 1%.
Hope this helps.
Sponsored Links
Old 7th April 2008, 04:59 AM
Karma Power: 15
Thanks Hershal for your help.
Old 10th April 2008, 05:54 AM
Karma Power: 15
Please Help! Re: What is maximum limit for MU (Measurement Uncertainty) or acceptable criteria?
Hershal,
MU for any instrument is written to its certification. This MU should be calculated according to a butget including instrument resolution,temp difference and thermal expansion etc.When I buy a instrument,can ıI use uncertainty indicated on the certification adding repeatability? Or Do I have to calculate MU according to new budget?
Thanks in advance
Old 10th April 2008, 05:25 PM
Hershal's Avatar
Metrologist-Auditor
Karma Power: 186
Default Re: What is maximum limit for MU (Measurement Uncertainty) or acceptable criteria?
Great question!
When you obtain the instrument, the uncertainty stated is what is delivered to you. The uncertainty of your measurement will take that into account and also add any other factors present in your measurement, including the repeatability.
Other factors may also need to be included, for example, temp and humidity, vibration, dust, barometric pressure, or other influences that can affect the measurement.
Thus, the uncertainty of your measurement will be greater than the uncertainty as delivered to you, and depending on what kind of measurement you are doing it may be much greater or only a bit.
Hope this helps.
Old 11th April 2008, 02:50 AM
Karma Power: 15
thank you for your response and help.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Maximum Permissible Error for Monitoring and Measurement Devices mickng ISO 17025 - Calibration, Measurement Gages and Test Laboratories 19 22nd July 2009 04:33 PM
TUR (test uncertainty ratio) based on Standard or Expanded Measurement Uncertainty? ScottBP Measurement Uncertainty (MU) 2 25th March 2009 11:04 AM
Measurement Uncertainty & Tolerance - Adding Uncertainty to the Tolerance Charles Wathen ISO 17025 - Calibration, Measurement Gages and Test Laboratories 12 5th June 2008 08:16 AM
Measurement Uncertainty - Measurement Uncertainty in Measurement Results Marc Definitions, Acronyms, Abbreviations and Interpretations 0 17th April 2006 08:13 AM
Accuracy Criteria - Published material related to acceptable accuracy criteria Mark W ISO 17025 - Calibration, Measurement Gages and Test Laboratories 5 27th May 1999 06:45 PM
The time now is 11:38 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
